Unlock bios toshiba satellite L775-S7102 - Computers & Internet
  • 13 Answers
SOURCE: need to unlock BIOS password
Unfortunately there is no easy fix. Removing the CMOS battery does not work nor are there jumpers on the MB. The only way to get it reset is to go to an authorized Toshiba dealer or repair facility and have them do it. This is going to cost you since normally it is not covered under warranty.
Posted on Jun 15, 2009
  • 10406 Answers
SOURCE: how to remove bios password for Toshiba Satellite A200
If you know the current password, use it to enter BIOS SETUP.
Then, type a "blank" ("space-bar") as the "new" password.
If you don't know the current password, you're stuck;
this is a "security" feature to prevent a stolen laptop from being used by the thief.
Posted on May 27, 2009
  • 244 Answers
SOURCE: toshiba satellite a215-s7437 bios pw
There is a well know issue with Toshiba laptops of certain models, where at startup suddenly ask for a password.
There is NO WAY you can reset that.
You must take it to the nearest Toshiba authorized service center.
There will be no charge for it.
You should first call them to get an authorization number.
Their number is 1(800)457-7777
Just tell them that your laptop is asking for a password at boot up, and give them your model number.
They will also flash the CMOS so this issue won't repeat again.
Please don't forget to rate this answer if useful
Posted on Jun 21, 2009
  • 47 Answers
SOURCE: toshiba satellite a105 bios password dont have
1), when taking your computer apart, take out the battery and unplug it always
2), Remove the plastic cover piece above the keyboard, called the keyboard bezel. this is the piece where you can see the speakers. it is a bit difficult to get the plastic retaining clips to pop loose, but if you are careful, you can use a small screw driver and slowly between the two screen mounts. this is done with the screen all the way back. you could use a paper clip with a little 1/8" bend at tip to do this also. (it is a tight working area) there are three retaining clips that have to come loose the others are fairly easy to pop out . once this is bezel is off the rest is fairly simple. please take your time and be patient as if your not you could damage it .
3), Remove the keyboard. Remove the two screws that are evident once the bezel has been removed. These hold the keyboard in place. Lift the keyboard up from the screw side and the retaining clips at the front of the keyboard will lift out. (there is no need to pry here). Once the keyboard is loose you will have to either leave it connected, just off to the side, or disconnect it from the mother board. The keyboard cable connector has a black clip along the top of it. just lift this clip up a little and the keyboard cable will slide out. (the keyboard cable does not have a fixed connector, but is just a ribbon that is held in place by the black clip along the top of the keyboard cable connector) Once you have removed it you will better understand what I mean.
4) Remove the wireless card. It is the only card visible at this point. It is connected by metal spring clips. just unclip in a similar fashion as removing ram. You do not need to disconnect the wires connected to card, just move card over to expose area below card.
5)you will see C88 clearly labeled right next the jack that the wireless card plugs into. There are two little solder squares (approx 1/16") at this location. *** At this point plug the power adapter to your computer again. ***
You will have to jump the two solder squares at label C88. .use a small wire or paper clip but make sure you removed all the coating off the paper clip first with pliers so it can make a good contact on both ends. hold it in place on these two solder contact squares and press the power button to boot your computer. here is a link to guide you for disassembly it is the same family of laptops although its for a a135
http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-2.htm
Posted on Jul 08, 2009
  • 5 Answers
SOURCE: need to unlock phoenix bios password for toshiba satellite a135-s4527
remove the keyboard the mobo battery is there you need to unsolder one end of it, lift the leg, and turn it on that way for it to clear.. you will have to resolder once done.. have the skills or find someone that does... and you're set..
Posted on Aug 07, 2009
Toshiba satellite L775 laptop. Cannot find jumper to reset bios.
http://www.fixya.com/support/t16407637-trying_clear_bios_password_toshiba
this previous post confirms this jumper !
Try also removing hard drive to see if cd rom is next device to boot in the boot order when the hard drive is not found !
Mar 23, 2017 | Toshiba Computers & Internet
How do I remove the bezel from the screen of a Toshiba SATELLITE LAPTOP p875-s7102
Hi
I haven't found anything specific to the model given, but the link below takes you to a movie showing how to replace the screen on a p870, which may be similar to yours
http://www.laptopscreen.com/English/video/Toshiba/satellite/p870/
This link below takes you to a website where there are many, many models of Toshiba laptops with disassembly instructions. Again I couldn't find your model but you may be able to find a similar one
http://repair4laptop.org/disassembly_toshiba.html
Good Luck
Oct 18, 2014 | Toshiba Computers & Internet
How to remove bezel from a Toshiba satellite p875-s7102 laptop screen
There are four rubber bungs, one in each corner. Pull them out and then undo the four screws. The screen bezel will then unclip from the screen.
How to unlock a toshiba Satellite l45 bois password
Just remove the CMOS battery for a few seconds, then put it back. The BIOS password will now be reset.
Aug 09, 2014 | Toshiba Satellite L745-S4310 Laptop
Laptop screen lights, no display but exterior vga plays
either bad lcd panel or the power inverter for the lcd has gone bad.
Mar 27, 2014 | Toshiba Satellite L775-s7307 Laptop...
My Toshiba L775 -S7307 won't stream to my Bose Sounddock 10. Does my computer support A2DP?
According to the Toshiba website, your laptop does not have Bluetooth, with means it won't have A2DP. You can buy a dongle to get Bluetooth to your laptop.
http://www.toshiba.com/us/computers/laptops/satellite/L770/L775-S7307
Oct 14, 2013 | Toshiba Computers & Internet
Can't get Toshiba Satellite L775 to boot past "windows is loading files" screen
I assume you are doing a System Restore/Recovery? Have you removed the HDD and tested it? Perhaps the Recovery files are corrupt/missing? A bit more info needed.
Jul 03, 2013 | Toshiba Satellite L655-S5160 Laptop PC...
How much ram available on toshiba L755 motherboard
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L775-L770-L775D-L770D/laptop-disassembly-1.htm
Click on the photo in Step 3.
There are TWO Ram memory modules that can be installed.
EACH ram memory slot will support 4GB of ram memory.
TOTAL for the motherboard is 8GB.
Uses SO-DIMM ram memory modules that are PC3-10600, or PC3-12800,
http://www.crucial.com/store/listparts.aspx?model=Satellite%20L755&Cat=RAM
Regards,
joecoolvette
Sep 19, 2012 | Toshiba Computers & Internet
Need to unlock bios on my toshiba satellite n e
I would disassemble the computer, or find a manual where it will tell you how to remove the cmos battery to reset the bios,
Once it is reset, then windows would boot up
Jul 20, 2010 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
175 people viewed this question
David Payne
David Payne
