Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
Spark plug gap
What is the spark plug gap on a 1500LE, Featherlite leafblower?
  • Anonymous Mar 20, 2014
  • 211 Answers
Hi
0.7 mm
bestregards savumihai71
Posted on Feb 12, 2009
What is the spark plug gap for 18cc weed eater?
search
What is the correct spark plug gap?
The spark plug gap on all products is .025-inch.
What type of spark plug does the unit take?
The size of the plug varies from unit to unit. On trimmers, blowers and hedge trimmers is RCJ-8Y or RCJ-6Y. Follow the spark plug recommendation and replacement procedures in the operator's manual if you are doing the work yourself.
Jun 07, 2015 | Weed Eater Featherlite 18cc 2 Speed Gas...
What is the spark plug gap for weed eater 25cc leafblower
Hi Joyce,try 015" thats 15 thousands of an inch.with imperial feeler gauges.Cheers.Ronnie.
Apr 21, 2012 | Weedeater 25cc Gas Blower ()
Need do know the spark plugs gap
If you're replacing the spark plugs in your car engine, you'll need to set the gap before reseating the spark plug. The gap is the distance electricity arcs between the ground electrode and center electrode. The gap must be set correctly to ensure maximum performance. Here's how to set the gap of a spark plug.
  1. Remove the spark plug wires. Use a socket wrench to remove the spark plugs from their chambers.
  2. Clean the spark plug if you are not replacing it with a new one. Remove all dirt and debris from the spark plug.
  3. Check the owner's manual for your car (or any appliance with spark plugs) to find out the recommended gap setting.
  4. Use a gap tool to check the gap of the spark plug. Slip the tool between the ground electrode and center electrode. The gap tool should fit snugly at the recommended gap width indicated on the tool.
  5. Push the tool between the electrodes a few times to ensure proper gap. If the gap is too wide, push the ground electrode firmly against a flat surface to narrow the gap and then check again with the gap tool.
  6. Repeat Step 5 as necessary until you reach the correct gap. Reseat the spark plug and reattach the spark plug wires
Good Luck
Dec 10, 2010 | 1997 Pontiac Grand Am
I purchased a new spark plug for my craftmans leafblower and it still won't start I did not ajust the gap on the plug, but I will to see if it will start, I have more gas than oil right now, but I am going...
Gap the plug try.030 to start or if you know your plugs gap, gap it make sure you have spark more fuel is ok only for short time but is recommended to make correct mix.
Nov 12, 2010 | Garden
Craftsman leaf blower wont start
The air gap for the ignition coil core to flywheel is adjustable on some engines and the gap does vary.
On a Stihl, I used a matchbook cover first, then doubled it and got the engine to start. That amounts to 8-10/1000ths (0.008-0.010") as measured with a digital caliper after-the-fact.
I'm troubleshooting another engine currently from a McCulloch Airstream IV that only has ~12 hours and no spark but the coil measures roughly as it should; around 1K Ohms. Was surprised to find the company went bankrupt in '99. Another one killed by Asians and fairly poor design.
May 26, 2010 | Poulan Featherlite Gas Blower, with Low...
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
224 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
