Question about Symbol MC3090
MC3090 device (with Wondows CE 5.0) is not connecting to PC (Windows 7 - 32 bit) via Windows Mobile Device Center
Active sync
Depending on your OS, you'll need Windows Mobile Device Center 32-bit or 64-bit. ActiveSync is for Windows XP machines;
Microsoft Windows Mobile Device Center 6 1 for Windows Vista 32 bit
Windows Mobile Device Center 6 1 Driver for Windows Vista 64 bit
Thanks
Jay
Sep 29, 2013 | Symbol MC70
When i connect the samsung ping to my computer via USB 2.0 the phone asks for Pc Suite or mass storage but everytime i pick any of them it just says its connected but nothing comes up on the computer so...
  • If Windows Live OneCare is installed on your machine, it may be blocking the device connectivity. Please click here for the steps to configure Windows Live OneCare to allow the device to connect.
  • The driver installation may not have completed successfully. If you think this may be the case, follow these steps:
    1. Keep your device connected
    2. From the desktop, go to Start > Start Search
    3. Enter "Device Manager" or "devmgmt.msc" to launch the Device Manager window
    4. Look under the "Network adapters" node for "Microsoft Windows Mobile Remote Adapter". If this is not present, skip to step 5. Otherwise, right-click "Microsoft Windows Mobile Remote Adapter" and choose to "Uninstall"
    5. Look under the "Mobile Devices" node for "Microsoft USB Sync". If this is not present, skip to step 6. Otherwise, right-click "Microsoft USB Sync" and choose to "Uninstall"
    6. Disconnect and reconnect your device. Your device driver will re-install and Windows Mobile Device Center will launch.
Jun 05, 2011 | Computers & Internet
I have datalogic memor scanner. i can't connect to Windows mobile device center in Windows7. also it's driver does not work
Dear Original Asker,
Unfortunately, the older Datalogic Memor devices, which I believe your model is by the issue; model (Windows CE 6.x), can't support, and doesn't have drivers that work with Windows 7. You need Windows 6 (Vista) to use the device. In other words: all software support for the device with that firmware was dropped with the advent of Windows 7.
Solution: Update the firmware on the Memor via a Windows Vista PC, then connect the device to a Windows 7 PC.
Nathaniel Sherman
STLCC - 2012 Mathematics
MS&T - 2014 BS-CE/EE
Oct 10, 2010 | Datalogic Memor Smartphone
Window Vista syncronizing with iPAQ 3835 problem
In order to sync any iPAQ with Windows Vista, you will need to download and install Windows Mobile Device Center 6.1 from http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx.
Activesync will only work for XP Operating Systems and earlier.
Notes
  • To find out whether your version of Windows Vista or Windows 7 is 32-bit or 64-bit, click Start, right-click Computer, and then click Properties. The version is listed after System Type.
  • You can use Windows Mobile Device Center 6.1 only with phones running Windows Mobile 2003 or later. ActiveSync and Windows Mobile Device Center won’t work with Windows Embedded CE 4.2 or 5.0, Pocket PC 2002, or Smartphone 2002 devices. (To see which Windows Mobile operating system you’re using, and if your phone doesn’t have a touch screen, click Start > Settings > About. If your phone has a touch screen, click Start > Settings > System tab > About.) To sync content to any of these devices, you must use a USB or serial cable and your computer’s Internet connection and File Explorer.
  • You must use Microsoft Outlook 2002, Outlook 2003, or Office Outlook 2007 to sync your e-mail, contacts, tasks, and notes from your computer.
  • You must use a USB cable to connect your phone to your computer the first time you use Windows Mobile Device Center to sync.
Jan 11, 2010 | HP iPAQ H3835 Pocket PC
How i can sync my Ipaq h3955 with my pc win xp
In order to sync your iPAQ with Windows XP or earlier, you will need to download and install Windows Microsoft ActiveSync 4.5 from:http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/activesync-download.mspx.
Notes:
You can use ActiveSync 4.5 only with phones that run Windows Mobile 2003 or later versions. ActiveSync and Windows Mobile Device Center won’t work with Windows Embedded CE 4.2 or 5.0, Pocket PC 2002, or Smartphone 2002 phones. (To see which Windows Mobile operating system you’re using, if your phone doesn’t have a touch screen, click Start > Settings > About. If your phone has a touch screen, click Start > Settings > System tab > About.) To sync information to any of these phones, you must use a USB or serial cable and your computer’s Internet connection and File Explorer.
Download and install ActiveSync:
1. Click the download link on this page, and then click Continue.
2. Select whether you want to register for the Windows Mobile newsletter, and then click Continue.
3. Click Download files below, and then click Download (next to the Setup.msi file).
4. In the File Download dialog box, click Run.
5. Follow the instructions in the Installation Wizard to install ActiveSync.
Note: You must use a USB cable to connect your phone to your computer the first time you use ActiveSync to synchronize information.
Jan 10, 2010 | Compaq iPAQ H3955 Pocket PC
I have a Ipaq 2200 version 4.2 2003 will it active sync with windows7
In order to sync your iPAQ with Windows Vista or Windows 7, you will need to download and install Windows Mobile Device Center 6.1 from http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx.
Notes
Dec 30, 2009 | i-mate Pocket PC
Wabt to Sync an SPV M3100 on Win Mob 5 with Win
Download the Windows Mobile Device Center from vista site but make sure you pick the right version (i-e 32 bit version or 64 bit version) to check that do as follow;
Right Click -> My Computer -> Properties
Then look for "System Type" if it says "32-bit Operating System" then choose "32-bit version" else choose "64-bit version".
After installing the "Windows Mobile Device Center" connect your mobile with pc via usb cabel and it should connect.
If it doesn't connects on mobile open "ActiveSync" then choose "menu" then "options" and click the small icon of the pc and press "delete" repeat untill there is no icon left. After that reboot your mobile and connect to your pc and it should connect now.
If you have any other questions please feel free to contact...
Sep 23, 2009 | Orange SPV M3100 Smartphone
I'm running Vista and I'm having trouble with my HX2415.I have Windows Mobile Device Center Installed. When I plug the unit into a USB port it doesn't find the hardware. It worked fine on XP with Active...
Hi
Thanks for using FixYa. HP ipaq HX2415 is compatible with Windows Vista Mobile Device center Version 6.1. Please check if you are using version 6.1, you can download the Windows Vista Mobile Device center Version 6.1 from this link--
Windows Vista Mobile Device center Version 6.1 Link
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 07, 2009 | HP iPAQ HX2415 Pocket PC
Symbol MC3090 Logo
62 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
