Question about Canon ZR45MC Mini DV Digital Camcorder
Camera cassette errors
Hi, im reciving an error, every time i insert the cassette in the video camera. "remove cassette" is the error im reciving. and when i open it up to take out the cassette, the tape role is badly pulled out.... plz help...
  • 1 more comment
  • nadia kkan Jul 16, 2007
    oops..didn't mean too rate this solution that bad, i actually rated it before i saw that someone
    once again: thanks alot :)
  • Anonymous Nov 24, 2007
    I, too, kept receiving the "eject tape" signal on my Canon zr45. Tapes would not play or record. I almost threw away the camera, figuring it would cost a bundle to repair. But you suggested to clean the camcorder heads with a cleaning tape, and it worked perfectly. Thank you so much!
    Dianne
  • rocky54 Dec 29, 2007
    I recieve the same error message but the cassette will not eject all the way so I cannot take it out.
    Scholar:
  • 35 Answers
Often in this situation there are two issues that can casue the problem you are having. 1. The tape is casuing the camera to "reject" it. In other words, it thinks there is something wrong with the tape so it is warning you with the error message. Perhaps the cassette has been damaged slightly. This error can also happen when the tape has been used often or taped over a few times. Solution: Try using a new tape. 2. The camera may need to be cleaned. The recording heads may be dirty and it doesn't matter what tape is placed in there. Purchase a cleaning tape from a consumer electronics store. Make sure you read the directions very carefully. These are cheap fixes. If it works, great. Otherwise it may need to be serviced by your local technician. Let me know how it goes.
Posted on Jun 30, 2007
SOURCE:
Re-insert the cassette error message
SMACK THE CAMERA ON EITHER SIDE REAL HARD
? what does it mean plz?
can you explain for me plz?!!
Apr 12, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
The tape runs for 3 seconds then error message ''please re-insert cassette / on screen error code C:32:22 - head cleaner tape has the same effect
When I got this error I removed the battery for 10 seconds and then put it back in. Camera should come on automatically. I just did this to mine and it seems to work.
Oct 03, 2009 | Sony Video Cameras
My problem is error c3122
The error C:31:22 indicates that the problem is in mechanical section of the tape loading path, it need mechanical adjustment, Actually most of the time this problem appears when the insertion of the cassette is improper or due to dirt/dust mechanical gears start malfunction and a sensor in the mechanical detects it and self diagnostic system shows this error,
Your camera only needs mechanical adjustment and it work fine again, Contact any expert for mechanical adjustment.
Thanks for using fixya.
Jul 24, 2009 | Sony Video Cameras
I get an eject symbol and beep and error code c32:11, original issue was that it ate a tape
The error C 32:11 denotes for mechanical unsuitability, This problem appears when the improper insertion of the cassette been done, or lose cassette tape stuck,
In all these situations mechanical adjustment is required, You are suggested to please contact any expert for the mechanical adjustment.
Hope you will understand my sayings.
Jul 11, 2009 | Sony Handycam CCD-TRV68 Camcorder
MX2, it displays the following: "remove the cassette" or eject. I thought it was a condensation problem but all attempts failed, please help me.
On Canon camcorders, "remove the tape" error is due to no data reading by video head. You may have clogged heads or somewhere along the area. Initially, I would try to insert good clean "video head cleaning tape" and run for about 7 seconds and see if that resolve the symptom. If it persists, it need a help from a technician. Good Luck. For further help, go to www.camerarepairjapan.com James
Feb 26, 2009 | Canon DM-XM2 Mini DV Digital Camcorder
Error display C31.23
code indicates that you should remove the cassette and insert again, then operate camera.
disconnect power cord and battery pack. after reconnecting operate camera,
Oct 13, 2008 | Sony Handycam DCR-TRV30E Mini DV Digital...
Sony dcr-trv480 video camcorder error
I also have this problem, with a SONY DCR-TRV480E PAL. The problem is when I insert the cassette it reads on screen that "re-insert the cassette"
May 04, 2008 | Sony DCR-TRV-428E Hi8 Easy Handycam Pal...
Inserted cassete in wrong way in Sony camcorder CCDTRV68, not ejecting cassette Error codeC32:20
Sony camcorders C:31:23 error
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Dec 24, 2007 | Sony Handycam CCD-TRV68 Camcorder
Error indication E04 eject and re-insert cassette ?
Hi, when you get an E0 type error it is time to take it to a technician.
Oct 13, 2007 | JVC Cybercam GR-D90 Mini DV Digital...
Reinsert cassette error... cannot record via tape
What error message is it giving to you ?? as this will be a good indication of fault.You have tried all the usual things to try by the sounds of things,
May 14, 2007 | Sony Handycam DCR-HC46 Mini DV Digital...
Canon ZR45MC Mini DV Digital Camcorder Logo
365 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
