Question about Maytag 7.0 Cu. Ft. Electric Dryer
DRYER NOT PUTTING OUT HEAT
I HAVE A WHIRLPOOL ELECTRIC DRYER MODEL #SEDS800JQO I HAVE CHECKED CONTINUITY ON THE HEATING ELEMENT AND THERMO FUSE AND APPEARS TO BE GOOD BUT I'M STILL GETTING NO HEAT, DRYER TURN JUST DOES NOT HEAT AND BLOWES AIR THROUGH THE DUCT. WHAT ELES COULD IT BE?
THANKS FOR ANY SUGGESTIONS,
XAVIER
quirozx@pella.com
Check the thermostats and thermo sensors. You might also try the dryer on different cycles and see if it heats on some cycles and not others, it may be your timer
Posted on Jan 19, 2009
    President:
  • 1,214 Answers
If you can find the wiring diagram inside the rear service panel of the appliance, follow the circuit to identify the overload sensors. There are several internal temperature sensors in the heater circuit that could be open.
Also check that the vent duct, all the way out to the discharge grill outside of the house, is not partially restricting the airflow. Note the same for the lint filter on top as well. Any restriction to airflow will cause poor or no heating problems.
Check for a good discharge of air with everything hooked up, outside where the dryer vent discharges, while the dryer is operating.
Plase feel free to reply your findings, and if you have any additional questions.
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
My dryer whirlpool still blow cool air but do not heat please tell me what the problem henry le
Bad heating element or bad thermo fuse.
You will have to unplug the dryer and remove the back to access the heating element. The thermo fuse is located on the side of the heating element.
If you don't have a meter to test the element and thermo fuse or just don't know how simply remove them from the dryer and take them to your local appliance repair shop and they can test them for you.
Aug 03, 2011 | Whirlpool LER4600 Electric Dryer
Whirlpool Dryer LEB6200KQ0 - Issue will not heat. Have checked Power, Getting 220 volts (110 on each line at dryer) Checked Heating Element. Have continuity. Checked Thermal Link. Have...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 06, 2011 | Dryers
Doesnt heat thermostat was replaced and fuse replaced still doesnt heat
What is the model number of the dryer? I did not see where you checked the "heating element" on the dryer. Check the element for continuity.
Dec 30, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Dryer drum turns but no heat is produced.
If this is an electric dryer, unplug, remove the back, and remove the heating element. Check for continuity. There is also a fuse, and a thermo fuse that need to be checked for continuity. If any is bad, replace (get parts from local appliance parts shop). If all is well with the parts, check to see that your 220 is OK. Check the breaker box (switch breaker off and then back on) and see if that fixes the problem. Some electric dryers motors can run but not have the correct electrical leg to run the heating element.
Good luck
Dec 30, 2009 | Whirlpool Dryers
Ihave a kirkland signature dryer model#seds800jqo dryer runs but
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 23, 2009 | GE Profile DPXH46EA Electric Dryer
Whirlpool Dryer Does not dry
Its the thermal fuse. when you jump or, by-pass the cycle thermostat, you are basically by-passing the fuse as well. replacing the thermal fuse will fix thsi issue.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
NO HEAT
Check for 220 volts incoming at the terminal block where your cord connects.
Make certain the dryer wiring is good there also.
Check the heating element to a ground on the dryer.
Check the continuity tthrough the start switch on the motor.
for the heater wire connection.
Mar 09, 2009 | Whirlpool LER4634J Electric Dryer
My whirlpool electric dryer runs but doesn't heat up
That' a very common symptom for a bad (open) heating element.
May or may not be DIY job to replace it. Would have to look at the manual.
Jan 25, 2009 | Whirlpool LER4634J Electric Dryer
Maytag 7.0 Cu. Ft. Electric Dryer Logo
265 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
