Question about Amana NDE2335AY Electric Dryer
Hotpoint Dryer not heating
Our dryer is running its cycle but it is not giving any heat, is there a reset button, if so how do we get to it, or is there something else we can do?
  • 63 Answers
Check breaker for 240 at outlet if you have that its your cuttoff fuse or element
Posted on Jan 20, 2009
  • 1,214 Answers
Please confirm the appliance in question is the Amana NDE2235AY.
Check that the vent pipe is not partially or totally restricted, all the way to the outside of the house.
Posted on Jan 19, 2009
Where will I find the heat reset button on my tcm580 condenser dryer
Hello Mandy, I am not sure what you mean by a heat reset button; perhaps explaining what the problem is, I may be able to assist you. Are you referring to the dryer motor's overload reset button? As a safety feature, a dryer has a high-limit thermostat and either a thermal fuse or thermal cut-off fuse.
In the event of poor air flow where there is no proper ventilation to the heating element- the internal temperature of the dryer exceeds its high-limit, the dryer will shut-down; once it cools off, you should be able to run it again.
However, if the thermal fuse (located on the blower housing) or the thermal cut-off fuse (located on the heater housing) goes, the dryer heating element will will not heat up or the dryer will stop running altogether.
Please note, a dryer will have either a thermal fuse OR a thermal cut-off fuse, but not both.
By-the-way, there has been a recall on certain models of HotPoint Creda, and Indesit tumble dryers due to a fire hazard risk; I am sending you the link...If your dryer is manufactured by HotPoint model TCM580, then your dryer maybe affected. Read the info in the link- it'll give you instructions on how to determine if your specific dryer is affected and what to do.
Feb 15, 2017 | Dryers
Do a tumble dryer have a reset button once you have changed the thermostats?
check the heating element they might be the problem if they are not getting any power or are open.
Aug 27, 2014 | Hotpoint Dryers
Matthew Campbell,
I understand that your Frigidaire electric dryer will run but is not heating up. What I would suggest would be to give the appliance a hard reset.
You can do this by either unplugging it or cutting the power at the Circuit Breaker for 3-5 minutes. After resetting it for the 3-5 minutes, bring power back to the dryer. Run any cycle and see if you are getting heat or not.
If you are not getting any heat to the appliance, it could be either something to do with the heating element or possibly the control board itself. The other possibility would be the wiring going between the heating element and the control board.
I would recommend contacting a local authorized technician to determine what exactly is the root of the dryer not heating.
-Best Regards-
Jan 14, 2014 | Frigidaire Electric Dryer
Dryer heats too hot instantly. Ok on cool down or blower only cycle. All vents are clean.
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
Aug 06, 2011 | Hotpoint Dryers
My hotpoint dryer doesn't heat up, it runs but the air is not warm to dry anything. Can you tell what is the problem?
dismantle the top and front covers,then test the heating element,high limit thermostat on the element housing,then,check the cycling and thermal fuse on the blower wheel housing for continuity
Mar 03, 2011 | Hotpoint TDC32 Electric Dryer
Hotpoint wd865 dryer stopped working
I always start at the plug to make sure it has 220, a dryer will run but no heat with 110. This was a common problem when everyone used fuses instead of breakers, just an old habit.
Then I check the heating element and thermostats, this must be done with an OHM meter. More than likely it will one of these.
Dec 23, 2008 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Hotpoint wd440 flashing dryer heat button and onoff button !
I had to have a tech come out for the same problem two weeks ago. They had to clean the lint collector which you cannot get to on your own. He said now that this has been done everytime I use the machine, take the clothes out and then run a rinse spin cycle.
Aug 04, 2008 | Hotpoint Aquarius WD63 Front Load...
My gas dryer only heats up the first time...
replace both coils on the gas burner (the round black dohickeys)after first ignition they tend not to pull valve open next time heat is called for
Jun 06, 2008 | Hotpoint NBXR463GBWW Gas Dryer
Amana NDE2335AY Electric Dryer Logo
157 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
