Question about Samsung SGH-E900 Cellular Phone
My Usb and Pc are not adapting properly
When i put my usb in the computer and try the Samsung Pc Suite the pc suite does not work, i have uninstalled and reinstalled and it still says runtime needed and carr error. what do i need to do to make it work?
  • 50 Answers
Try to replace the cable with another
Posted on Jun 28, 2007
SOURCE:
How can i send a application from computer to may cell phone unit samsung gt-b7320
Hi
You need a USB data cable and samsung PC suite software to be able to connect with your computer. Once you install the samsung PC suite, use the USB cable to connect or transfer data.
Mar 05, 2011 | Samsung Computers & Internet
My samsung sgh m-200 mobile problem 1Chalte Chalte hang ho jata hai.2. auto restart hota rahta hai.plz solv my problems thanks
For this you need to scan your handset and memory from a updated antivirus
if problem persists you need to flash your phone
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps) *Software Updater
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE *Install the "Software Updater" *Select Update**....(It takes 10-30 Mins)
Thank don't forget to rate
Jan 28, 2011 | Samsung Cell Phones
I got the Samsung A877 Impression and i wanted to know how to put music from my computer on it ... it came with a usb cord but that doesnt seem to want to work with my computer so what do i do ???
you can copy music files in two ways:
1) Send via USB
a) Install the Samsung PC Suite (driver) in your PC/Laptop.
b) Connect the device with the PC/Laptop via the USB cable got.
The PC suite will act as an interface for connecting the mobile to the PC. Use original USB cable for faster & efficient data transfer.
c) The PC suite will give an interface for copying the music files to the mobile, Or, you can directly copy files by accessing the extra drive shown on the MyComputer which denotes the mobile device's memory.
2) Send via Bluetooth
If you have an active bluetooth device available in your PC/Laptop then just send files to the mobile after searching the mobile.
Regards
Vineeth K.
Aug 05, 2010 | Samsung Cell Phones
Samsung C3060R driver fo Windows 7
uninstall again your pc studio, restart you laptop and reinstall your pc suite, but before you do install it, try to do this trick, right click the pc studio, select properties, then select run in compatability mode of xp and vista, then select run as administrator, select apply and ok. it will install, there are times that windows 7 will inform you that the program not installed, you will be having two options, select, '' install the program with recommended settings''.
once installed, connect your phone to your laptop, select settings on you pc suite, select connections, select usb, this will command the pc suite to search for phones attached to usb ports. once searched, it will install your phone automatically and will look for appropriate device drivers for your phone through your pc suite, once connected you are set.
if this doesn't fix your problem, try updating you device through device manager, direct your device installation by browsing the folder to your samsung pc suite and unchecking the automatically install the best driver and checking the box for include the drivers on this folder.
regards.
Mar 06, 2010 | Cell Phones
A Samsung PC Suite or Similar for MAC computers
Samsung does not support the Mac OS with its apps (9/X). If you want to transfer files to your d980, you can do it via Bluetooth (assuming you have a newer Mac with Bluetooth built in -and your phone has bluetooth- or else a USB adapter will do).
Jan 28, 2010 | Samsung SGH-D980 Cell Phone
The exact same problem!
ok, if the suite was a legitimate non-virus software, then go to Program Files and find the folder for the PC suite. There should be something like uninstall.exe in the folder.
Sep 01, 2009 | ASUS Eee PC 1000H Laptop
I am having nokia n95 i want to connect my mobile to computer through internet via mobile office and i also having latest pc suit .7 but having problem 1- nokia connectivity cable driver software2-survice...
firstly take proper mo settings start ur internet service then insatll pc suite in computer check ur usb cable is proper or not then make a dial up connection with *99# dail code ur work is done...
Jan 31, 2009 | Nokia N95 Cellular Phone
Can't sync my P1i
If you experience problems when using the USB cable during synchronisation:
  1. Check that the USB cable is properly connected to the phone and the computer.
  2. Make sure the phone is turned on.
  3. Restart the computer, without disconnecting the USB cable or turning off the phone, and try to synchronise again.
  4. If you still experience problems using synchronisation software, e.g. Sony Ericsson PC Suite or Active Sync, try to uninstall and reinstall the program you are using.
this might be the case. if not enable active sync on phne
good luck
Jan 16, 2009 | Sony Ericsson Cell Phones
Nokia 6233 GPRS connctivity through USB blue tooth dongle and Nokia PC suite
There is some problem in your Bluetooth device driver. Try to uninstall it and restart your Pc then reinstall it.
Oct 05, 2008 | Nokia 6233 Cellular Phone
Unable to connect to PC
I would suggest getting your socket checked
Jun 24, 2007 | Nokia 6288 Cellular Phone
Samsung SGH-E900 Cellular Phone Logo
35 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
