What like to rmove i dont like being scamed - Computers & Internet
  • 27,725 Answers
Im not sure i understand the problem rmove ? and scamed
if the last scamed is scammed no one likes to be scammed
post a reply with details of the scam
Posted on Jan 05, 2013
Testimonial: "I am very new at all this and did download things i didn't know i did and you helped me fix it "
I've a 99 protege replaced the rear main seal in, and leaks again , I was told that the crank was worn and that's what caused it to leak again could this be true or am I getting scamed
unlikley as its only the rubber that touches the crank shaft on any car but it could be warped moving the seal and letting oil out more likeley if its still leaking did the garage do it it may be that the seal was rubbish they put in and are trying to get more money out of you for the sake of another seal was it genuin parts of aftermarket parts as some times that makes a masive difference hope this helps
Sep 24, 2012 | Cars & Trucks
1995 bonneville pontiac haw to re rmove the radio
check fuses first if dome lights dont work find that fuse and replace
Aug 16, 2012 | Cars & Trucks
Are there any written instructions on-line on how to install a water pump on a 2002 Toyota Four Runner SR5 V6
well doing a water pump is like doing timing belt just one more estep, rmove your water pump there are about five 12mm head bolts and two 10mm nuts, clean gasket surface from any sealant left, replace water pump and timing belt.
dont have any ilustrations to show you but any manual for timing belt will do.
Mar 17, 2011 | Toyota 4Runner Cars & Trucks
I want to add RAM Memory. Which panel do I access or must I rmove the entire case?
just remove the back side small cover .dont open entire case.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Dec 28, 2010 | Toshiba Satellite A135-S4527 Notebook
Is it hard to replace hub bearing on gmc jimmy 2001
No,,,Remove the wheel,the brake caliper,unplug the abs sensor,if it is 4x4,rmove the center nut on the axle,rmove the rotor,and caliper braket,bracket first of course,then unbolt the three bolts that hold the bearing assembely,that is it.
Mar 25, 2010 | 2001 GMC Jimmy
Motorola motokrazr i cried on while talking to a
Ok some moisture has got into your phone.
Take the battery compartment cover off and rmove battery dry both.
Take phone and parts into a warm room and leave for 2-3 hrs .Dont put on a radiator.
Then reconnect and try.Charge to full , replace battery and cover. Fingers crossed for you.
Dec 23, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
My xbox 360 will not play any of my new games
1 if you bought from ebay you got scamed 2 less likely you got scamed on your "new games"
Nov 01, 2009 | Microsoft Xbox 360 Console
Yahoo scam and harrasment
You Can Contact Yahoo directly at 1-866-562-7219
Jan 01, 2009 | Yahoo Mail
Computers & Internet Logo
David Payne
David Payne
