Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
A blue semi-circular hue on the bottom left of the screen
The hue appears on most viewing unless the area
is showing a blue color then it isn't visible. the semi-circle also seems to be getting bigger at a slow rate.
  • 2 more comments
  • n_gakuya Jan 19, 2009
    the model of the tv KF-50WE610. it has a blue/purple patch semi-circular in shape on the bottom left of the screen. it looks like a light or hue and it's slowly getting larger.
  • Anonymous Feb 12, 2009
    Can I replace the blue lcd in light engine myself or does it take a service call?
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Thanks for update,
    Problem is Blue LCD in light engine and needs replacement.
    Call Sony Support number written on user manual for proper fix.
    Need more info, let me know.
    Please intimate exact model of tv to help you out.
    President:
  • Sony Master
  • 1,779 Answers
9 times out of 10 the Blue Polarizer heats up and discolors which causes that problem, all projector's have the same issue and have for years. My professional recommendation is get in touch with Sony, they have been extending the warranty's for this issue. If they won't the have a servicer replace the light engine of which is not cheap.
Posted on Feb 17, 2009
  • cheryl1999 Feb 08, 2014
    what is the light engine - u mean the optical block-the heart of LCD's?
How can i adjust colors in konica c450
HI ganesh,
Instructions
    • 1Go to the Application screen on the LCD panel located on the printer and press on "Edit Color." Press on "Color Adjustment."
    • 2 If unhappy with the hue of your copy, press "hue." Look at the 'hue" screen and press the arrow keys in the direction you wish to change the color hue. Press "Sample Copy".
    • Sponsored Links
    • 3 Take a sheet of paper and place in the top left corner of the glass surface of the Bizhub. You will see that the area is marked "Sample Area" alongside the glass area. Press the "Start" button on top of the Bizhub.
    • 4 Wait for the Bizhub to produce a sample sheet. Look at the finished sample sheet -- there are six options showing three incremental "plus" hue options and the three incremental "negative" hue options. Select the one you like and press to confirm the required hue adjustment on the "Hue" screen. You have now calibrated your colors as desired.
Read more: http://www.ehow.com/how_7590176_calibrate-colors-konica-bizhub.html#ixzz316wHLgOK
May 08, 2014 | Office Equipment & Supplies
The grey in my relaxed brown hair occasionally turns a greenish color I use adore semi permanent, dark chocolate any idea how to avoid this?
Your hair is turning green because your missing red when you color your hair. Gray is uncolored hair and to get to a dark chocolate brown you need to add a little red to the color to make up for this. You don't need to strip it out.
Have you heard of people using purple shampoo to neutralize the yellow tones of their blonde? Red will neutralize the green tones, so adding a little red to your color will do this for you.
Mar 09, 2014 | Adore LVT Semi Permanent Hair Color 112...
There is too much blue on the screen & not enough green coloring
Have a very close look at the blue and see if it's perfectly uniform across the whole screen.
If it is then altering the hue or colour temperature settings in the menu may help.
If it's not then either there are heaps of pixel failures (appearing as small rectangular spots) or degradation of the polarisers (green may be affected more than the others).
If you show the menu, do the white areas appear bluish.
If the lamp is very old then colour changes start to happen.
Jun 23, 2011 | Canon Office Equipment & Supplies
I replaced the lamp on a Panasonic PT-LC80U thinking this will solve the yellow appereance, but it did work, it seems that there are not blues in the image. What Can I Do to solve the problem?
here are some probable causes..
This appears to be an older model (over 5 years old) and LCD projectors turn yellow with age. It's just what they do
However, if you are projecting a computer signal or a component signal, a short in the blue signal of the cable can cast yellow hues over your image. The hue will cover the entire image as if you are viewing the image "through rose (or in this case, lemon) colored glasses" so to speak. That's an easy fix.
Harder fixes: the blue LCD panel is weaking and/or gone bad.
If you have a round yellowish spot in the middle of your screen, the diffuser has been overheated and is "burnt".
Apr 08, 2010 | Panasonic PT-LC80U Multimedia Projector
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Jul 24, 2009 | Vizio GV42L 42 in. LCD Television
Blue circle in the center of picture
I need to know what color you got the circle in because one of your lamps went out and needs to be repaired this circle is only going to get bigger an bigger and shall i go on? Easy fix buy the new one and have it put in around $90 bucks plus labor.
May 24, 2009 | Hitachi 46F500 46" Rear Projection...
TV lost some of the colors
quick simple solution that might fix it. Completely unplug the tv from the electricity for about 30 seconds. Some times especially during brown outs or black outs, the processor gets scrambled and needs to be reset. This 30 seconds of no electricity usually allows the system to reset it self correctly.
hth
Feb 14, 2009 | Samsung DLP HL-P5663W 56" TV
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
168 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
