Question about Dometic Heating & Cooling
Clausen Optiduel Duelmax Air Conditioner and heater manual
Came with incorrect water hose external, need manual what parts come stock with this model i bought mine second hand cheers
SOURCE: Danby air conditioner model #DPAC10060(R)
here is the manual link: http://www.danby.ca/manuals/DPAC8020.pdf
Posted on Jun 15, 2007
SOURCE: Water spillage in Dimplex portable air conditioner
Hi Leanne,Bung stays in and you dont take it out until the red light (4th on right on top of unit) comes on, then you empty it taking bung out and use tube to get the water out. It will probably take some time (days of continuous operation) for the light to come on, depending on your humidity etc. For easy emptying, wheel the unit to a bathroom or outside where if it spills a bit it won't matter.
Ours is working okay although it just stopped blowing cold air and is only blowing room temp air. we have guests tonight and its hot! I came here looking for a solution to my prob and found yours!
chhers, Les.
Posted on Jan 08, 2008
yalmer
  • 552 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
gtmerkley
  • 190 Answers
SOURCE: I have a Maytag window air conditioner that is leaking out front
The unit has to lean backward to let the water run out. It sounds like it is too level or leaning forward too much. There should be an adjusting screw in back that you can lower and it should work fine.
Posted on Jun 27, 2009
SOURCE: i need parts for everstar portable air conditioner
I have lost the exaust tube and the attachment that hooks up to the back of the unit to the tube. Where can I buy these parts?
Posted on Jul 19, 2009
Where can in get a set of exhaust/intake hoses for a danby dpac120068 air conditioner
Is there a reason not to just go to the Danby site? Support Danby includes phone support, email and "Find Parts" Even if their source is out you should at least be able to find the correct part number, then Google Danby (part number).
You could also look to see if generic flexible vinyl tubing/hose can be substituted. It's doubtful that Danby created their own hoses.
Jun 09, 2016 | Danby Heating & Cooling
I have a homebase air conditioner 275937 and no intructions, where is the water out let, is it a hose fitted to the plug or a internal fitting to
I was also unable to find a manual through any of my many searches, however either of these two links may provide some general, generic assistance, given similar items. Hopefully you may find something useful:
1) This website includes numerous general info articles. Link to Article Library & Buying Guides (for similar items):
http://www.air-conditioner-home.com/portable-ac-library/
2) YouTube video - Portable Air Conditioner from Air-Conditioner-Home.com:
https://www.youtube.com/watch?v=LRDihKbdrwc
Aug 20, 2014 | Heating & Cooling
Hello, I need the hose to drain water outside that fits the fridgidair portable air conditioner #FAPO9EP1Z1. Is there another small tube or is there any other hoses or vents that I need? I don't see...
impreston - with out the following parts , you really don't have "just the air conditioner."
1- Flexible Exhaust Hose
2- Hose Adapters
1- Sliding Window Kit
1-Foam Window Seal
1-Remote Control
The drain hose is something you supply. A garden hose, no longer than 5 feet will do if you want it to be a continusos drain, rather than drain into the water collectiong bucket. But, without the first 4 items lister above, you won't be able to operate the unit.
Here is a link that may be of some help to you, since you don't have an Owner's Manual.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020252a0373en.pdf
You will beed to contact Frigidaire (1 -800-374-4432 ) for the parts you're missing.
Hope this helped you. Please let me know. Thanks.
Jul 12, 2011 | Frigidaire FAP094P1Z Portable Air...
Dandy model DPAC8399 water lear from rear water hold tank
Dandy instructions are located here:https://www.danby.com/wp-content/uploads/2016/04/DPAC83991.pdf
Basically, you need to attach the external tank tray at the bottom, remove the tank male fitting and screw it into the external tank female port.
Nov 24, 2017 | Danby DPAC8399 Air Conditioner
The heater blows cool air
Most heater core control valves are cable operated. A few are vacuum operated. Hot water is not getting into heater core. Valve has to be troubleshot. Less likely is plugged hose lines to heater. If you intend to DIY please get a repair manual at autoparts store. Good luck!
Mar 17, 2010 | 1994 Ford Thunderbird
I need a manual for a Clausen kyd-32/a portable air conditioner
http://www.search-document.com/pdf/1/clausen-air-conditioner-kyd-32a.html
Nov 11, 2009 | Heating & Cooling
I just bought a Danby portable air conditioner (model # dpac5070). The manual tells you how to use the direct drain hose if you want to "vent" the water outside. If I don't want to direct the water...
You use the hose only for continuous draining outside of the unit into a bucket or what have you. You don't need to attach the hose at all. I actually need the hose if you want to part with yours. coatings(at)shaw.ca
Jul 04, 2009 | Danby Heating & Cooling
Needing part to fix my water heater?
Colburns Suppy they have a web site and will have that part in stock or they can order it. www.coburns.com
Feb 01, 2009 | Bosch & Tankless LP Hot Water Heater
Heating & Cooling Logo
106 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
