Question about Maytag PYG2300A Gas Dryer
Dryer won't shut off after cycle
Everything seems to work fine except that after the clothes are dry, it doesn't shut off. It ran for 5 hours yesterday$$. The model # is MDG9206BWW
  • 2 more comments
  • doverbay1 Jan 19, 2009
    I am using the timed dry cycle. I turn the timer thingy and then push the button. Actually, it's my wife that does all the clothes. I just fix things...or try. She would be very happy if I could fix this!
    Timer doesn't seem to move at all.
    Correction...My wife just informed me the timed dry works and moves properly, but the auto dry does not.
  • Anonymous Mar 03, 2009
    dryer works fine on timed cycle but when used in auto-dry it never shuts off
  • 61 Answers
I got to know what cycle you are using the timed dry or the auto cycle timed dry you may have a bad timer if auto dry it coult be the auto dry resistor or it could be a clogged vent.
Posted on Jan 19, 2009
  • Shawn Smith Jan 19, 2009
    does the timer ever move?
  • Shawn Smith Jan 20, 2009
    ok there is a resistor onthe timer if you have an ohm meter check there resitance on it what it should read should be printed on the resistor if this checks good replace the cycle thermostat located on the blower housing
Hi We have a miele condensor dryer. It is working fine except that you have to put clothes through twice to dry. It seems to cut short the drying process and then you need to put the machine back on...
The first thing you need to check is your vent system. If your dryer vent is clogged with lint, the dryer has a hard time expelling the moisture.
Then, if the vent is clean, try using a timed drying cycle instead of a sensor cycle. If your clothes get dry using the timed cycle, then you might have a sensor problem.
Also, make sure your wash machine is properly spinning out the clothes. I saw that once before where the customer thought the problem was with the dryer, but it ended up being their wash machine's ATC switch adding water at the end of the spin cycle.
Nov 01, 2014 | Dryers
My dryer does not shut off and doesn't get hot. It takes almost 5 hours to dry a load of clothing.
Sorry to say but it sounds like the heating element is on its way out... Happened to ours and repair was more than a new dryer so we brought a new one
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
My maytag duet electric dryer is heating, all controls seem fine, we cleaned out the lint traps, checked the hose and blew out vent as well. The dryer keeps shutting off early before clothes are dry. They...
Your moisture sensing bars may have junk on them. The way your machine detects drynesss ir with we clothes.
As them wet clothes rub them bars they short out the board and that way it knows them clothes need a bit more time.
If thm bars get a bit of softener oem and glaze over the bars then wetness won;t be detected no more and the control won't know them thangs is wet or dry and most likely declare a No Joy.
Dec 10, 2010 | Dryers
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
It seems like the burners are not all lighting. Maytag Epic Z gas
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Haier washer/dryer combo not drying clothes
Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
UN-ending Auto dry cycle
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
Nov 10, 2008 | Dryers
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Open Questions:
Maytag PYG2300A Gas Dryer Logo
575 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
