Question about Watches
How to turn off alarm on a mickey mouse digital watch
Mickey mouse black band digital watch
SOURCE: Arnette Digital Watch
So My arnette digital wrist watch was going off every 5 minutes. I hit the Mode, Reset, and St/STP buttons at the same time out of frustration, and it seemed to turn my alarm off.
Posted on Jul 17, 2008
escapement
  • 2334 Answers
SOURCE: Remove links from watchband.
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 08, 2009
SOURCE: How do I turn the alarm off on my Jag J1027 watch?
Hold the Reset (S2) button in and press the Start (S1) button to turn the Alarm OFF or ON.
Hold the Reset (S2) button in and press the Mode (S3) button to turn the Chime OFF or ON
Posted on Oct 08, 2009
gemineye61
  • 831 Answers
SOURCE: i have a lorus mickey
You may need to have a local jeweler who has a watch press to put it back on, If you put to much pressure on the inside of the back, it may be warped. A knowledgeable jeweler should be able to fix that issue also.
Thank you for contacting FixYa..
Jewel
Posted on Aug 31, 2010
guru_fixya
  • 944 Answers
SOURCE: what battery do i need
CR920 3V + is the battery you need to buy.You can buy any A+ 3v battery it will be of same size.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 08, 2010
How to fix a plastic disney watch
Yes, you can solve your watch problem from ankaka . It is a great place of digital watch as well as many electronic products. Different modern types of digital watch and solution in case of problems are available here.
http://www.ankaka.com/Wholesale-led-watches_c10091
Apr 03, 2013 | Disney Mickey Mouse Watch with Square...
My gold Mickey mouse Lorus watch was opened a part damaged by the person replacing the battery. This is not a digital watch, but has nthe mouse with hands and a second wheel at bottom.
You are probably going to have to look for an identical watch for parts.You might try this site:
http://www.esslinger.com/watchparts.aspx?gclid=COCr3t2F9KUCFcIKKgodgiARnA which is parts for watches. I'd have a look on ebay as well for a watch that is not working. Of course it does depend on the part you are looking for. I am also wondering if the inner parts for another Lorus mickey moue watch might fit, but maybe you don;t wish to change it out from the original.
Dec 17, 2010 | Disney Lorus Out of Production Collectible...
I have a Woman's Mickey watch that has "Disney Time Works" on the back of it. I would like to get a new band for the watch since after 10+ yrs it is very worn. The band is gold tone but it has not the...
mcdevito75 here, Any small watch repair shop can replace the strap for you. Ebay may have Mickey Mouse replacement straps if you"d like a Mickey Mouse strap.
Sep 24, 2010 | Disney Watches
Need to get watch repaired can you help me find a place to repair it
mcdevito75 here, It would depend on what is wrong with your Mickey Musical watch. I am in the repair service directory at the bottom of this page, I am Mike at the RITE TIME BASICS in Florida and I do some work on the 40"s, 70"s and 80"s Mickey watches. Or you try to look for a small watch repair shop in your area and have them take a look at your Mickey watch.
Jul 06, 2010 | Disney Adult Gold Musical Mickey Mouse...
I cant set my dancing mickey mouse alarm animated rat001 watch
mcdevito75 here, The crown is very flush with the case, from the front of the watch sip a fingernail just unfer the crown and lift. Now you can turn the crown and set the time.
Jun 21, 2010 | Watches
I have a minnie mouse that was made in 1928! does any one no howmuch itz worth its called classic mickey!! please
mcdevito75 here, hello miss d, the first Mickey watch Disney came out with was in 1933, Mickey was invented in 1928, if this is a picture of your Mickey above, then it wa made in the early 1980"s. If it's working very well it could be worth a collector value of approx. $30.00 --$50.00
Dec 08, 2009 | Disney Since 1928 Classic Mickey Mouse...
I have a Lorus NX11A multifunction watch and have no manual. I have been on the Lorus website but it might as well be written in Japanese
mcdevito75 here, I would imagine this is a Mickey Mouse Lorus watch by the picture supplied. If it Has DAY / DATE function, here"s what to do, --- To set the DAY, pull the stem out to set, keep turning the hads till you rech the day, then push in the stem. To Change the DATE 9 number) slip your fingernail just under the stem and lift it to it"s first position (notch) this should allow you to change the DATE (number) without haveing to turn the hands so many times.
Jun 24, 2009 | Disney Lorus Out of Production Collectible...
Can't get to work.
I have a lorus rvs001. Silver with black band. The instruction booklet says it takes a SR920W. Seiko Maxell or Sony.
Apr 13, 2009 | Watches
Watches Logo
111 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
