Question about Whirlpool ET8WTKXK Top Freezer Refrigerator
I have a whirlpool fridge model WRN43NWB6 where the compressor keeps running and it does not keep things completely frozen can you advise me what the problem might be please, Tonnie
lenwest
  • 150 Answers
SOURCE: My bottom freezer is making ice but not keeping the food frozen
The flow tubes are blocked.You will need to defrost the unit,unplug and pull off as much ice as possible.You can put pans of hot water in the freezer.
Posted on Feb 12, 2009
peyton32034
  • 410 Answers
SOURCE: compressor runs for 5sec.
the sound your hearing is most likely the starter relay for your compressor. this is a common failure part for this model whirlpool. if the unit is out of warranty you can purchase part# 8201786 from any local appliance parts deealer, online at numerous parts suppliers or the easiest in my opinion sears partsdirect.com. the kit is a plug and play part and has very good instructions so that you could replace it yourself. the part should be less than 65-70 dollars.
I do reccomend that you unplug the refrig to prevent damage to your compressor.
If you have any further questions please leave a comment here and I'll be glad to assist you in any way I can. thanks Peyton
Posted on Feb 23, 2009
  • 163 Answers
your relay and overload on side of compressor is bad.you can replace with original parts or a 3-n-1 hard to start.
Posted on Mar 09, 2009
aborcass
  • 2651 Answers
SOURCE: The strip between freezer and fridge is very hot
sounds as if you either need to clean the coils under the unit,they are clogged and unable to disapate correct amount of heat, or your fan mounted behind the unit, next tothe compressor has failed..YOUR UNIT IS WORKING EXTRA HARD TO GET RID OF HEAT.check those 2 places
Posted on Jun 15, 2009
SOURCE: Have a whirlpool top-mount fridge model # ET1FTTX00 the fridge
no frost in freezer temp is about 28 degrees in freezer
Posted on Jun 18, 2009
Our kenmore fridge model #25371134102 is not keeping things cold
check the coils at bottom of ref.they shoud be clean.also the overload relay mounter on compressor maybe bad
Apr 10, 2013 | Refrigerators
Msd3756aew fridge won't stay warm, freezer cold but not keeping frozen. Cioils not frozen, fan working
the ptc overload/relay on the compressor is bad and not starting the compressor,remove back cover unplug the ptc off the compressor and replace it with a new exact replacement part
Feb 01, 2013 | Refrigerators
Coil is freezing up
two options...one drain hole blocked in freezer,clean with copper wire/bleach to clear gunge.
two outside temp too cold i.e. unit in garage/outhouse( too cold for compressor )
also check seal to doors.air leaks...
Feb 06, 2010 | Whirlpool GB9SHDXPS Stainless Steel Bottom...
Crosley fridge will not stop running?
Check the seal (gasket) around the door. If the seal is not sealing properly the compressor has to keep running all the time.
Aug 07, 2009 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
Compressor runs for 5sec.
Mar 09, 2009 | Whirlpool ED5GHGXMQ Side by Side...
Feb 23, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE Profile not keeping items cold or frozen
Does'nt sound like your compressor.sounds like you may have frost build up,and the tubes may be partially blocked.Try defrosting the whole unit.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 21, 2009 | Refrigerators
Whirlpool frost free fridge
check the reley at the compressor if it looks like a little white box pull it loose if it rattles and stuff falls out go the appliances part store and get you a three in one rely for a1/3 horsepower or less and install it by the directions its not hard
Jan 20, 2008 | Refrigerators
Whirlpool ET8WTKXK Top Freezer Refrigerator Logo
94 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
