Question about Coffee Makers & Espresso Machines
Delonghi magnifica won't suck up milk - Coffee Makers & Espresso Machines
5 Suggested Answers
mattofilms
  • 110 Answers
SOURCE: my delonghi magnifica is having a problem with
There are 'o' rings on the pipes (on machine - not milk container) where the milk container fits into. replace or clean them - should work like new.
Posted on Jul 02, 2009
SOURCE: Delonghi Magnifica Coffee Maker the milk is not
You did not state anything about descaling, but every now and then, I also add water and descaler to the milk container and use the "Frothing" program to run through the water and descaling-solution (double-click the Cappuchino button).
I have also noticed that the first cup (and sometimes even the second) will produce less milk, and not as well frothed milk as later cups. My theory is that the machine is warmer when producing later cups.
If possible, you could try to run two-three frothings of plain water through before switching to milk. I realize this is inconvenient, but it could be worth testing this to see if it helps. We luckily have two milk containers and keep one filled with water just for the purpose of heating up (or whatever we do :) the frothing system before serving the first cappuchino.
Posted on Oct 08, 2009
SOURCE: I have a Delonghi Magnifica
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
Posted on Jan 10, 2010
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Posted on Jul 08, 2010
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
www.coffeeforums.com/.../9427-wits-end-delonghi-magnifica-steam-fun...
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya
www.fixya.com > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Magnifica ESAM 3500 milk temperature low
This is factory preset and cannot be altered. You do need to use the "clean" function on the milk frother unit to ensure the boiler and pipes heat up enough also.
May 15, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi coffee machine ecam23. Milk comes out of jug when turning machine on and milk also comes out after the water when cleaning the spout on the jug.
I think the ECAM has a second solenoid at the front near the milk jug. That solenoid valve might be stuck open.
>> service agent
Oct 17, 2013 | DeLonghi Esclusivo Magnifica ESAM3300...
Milk is not being sucked up from container for frothing. It is sucked intermittantly; usually becoming less at the end of the cycle; sometimes not sicking at all. O rings have been cleaned; so has the...
Do you also find the milk seems to be warm rather than hot?
If so the main water heater is not working correctly (there are two in most Delonghi machines like this). The horse-shoe shaped one is the one used by the milk frothier.
In many cases it is the thermal sensor that is faulty (open circuit). Normally at room temperature they should measure 120K ohms in resistance. These can become intermittently faulty so you need to measure the resistance when the fault actually occurs so is not an easy job if you have no technical training.
Apr 20, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Magnifier doesn't get enough steam to warm milk or froth milk
sounds like you need it stripped down and serviced ... bsc appliances bristol 07779933829 postal service too.fully trained by delonghi.
Feb 16, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Magnifica 3500 not frothing
use cold low fat milk and keep the milk container in the frig.
Make certain that when washing water come out of both holes.
Jul 09, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
My delonghi magnifica is having a problem with milk..steam is coming through but no milk..can you suggest what the problem may be?
Jun 21, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Coffee Makers & Espresso Machines Logo
88 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
