Question about Philips SA3025/37 Flash MP3 Player
Going back to the menu
When i turn my philips go gear on it goes to the menu but after selecting a catagory i cant go back to menu.............HELP
  • 8,596 Answers
The button that looks like a curved arrow will let you go to a previous menu screen - see your user's manual for details.
-Tha Mp3 Doctor
Posted on Feb 01, 2009
I took the cover off to see if my prop. was jammed, but nothing. When I spin it manually it's hard to turn & snaps quickly to where it started.
you have put this in spa and pools catagory but it would be as an outboard question
re-ask the question in the right catagory with full details of make ,model and prop mount procedure and any other details like gear selection problems ,noise etc
Aug 28, 2015 | Pool & Spa
The screen goes back to menu and stays on.how do i get it off.
should press menu again on your remote control or quit depends on the tv brand
Feb 02, 2014 | Philips Televison & Video
Got the philips go gear raga and the main philips screen will turn on but then it freezes what do i do
You can repair your device using this steps:
Please install Philips Songbird software on your computer and then launch the program.
If you don"t have it can be downloaded from Philips website.
http://www.support.philips.com
In the Philips Songbird menu bar (at the top), click on the Tools pull-down menu and then select Repair My RAGA.
Follow the on-screen instructions to complete the repair procedure.
I hope it will be successful.
Thanks.
gylacz
Aug 16, 2011 | Philips GoGear SA5285/37 Digital Media...
Hi, i have a 42PF5421, i have had foreign language on my menu for 2 years now, but im finally going mad. Ive tried going to the menu, but its just the hdmenu. I cant get to any install/language options. ...
On the right hand side of the TV (NOT the remote control), push the menu button (there are 4 buttons on the side of the TV, menu one is 2nd from the top) and hold it down for 10 seconds. The green light on the TV will flash continuously while you're holding it down. Then the language selection feature pops up. Default was English for me. Push the menu button again to select.
The manual (http://download.p4c.philips.com/files/4/42pf5421_10/42pf5421_10_dfu_eng.pdf) does not include this
May 02, 2011 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Every time I connect my Philips Go Gear into my computer, it tells the that the device is not recognized. It won't even charge it. I have had this MP3 player for going on 4 years, and have never had this...
I'd suggest that you do a soft reset of your player. You will find the reset button next to the 'power on' button on the side of the player. Please hold the Reset button using a pen tip or other sharp object for 10 seconds. Now turn it on.
If that doesn't work, I'd suggest that you restore factory settings or repair it Philips Device manager. You can install them from the CD that came with your player or download it from Philips support site.
*Contents may be removed by using this function. So make sure to back up your contents.
Repair using Device manager:
Launch Device Manager and click the Tool menu and select "Repair", then follow the instructions to perform the repair process. Make sure all other applications such as Philips Plug-in, Windows Media Player or Windows Explorer that access the device are closed or else Device Manager will not recognize the device.
You can download the Device manager from www.philips.com/support site.
Hope this works
Mar 10, 2011 | Philips SA5125/37 MP3 Player
Sir,I have motorola w200 cdma phone by mistake i have change it language and now i can't change its language please tell me how we can get english language.
Service codes Motorola CDMA: w150, w150i, w170, w170c, w200, w210, w355:
Set English language:
1. Menu
2. Down 7 times, Right soft button
3. Down 3 times, Right soft button
4. Down 1 times, Right soft button
5. Down 4 times, Right soft button
6. select language now
Aug 14, 2010 | Motorola Cell Phones
Phillips 37PF73203 37 in Television goes straigt to Menu and stays
When I turn on my TV it goes straight to the menu screen. You can still hear sound but no picture. When I try to exit you see the picture for about a second then it automatically flashes back to the menu screen. Even if I try to use the functions in the menu screen it flashes right back to the main menu screen. Very frustrated...need help!
Jul 13, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips Turns Back Off
Install and run the Philips Device Manager from the product CD.
Switch off the player.
Press and hold [VOL+] whilst connecting the player to the PC.
Device manager should report device error.
Follow on-screen prompts.
This should format the player and re-load the system files.
Apr 22, 2008 | Philips GOGEAR SA6045 MP3 Player
50p8341 on-screen menu
05/09/08
I called the Philips help number (1-888-PHILIPS) and the tech had me turn off the tv and then unplug it from the outlet, wait 1 minute, then plug it back into the outlet, then turn the tv back on. It reset the menu memory and it is now back in the middle of the screen where it belongs.
Feb 23, 2008 | Philips 50P8341 50" Rear Projection...
Stuck at the Go-Gear screen
Sounds like the firmware has corrupted.
Select the restore / repair option and follow the on-screen prompts.
This will re-install the firmware and format the player.
Feb 16, 2008 | Philips SA5125/37 MP3 Player
Philips SA3025/37 Flash MP3 Player Logo
23 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
