Question about Lenovo IdeaPad Z560 Notebook
My lenovo ideapad z560 is stuck at splash screen and not taking any of keyboard inputs.....also on keep pressing any key it start making beeping noise.........what to do??
leecom72
  • 4806 Answers
SOURCE: new lenovo N500 laptop keyboard not working just noise
The N500 has a row of touch sensitive buttons above the keyboard, toward the right side of the computer. If you have accidentally press one of those buttons you may have disabled the keyboard, try pressing one of those buttons to activate the keyboard again.
Good luck.
Posted on Jul 01, 2009
rubydu
  • 102 Answers
SOURCE: keyboard is not working
show it to the service centre it is in warrenty it is the problem of motherboard
Posted on Jul 21, 2009
elix0411
  • 3530 Answers
SOURCE: IdeaPad S10e Netbook: CANT OPEN LENOVO ONE KEY RECOVERY UPON START...
Make sure you did it correctly. Computer should be OFF when doing the one key recovery. Turn off the computer then press the small button right beside the power button. Your computer should automatically turned on and you will go straight to one key recovery software. If this will not happen, then the one key recovery is destroyed. We need to re-image your Harddrive to have that one key recovery software back to you computer. You may call Lenovo technical support department for further assistance on how you are going to send your laptop to our depot department.
Posted on May 30, 2010
SOURCE: Lenovo Ideapad Y510 won't turn on or off
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
Posted on Jun 24, 2010
elix0411
  • 3530 Answers
SOURCE: My Lenovo ideapad s10-3t web
Welcome to Fixya
Go to control panel and click system icon. Got to device manager and see if webcam is detected by your computer. Reinstall the driver of your webcam by going to lenovo site.
Your response will be highly appreciated.
Thank you for using Fixya!
Posted on Jan 19, 2011
Funtional keys are not working in lenovo
Function keys on many laptops are used as the secondary set and the individual functions of the keys have been shifted to the primary functions. Thus, if you press F1 and things are normal, you would get some kind of "help" But if, as in many laptops, the functions of those "F" keys has been reversed you might get an Internet key, a brightness key, some kind of CD opening key, or whatever the manufacture decided. F2, as another instance, is used to trigger "edit" of the current item....but in many laptops pressing F2 just turns off your wireless signal or dims the screen slightly. In those cases the way to access the expected Fkey functions is to hole the Fn key down (at the bottom left of the keyboard) then press the desired F key. Personally I find it nuts to have reversed an PC age old way but I'm not in charge of keeping people happy so it's not happening.
Hope that helps.
Dec 18, 2014 | Lenovo IdeaPad Z560 Laptop
Bios
Anything on the screen? This is usually a sign of sticking keys on the keyboard. You can check to see if any are stuckl, if you cannot tell then you should start taking things out of the computer to see if it stops. Tale out the hard drive, and cd drive that is present, then you may have to remove the keyboard to see if it is bad.
Jul 23, 2013 | Lenovo IdeaPad Z560 Notebook
Lenovo z560 automutes
Launchboard is the panel with buttons situated over your keyboard. If some kind of conductive dirt, fluid or water came inthere, it will short out the keys and "press" them giving you that problem. Try to clean the board with alcohol.
Jan 01, 2013 | Lenovo IdeaPad Z560 Notebook
Lenovo keyboard typing q continusly
get a flat head screw driver ,, its also called a blade type,, a small one..
stick it under the q key and gently pry up..
if the q continues pry till the key pops off.
the q will stop.. use a cotton towel and clean the contacts of the q key and on the board.. firmly press the q key back into its position..
your done.
ps. hopefully the key wasn't broken and the contacts dropped causing the q to be continuously active.
Dec 28, 2012 | Lenovo IdeaPad Z560 Notebook
Ideapad Z560 neither accessing BIOS setup or is starting normally
Your bios seems corrupted. You will probably need to reflash from a thumb drive which is bootable. The F2 should get you to booting screen to access the thumb drive to boot from to flash the bios.
Dec 23, 2012 | Lenovo IdeaPad Z560 Notebook
Nvidia driver not intstal in ideapad Z560 in Windows XP
Try to download again. delete corrupt file. Perhaps it was a "Hiccup" By the way you have a Lenovo IdeaPad Z560 didn't that come with Windows 7 64bit? Did you downgrade to Win XP SP2?
Nov 04, 2012 | Lenovo IdeaPad Z560 Notebook
I purchased a lenovo z560 laptop last month, but its F12 key's lock is broken, is there any way to overcome this problem. I am very confused please suggest any help .....
If you are interested you can use external mini usb keyboard.
If possible call to lenovo call center and ask for replacement of key board.
Jul 04, 2011 | Lenovo IdeaPad Z560 Notebook
I bought a lenovo ideapad z560 for my sister in march and she tells me that several keys in the keyboard stop working. Is that a software problem? or a hardware? what can be done?
Welcome to Fixya
It could be software problem. Try to restore the computer back to the factory state. Turn off the computer then press the small button located beside the power button then follow to on-screen instruction to restore it from initial state. By doing this, we will now clear any software issue in the computer since it will be restored from the date it was purchased. If same thing will happen after restoreation then you need to send in the computer to depot repair depatment for keyboard replacement. I believe the computer is still under warranty. You may call 18774536686 then press option 2 for hardware support/repair.
May 01, 2011 | Lenovo IdeaPad Z560 Laptop Computer -...
I CAN'T DETECT OPTION TO START WEBCAM FOR LENOVOZ560
Make sure you download the latest version of the driver on the website of lenovo. Click here to download. Make sure to select the Family and the model of your unit then select the operating system. After you install the driver press FN + ESC on your keyboard to enable the webcam
Thanks for using Fixya.
Jan 26, 2011 | Lenovo IdeaPad Z560(0914-3NU) NoteBook...
Lenovo IdeaPad Z560 Notebook Logo
50 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
