Question about Brother IntelliFAX 2800 Laser Fax
Loud grinding noise when paper is feeding through machine
Noise seems to be from left side top of machine. Noise does not occur when receiving faxes and machine is printing these faxes. Grinding noise occurs when paper is fed through machine when faxing or copying. If you push down on key pad area on left side grinding noise sometimes disappears. Sounds like gear grinding. Can this machine be taken apart easily and gears replaced? Are replacement parts available on-line?
Thanks
Tom
  • DLNipper Jan 21, 2009
    Same, exact, problem here.
Mine was indeed a gear problem. Took off the top cover and poked around. Found two areas that may have caused the grinding.
1. The lower roller shaft had slid to the left out of it's groove. By removing the handset cradle (3 release tabs are accessed underneath the toner hatch.) I could loosen the "gear box" (a black contraption with all the gears inside) and then snug the bottom roller into proper position.
2. I removed the "gear box" to look around. Don't know if I dislodged one of the gears while doing so, but noticed one was dislodged ;-)
This required opening up the gear box by removing 2 screws and lifting off the motor. Then i could get at a gear that had come loose from a claw sort of piece. Note: the teeth of the loose gear needed to be on the motor side when sliding it back into the claw thingy. It seems to use a metal clip for friction control and perhaps proper spacing.
I noticed "some" wearing of gears, but doubt this is an issue. This machine has been used VERY hard for years and now, just by re-aligning things, it works once again.
My googling barely found any mention of troubleshooting this machine, so I shudder to think what finding parts would be like.
Posted on Jan 21, 2009
When receiving large faxes, it prints a blank page (numbered in succession though on the top as __ of __) in between each page of the fax. How do I stop this?Canon LaserClass 9500 -- When receiving l
What size paper is set as default on your end? If legal size, that may be why. Also- how quiet is the telephone line? If it is getting interference from a close proximity flouorescent light, or just noisy, it may be the noise being interpretted as a new page break.
If it is set up to autoselect the page size, look at noise as a possibility. If it is only a random occurance, it may be as simple as the paper itself sticking together slightly, (if it sticks together on the other end, there is not much you can do about that.) or the pickup feed may need the rubber tires cleaned.
If it only happens from one or two numbers and not others, it is likely line noise on either end. On your end, you can install some ferrite beads to reduce it, if on the other end, they will need to do it.
Apr 11, 2012 | Canon Office Equipment & Supplies
KX-FLB756 Grinding Noise, Unable To Print
if you have driver for this printer pls. install
thanks
alamri
Dec 24, 2011 | Panasonic KX-FLB756 Plain Paper Laser Fax
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
PAPER JAM
If you pull the drum out of the machine. Close front cover. is the noise still there. If it is then you have a broken fuser gear. If noise is not there remove the toner cart. from drum reinstall the drum unit in machine see if noise is there. if noise is there then it will be the drum. If not reinstall the toner try that if noise comes back then it is your toner cart.
Apr 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Sharp FO 6700 Plain Paper Laser Fax
No there is no configuration page. The red blinking light means you have no paper under your blue tray or the paper empty sensor is broke. To identify the noise open the lid then close it, if you hear the noise while the fax is warming up then most likely you have a bad gear that meshes with the fuser drive gear, although it could also be the toner or drum. If it's not the toner or drum I stongly recommend a service technician , he should be able to provide an exit tray.
Oct 05, 2008 | Sharp FO 6700 Plain Paper Laser Fax
GRINDING NOISE or PAPER JAM
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
Apr 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Outgoing fax makes loud clicking noise
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
Oct 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Receiving faxes but a weird noise
GO TO RICOH REPRESENATTIVE...TO FIX THE PROBLEM
May 31, 2007 | Ricoh FAX2050L Plain Paper Laser
Gears grinding with Brother Intellifax 4100
Does it only make the noise when printing. Do you hear the noise when sending out faxes? I have heard grinding noises onlt when using poor quality toner refills, or the fuser gear and or drive gear asm is stripped. First try a known good OEM toner.
Mar 22, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
246 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
