Question about Northwestern Bell Classic Favorite 52860 Corded Phone
Programming the "Memory Dialer"
I've lost the manual for the phone, and I can't figure out how to program the "Memory Dialer" to hold the numbers I want to speed dial. Does anyone know how? Please help. Thanks!
  • Jorene Jan 06, 2008
    Have Northwestern Bell easy touch 77369 s/n 8268272. Cannot find manual. Wish to store phone numbers. Any Help appreciated.
  • Anonymous Mar 14, 2014
    I have a Vista 100 Bell phone manufactured by Nortel. I have lost the manual to tell me how to enter a new number in its memory.
You may try this: 1. Pick up the handset and listen for a dial tone. 2. Press and release the STORE button. 3. Enter the phone number(up to 16 digits)you want to store into memory(The telephone number will not dial out) 4. Press and release the STORE button. 5. Press a one-digit number(0 - 9)on the keypad to store the phone number into the desired memory location. 6. Hang up the phone by returning the handset to the handset cradle on the base. 7. To store more phone numbers in memory, repeat steps 1 - 6 Good Luck !!
Posted on Jul 19, 2007
  • guest131 Jul 30, 2011
    EUREKA!! It worked!! BTW to use the speed dial after you've programmed the # just push & release the "memo" button then press & release the speed dial # (1-9) that has the phone # you wont to call stored in it!. you should then hear the phone dialing the number.
SOURCE:
Radio Shack telephone Cat# 43-3091 Need phone setup instructions incl. programming memory button
If you mean the Radio Shack 43-3901 then you may download a copy of the manual here.
Apr 06, 2012 | Lands Phones
I have a Panasonic Easa-phone Model KX T-3135. I need information on how to program the memory to use the automatic dialer keys.
Panasonic ESA-PHONE - KX-T3135
Program instructions for the "Automatic Dialer"
On the right side of phone set the 'Memory' switch from 'Set' to 'Program'
If programing the upper entry of a 'Automatic Dialer' buttons:
Press the button - enter the phone number as it needs to be dialed - press the 'Memory' key on the left side of the phone's face.
If programing the lower entry of a speed dial buttons:
Press the 'lower' button on the left side at the bottom of the 'Automatic Dialer' pad;
When all entries are complete, on the right side of phone slide the 'Memory' switch from 'Program' to 'Set'.
May 03, 2011 | Cell Phones
How to program numbers into the memory of the fax machine.
Here is a link to your Toshiba DP-85F Operators Manual. Reference pages 65 through 80 to program Abbreviated Dialer Registration, One Touch Dialer Registration, and Group Number Registration.
http://209.167.114.38/dealers/opg/support/manuals/DP80F_85F.pdf
Dec 03, 2009 | Toshiba DP-85F Fax
I have lost my instructions for programming frequently used numbers into the phone.
http://www.amazon.com/Panasonic-KX-TSC11B-Corded-Phone-Caller/dp/B0007Q3QSK
Above is your instruction book,moved down the page till you get to "product details".There you can download your manual.
Hope i`ve helped
Nov 27, 2009 | Panasonic KX-TSC11B Corded Phone...
Need help programming autodial feature on my ge-27923-ge cordless phone
how do you change GE Model 27923 2.4 GHz cordless phone from pulse dial to touch phone dial? I lost my instruction manual Thanks
Apr 15, 2009 | Lands Phones
Instruction manual for Telemergency 210
i have a red light on left of the phone. blinking how do i get it off
Nov 29, 2008 | Lands Phones
Toshiba RPCI DI Station Ringer
which system?
The most popular is the DK system but it came in several revisions.
The primary differences are the way the ports are numbered and several program numbers.
Programming is done from port 005(ext 205).
The sequence of events is:
enter programming mode by pressing "speaker *#*#1*2*3"
enter ringing program
Day ring is "spkr 81 hold"
enter port number of the port you want to ring (example : 007#)
press buttons corresponding to the lines you want to ring then press hold.
To exit programming press"spkr ## hold then spkr ## hold.
Oct 17, 2008 | Toshiba DKT-2010H Corded Phone
I need to find a user manual.
This phone requires a phone system. The system itself stores the information. You need a programming and installation manual for your phone system, not the phone. You will need to determine the model number of your main phone system and look for the manual using that information. Phones only have user guides that explain how to use the features and do not get into programming the system.
Also, if you lost your programing in a power outage, most likely the memory battery is dead and this will keep happening in the future. Before making any programming changes, that battery needs to be replaced or you could possibly get away with a UPS battery backup system to power the entire phone system in a power outage.
Oct 30, 2007 | NEC ETW 8-2 Corded Phone
Memory dialer
I believe it is "Phone Book" then "Select" (STORE), enter the name, then location (01-09).
Oct 23, 2007 | Lands Phones
Northwestern Bell Classic Favorite 52860 Corded Phone Logo
563 people viewed this question
Top Northwestern Bell Lands Phones Experts
Bruce Showalter
Andrew Taylor
Andrew Taylor
Are you a Northwestern Bell Lands Phone Expert? Answer questions, earn points and help others
