Question about Plumbing
I have a Pacific Hydrostar 1 HP Shallow well pump 69302 and I am looking to replace the flexible tube. Where do I find this part?
The flexible tube has a slow leak.
3 Suggested Answers
SOURCE: Winterizing a well pump and pressure tank
If this is the pump I am thinking of, it should drain if you disconnect the hose to the pressure tank.
The other option is to place a "T" connection on the intake to the pump, between the pump and well. Place a garden hose valve on the new branch. After you drain your system, attach a 2' hose to the new valve and place the other end into some antifreeze. Run the pump to draw some antifreeze into the unit. This will protect it from freezing and rust over the winter.
Posted on Apr 26, 2010
  • 4 Answers
SOURCE: Wher can I get a manual for a pacific hydrostar
http://manuals.harborfreight.com/manuals/2000-2999/2955.pdf
Posted on Jan 09, 2011
MY classic 1976 Austin mini tends to over heat when outside temp is over 35c thermostat replaced with a safari one Radiator good WHY???
Maybe the engine cooling pump not work well?
If use flexible rubber impeller in the pump,check the vanes are leak or broken down?
We supply full range raw water pump impellers for outboard and inboard.Our website www.flexible-impeller.com
Normally we can delivery out by FedEx/UPS in 3~5days arrive customer's hand.I hope which can help you:-)
Best regards from Lindong
Jabsco Johnson Sherwood Water Pump Flexible Impellers Outboard Inboard...
Jun 29, 2017 | Mini Cars & Trucks
Throttle linkage diagram for pacific hydrostar pressure washer 4 hp
For a throttle linkage diagram, contact Pacific Hydrostar directly.
Apr 21, 2017 | Garden
How can I clear clogged drain tube?
Try blow it with air. Shop vac will do. Then with flexible small rod,
plastic one better, try to clean the tube, when done gently pour boiled water into the tube. It worked great for me.
Mar 26, 2016 | Refrigerators
I need to change the pump on my pacific hydrostar 2800
That cannot be done over the internet, no matter what ISP you have.
Further, you need to be more-specific about exactly what you have.
Pacific Hydrostar makes both sump pumps and pressure washers with 2800 ratings (gallons per hour and PSI, respectively). So you should use the model number of your device, not what the large print on its decals say, when requesting help with them.
Apr 03, 2015 | Computers & Internet
Hydrostar manual
they are sold @ Harbor Freight Tools, you can try there, the only other place that I can find this brand of pump is @ sears, but that is only for small 264GPM submersibles. can't seem to locate a web site for the company that makes them. you may look on the pump to see if you can locate where they are made.
Aug 18, 2014 | Plumbing
How hard is it to replace drivers side brake line it's leaking right before rear wheel
Hard lines (tubing) takes a little practice with the double flare on the ends. But if you buy pre flared and you can use a tubing bender that makes it a little easier. Flexible lines are pretty easy to change. You will need to bleed any lines that are changed to remove all air from line. Air will cause no pedal pressure or a mushy feel.
Aug 01, 2014 | Tie Down Flexible Brake Line Kit
Pacific hydrostar 68333 1500psi pressure washer...motor keeps cutting out, but reset breaker does NOT trip.
dont know the model or if it has a pressure switch inside the box but try and remove your lance and just operate the gun... if it runs ok your last could be blocked
Aug 21, 2013 | Pacific Hydrostar Pacifichydrostar...
Ween two 15mm bidet pipes which are about 3 inches apart and slightly at an angle
I don't know all of your situation, but I have found 1/2" flexible connection lines braided or neoprene very adequate. Another suggestion is to use 3/8" plastic tubing with appropriate fittings. Hope this is helpful.
Apr 21, 2017 | Plumbing
Pacific Hydrostar pump 2" 6.5 HP Item # 95977. I
Do you know where get a owner/repair manual for a Pacific Hydrostar portable water pump #95977?
Jul 09, 2011 | Plumbing
Plumbing Logo
533 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
