Big screen TV corners of tv blue and red
I have a big screen tv probably about 4 or 5 years old, the picture is super screwed up now.. the left side is stretched with red and the right is stretched with blue.. If there are words on the screen they are in like.. .double with a green layout or somethine.. please help...
  • brianbuy May 11, 2010
    whta make and model tv do you have ? does your problem look like a 3 d image ?
I HAVE A 57" TOSHIBA REAR PROJECTION TV. HALF THE SCREEN HAS A BLUE TINT AND THE OTHER HALF IS CLEAR.
Posted on Jan 14, 2010
IF U MEAN THAT YOUR TV IS A REAR PROJECTION TV, THAN U NEED TO ENTER IN TO MENU SELECTION AND SELECT CONVERGNCE ALIGNMENT & ADJUST, IF STILL THE SAME THAN U NEED TO REPLACE THE CONVERGNCE AMP MODULE
Posted on Jan 20, 2009
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Apr 08, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Dynex big screen tv stopped working won't come on with the remote of the botton. Only a little over a year old
The same exact thing just happened to me. I was watching tv and it just turned off by itself and now it wont turn back on. I've also only had mine a little over a year. The red light is on at the bottom left hand corner, but it wont turn on at all. Hopefully we can find an answer to what is going on!
May 21, 2010 | Protron PLTV3250 32 in. LCD Television
How much would it cost me to replace the picture tube for rca big tv screen that i got it for free ? where do i buy it at ?
A CRT (picture tube) for an RCA projection TV will cost $300-400 If the TV is more than 4-5 years old, you'll likely have to replace all 3 CRTs to obtain a watchable picture. Its probably not a good idea to spend that kind of money on a "free" TV.
michtech
Feb 18, 2009 | Sony KP-57HW40 57" Rear Projection...
Convergence problem and cropped picture
your tv is under convergence problem usually we need to replace 2 big integrated circuits in the convergence section, at this point you may need a good tech to come over to your home
Nov 13, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
Sep 25, 2008 | Samsung HCM4216W 42" Rear Projection...
Error Code 5 flashes when unit shuts down
Good Day;
It sounds like the TV may have a shorted CRT, picture tube, but let's trouble shoot:
1. Unplug TV from wall.
2. Remove speaker grill, two on bottom, the screws are covered with plastic caps, right and left side on bottom next to floor.
3. Remove inner panel.
4. The blue tube is the one the right side, remove socket, with phillips driver, make sure it's not touching anything.
5. Plug and turn TV back on, if picture appears with no blue it's the tube.
6. If still shuts down, bad blue CRT driver IC.
CAUTION: Call a factory authorized service dealer to give you an estimate, if this sounds too hard.
Good Luck, Day, Big Irish.
Jun 18, 2008 | Sony KP-51WS510 51" Rear Projection...
Hitachi 53fdx01b top-left corner is now duplicating picture
tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
Jun 01, 2008 | Hitachi 43FDX01B TV
Samsung HP-R4252 42 in. HDTV screen black outs and red lines
Hi: We had this problem under warranty, and tech installed the following to solve it: Parts BN96-02033A, BN96-02034A and BN96-02216A. This solved the problem for 2 years. I now have the upper half going black now and then for 2 to 3 seconds. I am ordering these parts from www.partstore.com and will just plug them in. Better than a new tv.
May 25, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Screen problem blue area in the corner
remove any big speakers that are close to the tv
Dec 17, 2007 | Televison & Video
Televison & Video Logo
303 people viewed this question
Top Televison & Video Experts
Electro Med Services...
