Question about Reliance & LP Gas Water Heater Control
Reliance 606 propane pilot won't stay on when i begin to turn on.its like ite not getting the message or signal,HELP PLEASE
  • Reliance Master
  • 5,089 Answers
1) Reliance is AO Smith-American, and air intake screen located on bottom of water heater. Clean air intake. Replace thermocouple. First two digits of serial number are year of manufacture.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-replace-thermocouple.html
2) Add comment and say what you tried so far.
Include age of water heater.
Posted on Jan 05, 2013
  • 582 Answers
SOURCE: Describe your Reliance & 30 Gal LP
TURN OFF THE GAS VALVE AND WATER TO THE TANK REMOVE THE PIPES FOR THE DRAFT USE A SHOP VAC AND CLEAN THE DIRT AND DUST FROM THE INSIDE OF THE DUCT WORK ALSO WHERE THE BURNER IS LOCATED YOU CAN VACUME THERE ALSO AND REINSTALL THE DUCT TO THE FLUE
Posted on Aug 23, 2009
  • 409 Answers
SOURCE: my reliance 606 hot water tank pilot wont stay on
You need to replace the thermocouple. It unscrews from the thermostat on one end, and the other one hooks in a bracket. After replacment make sure the thermocouple bulb is in the pilot flame.
Posted on Apr 09, 2010
SOURCE: Pilot won't stay lit in Reliance 606 gas water heater
The Reliance 606 has an enclosed thermal couple. Before you try taking that assembly apart take a wire brush to the bottom opening directly under the burner. There is a metal filter on the very bottom of the water heater. It could be that the filter has gotten filled with dust or animal hair. It took a serviceman 2 days to figure this out for me. The water heater has to have good airflow through that filter to work well.
Posted on Sep 29, 2010
  • 494 Answers
SOURCE: My pilot light goes out irregularly it's a
If you still have your owner's manual, you will need to call the manufacturer. They will need the model # & serial #. This particular brand has a fine mesh filter screen on the bottom (below the burner) that gets clogged and causes irregular pilot outages. They have a recall in which they will send you a new burner assembly with a reset switch built-in to it. They will send it to you for free, but you will need to hire your local propane co (at your expense) to install it and also clean the filter while they have the burner assembly out. Good luck. Douglas
Posted on Jan 06, 2011
SOURCE: Reliance 606 natural gas water heater - model
If I understand correctly, the pilot light is not staying lit.
You light the pilot and water in the tank reaches temperature.
Once hot water is gone, then pilot light has to be lit again.
Gas pressure is good, and gas is flowing.
Thermostat is working at high end because it cuts off heating.
Vent is working because tank heats up.
Air intake is working.
Gas control thermostat might not be reading low temperature. Replace gas control valve.
Pilot tube might be dirty. Clean burner parts and combustion chamber, and air intake, and vent.
Backdraft might be blowing out pilot. Check for constant updraft by running water heater 5 minutes, and then light match under vent hood and see if smoke goes up.
Very hot air can put out pilot, especially when water heater located in attic. Add ventilation.
Improper vent might have water dripping back down into combustion chamber and putting out pilot light and rusting out the parts. Inspect for rusted parts and water.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
Posted on Aug 10, 2011
Hot water tank wont heat water, how do you relight or resat, its a reliance self cleaning 808
Reliance Water Heater Literature ' Owner's Manuals ...
www.reliancewaterheaters.com/resources/instruction-manuals
Welcome to the Reliance Water Heaters Owner's Manual and Installation ... 9 40 EKRT - 40 Gallon Tall Self-Cleaning Electric Water Heater - 9 Year Warranty . ..... 10 50 DHPST - 50 Gallon Electric Heat Pump Water Heater - 10 Year Warranty .
How to light the pilot on a Reliance 606 water heater ...
? 3:27
https://www.youtube.com/watch?v=VU2PsFVd2ug
Jul 12, 2011 - Uploaded by kilroywashere123
How to light the pilot on a Reliance 606 water heater ... How to fixwater heater, will not stay lit - sealed combustion no hot water - Duration: ...
Reliance Water Heaters - Consumer Affairs
www.consumeraffairs.com > Homeowners > Bath & Plumbing
Rating: 1.6 - ‎84 votes
I purchased a Reliance 606 water heater in 2010. ... That they don't TELL you there's areset button or that I'm having conspiracy thoughts ... After several attempts, I was able to relight it. ... It's heading to the junk pile and I will purchase a new reliable (NotReliance) ... Checked breaker and changed breaker still no hot water!
Dec 28, 2015 | Reliance Water Heaters
What pilot light assy. do I need to buy for model# 640y0rt4, water heater ??? please wont stay lit
check that the flame sensor is clean. It would be a stiff piece of wire that would sit right over where the pilot lite is. If it is dirty...it wont sense if there is a flame....and if it dosnt sense a flame....it wont let the pilot lite to turn on.
Jun 03, 2015 | Reliance 606 Series 40 Gallon Natural Gas...
Reliance 606 Hot water Heating element (Pilot light) won't stay lit
Gas water heaters don't have elements, so I am confused about what type water heater you have..
Look on the side of tank for the label.
Find the brand, and type. Does it show BTUs? Or does it show wattage?
Then re-post question with this information, for best possible answer.
Also post question on Tank forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Aug 12, 2012 | Water Heaters
My pilot light goes out irregularly it's a reliance 606 propane water heater
Oct 01, 2010 | Reliance Water Heater #6-50-DJRT 50GAL...
Model 640HORT Reliance 606 40 gal LPgas came to cabin, water cold, lit; ran for 4 hours, flame went out, burner won't come on.
It does sound like a weak pilot thermocouple. Change the thermocouple first. Make sure you have an adequate supply of propane serving the water heater. If it still works for a while then completely shuts down, you will need to replace the control valve. Call Reliance and see if the unit is still under warranty, you may be able to get free parts.
Sep 11, 2010 | Reliance & LP Gas Water Heater Control
My reliance 606 hot water tank pilot wont stay on soon i release it it goes out and no hot water what do i need to do to solve the prolem myself?
Apr 08, 2010 | Reliance & 40 Gal Electric Mobile Home...
Feb 13, 2010 | Reliance & 50gal Electric Water Heater
Reliance & LP Gas Water Heater Control  Logo
564 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
