Question about Acer Aspire One PC Notebook
Acer aspire m3-581TG replaced hdd with ssd but bios doesn't see it.
Bios will not recognise the new ssd in the PC. The drive which is new works OK in a docking station so the problem is related to the PC. The bios is pretty basic and there are no obvious settings that can be changed. Kevin
    New Friend:
  • 4 Answers
Will dude this notebook was build for hdd and trying to convert it into ssd has a lot of job to do and heck bios will really not be able to recognize it
Posted on Jan 05, 2013
3 Suggested Answers
drifterK
  • 4924 Answers
SOURCE: acer aspire one 1640Z XP BIOS RECOVERY WON'T READ USB WITH BIOS
if I understood correctly you have the recovery software loaded on a stick flash drive and you want to boot from usb to restore the pc .....There are a few things that you have to know about to do that ...
first you have to go to bios and enable boot from another device ....other than hdd /cd or flopy ... for some elder bios this isnt even a choice ..or ..if it is ,,it will be as a sub options into the hdd...choice ..
another thing that you have to keep in mind ..is that you have to disable the other options to force it boot from this one ...or ....to press f8 on boot and manually choose the usm or the stick name that will appear on boot devices...
the most important thing is that if you already formatted the hdd it does notr have a usb driver loaded and that why willl not see the device ...also the device you are using to boot ...has to be specially formatted to be bootable ....this is made ussualy with a hp format tool ...and it is explained in more than one places on the net ...just look for making a boot-able stick (usb device)
in short ...make sure the sticvk is boot-able ...second the pc ha s teh capability to boot from another device ...and this is a feature that you already enabled like first boot device ...
than things will be easy ...it will ask you to press any key to boot from the usb ...and continue like an installation from the cd ...
if you cannot do it ...I recommend using a cd ..or an image that you will ***** in a virtual cd ...for those that do not have cd drive ( use daemon tool )
Posted on Dec 21, 2009
rahimhd
  • 31 Answers
SOURCE: How to crack /unlock the password set on SATA HDD port 0 in CMOS on Acer Aspire-5050
Cheap solution available at http://www.acersnoop.co.cc
Posted on Jan 26, 2010
Trying to start computer with SSD and HDD, NOT happening!
Have you tried going into the bios to see if the ssd is recognized and have the computer boot from the ssd So connect the drive and put your windows disk in and install to the ssd During the install it will scan for drives and ask which drive you want to install on Make sure you check the boot options in the bios to allow the connect drive
Nov 23, 2012 | Computers & Internet
Replacing the hdd with ssd
Does your laptop's BIOS support SSDs? The BIOS of some older laptops won't work properly with solid-state drives. Unfortunately, there's no easy rule of thumb to follow in this regard, so before you buy, try doing a Web search for your PC model and "SSD compatible" to see if other users have had upgrade issues.
And if everything is fine then here the Video which can help you to Replace Hdd over SSd
Aug 07, 2012 | Computers & Internet
No Bootable Device
Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 25, 2012 | Acer Aspire One PC Notebook
Acer aspire one zg5 BIOS not recognising SSD
OK here we go, a little netbook with a Solid State Drive. Just a disaster waiting to happen and looks like it did.
Apr 23, 2012 | Computers & Internet
Hi i have an acer aspire one 523h-2588 and in the bios it says "IDE0 HDD Password is : Frozen" how can i get rid of it to use my laptop again cause it wont let me see my windows
Acer Aspire One BIOS Recovery The Acer Aspire One has a built-in BIOS recovery routine, which can boot into a minimal BIOS environment via a special boot block to re-flash the BIOS, even if the system does not pass POST and does otherwise not boot anymore. This procedure is also known as Crisis Disk.
First format an USB flash drive with FAT. It does not need to be bootable.
Download the latest BIOS, and extract all files. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the flash drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD before proceeding. It only works with this exact filename.
Turn the AA1 off, and verify both battery and AC adapter are plugged in.
Press Fn and Esc simultaneously, keep them pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press it once. The AA1 will now access the files on the flash drive and initiate flashing the BIOS. After a while the power button stops blinking, and the AA1 reboots by itself. Wait patiently.
If it doesn't reboot, but keeps blinking, wait at least a few minutes before turning it off, and try again.
Oct 06, 2011 | Acer Aspire One AO532H-2527 Netbook
Aspire 6930 it has bios password also a hdd password and i don't them help
I use http://www.unlockbiosrecovery.com/Unlock_Acer_HDD.php when I need to unlock an Acer HDD or Acer Bios, they only charge $20 and guarantee it. Repairing laptops I get one or two a month that is locked with bios password or hard drive password.and they have always worked unlocking them.
Jul 31, 2011 | Acer Aspire One Netbook
My hdd password in my acer aspire 1640.... i forget my hdd password help me how to find my hdd password... the three times I've been out to try my system disabled eto yung number 00 007 how to help me...
I use http://www.unlockbiosrecovery.com/Unlock_Acer_HDD.php when I need to unlock an Acer HDD or Acer Bios, they only charge $20 for bios master password and guarantee it.. Repairing laptops I get one or two a month that is locked with bios password or hard drive password.and they have always worked for me.
Jul 31, 2011 | Acer Aspire 1640Z Notebook
How can i get update for Bios
Hi there.
You can download the BIOS update from the Acer website here:
http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
Just select your make and model, then underneath that, select your Operating System. Then just click on the BIOS tab, then the orange icon to the left of the BIOS file.
Hope that helps.
Tim
Apr 24, 2009 | Acer Aspire 1640Z Notebook
Acer Aspire One  PC Notebook Logo
291 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
