Question about Xerox Office Equipment & Supplies
Error code 012-332
Fault has occured
2 Suggested Answers
  • 2072 Answers
SOURCE: Xerox 8550 printer has error or fault code 37,018:45:24719
Oh yuck. That is a source voltage fault.
The electronics module has most likely failed. Umm very expensive also. See if your insurance will cover repairing it. That way you can have Xerox come in fix it and insurance reimburse you. I have had to do calls like this several times and have had insurance pick it up. You may need an estimate to repair from the insurance company.
Posted on Jan 22, 2009
Hi!Can you help me resolving error code 092-315 for xerox7225?
Can you verify the error code? 092-315 does not appear in the error code site. See link below
How To Search for a Fault Code WC7220 / WC7225 Fault Code Page
To search on a fault code, enter one code at a time. The codes will be displayed on the Touch Screen.
Fault code format: A 3-digit number, followed by a 3-digit number. For example, 010-352.
Viewing Fault and Alert Messages on the Control Panel
When a fault or alert condition occurs, a message will be displayed on the Control Panel to inform you of the problem. Alert messages inform you about printer conditions, such as low supplies or open doors, that require your attention. Fault messages warn you about printer conditions that prevent the printer from printing or degrade printing performance. If more than one condition occurs, only one displays on the Control Panel.
To view a complete list of active fault and alert messages:
  1. Press the [Machine Status] button on the Control Panel.
  2. Select the [Active Messages] tab.
  3. Use the Down arrow and select [Faults], [Alerts], or [Faults & Alerts].
  4. To view details, select a fault or alert.
Viewing the Fault History on the Control Panel
When faults occur, they are logged in to a fault history file by date, time, and fault code. Use this list to identify trends and resolve problems.
To view the fault history:
  3. Select [Fault History]. The screen displays the number, date, time, and image count for each fault code.
The following table represents the system area as represented by the first 3-digits of the fault code:
Chain Description 303 Communications Error 305 Duplex Automatic Document Feeder (DADF) 310 Fusing 312, 313 Finisher 371 - 375 Paper Tray Feed 377 Sensor / Interlock Fault 391 Drum Cartridge / Waste Toner
http://www.support.xerox.com/support/workcentre-7220-7225/support/enus.html
Mar 07, 2016 | Xerox Office Equipment & Supplies
Tip
LG UNIVERSAL SPLIT AIR CONDITIONING FAULT COEDS Error Indicator: # The...
Error Indicator:
# The function provides self-diagnosis and displays an error code if there is any trouble.
# Error codes are displayed on the Indoor unit's Wired Remote as CH**, and/or Fascia Display. In
addition, the code is indicated via LED's on the outdoor unit control board.
# If more than two troubles occur simultaneously, the lower number of error code is displayed first.
# After an error occurs, if error is released, error LED is also released simultaneously
for more check the link bellow
http://electro-medical.blogspot.in/
on May 10, 2015 | LG Heating & Cooling
I can't logiin
Try again later. A system error occurred that wasn't your fault.
Apr 23, 2017 | GPS
Volvo V-70 drivetrain & electronics faults
I suspect you have some loose connections or shorts in the wiring harness. I've had similar strange things happen with an Olds Bravada. Various transmission shifting problems, faults, etc. that all seemed to come from the engine's computer system getting incorrect voltages and readings due to wiring faults/shorts.
Dec 16, 2011 | Cars & Trucks
F- code does not show code in book what and how to remedy the problem?
Hello there again here is some more info for you
Whirlpool Washer Troubleshooting: Error/Fault Codes Whirlpool Washer Troubleshooting has been made easier since newer Whirlpool washers generally display a consistent range of error codes (or fault codes) when problems develop so that owners and service personnel can quickly troubleshoot the problem and fix it easily. The Fault codes address a wide range errors that occur with Whirlpool washers, everything from water and power problems to basic maintenance routines. We have put together a comprehensive list of Whirlpool Error Codes for some specific and general Whirlpool Washer models to help you with your Whirlpool Washer Troubleshooting task.on next post
Oct 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How ifix a fatal error
Below is a listing of the more commonly experienced processor exceptions ranging from 00 to 0F.
00 = Divide Fault
Occurs if division by zero is attempted or if the result of the operation does not fit in the destination operand.
02=NMI interrupt
Interrupt 2 is reserved for the hardware Non-Maskable-Interrupt condition. No exceptions trap through interrupt 2.
04=Overflow trap
Occurs after an INTRO instruction has executed and the OF bit is set to 1.
05=Bounds Check fault
The array Index is out of range
06=Invalid Opcode fault
This error can be caused by one of the below conditions.
  1. Processor attempting to decode a bit pattern that does not correspond to any legal computer instruction.
  2. Processor attempts to execute an instruction that contains invalid operands.
  3. Processor attempts to execute a protected-mode instruction while running in virtual 8086 mode.
  4. Processor attempts to execute a LOCK prefix with an instruction that cannot be locked.
07=Copressor not available fault.
This error can occur if no math coprocessor is present. This error can also occur when the math coprocessor is used and a task switch is executed.
08=Double Fault.
This error occurs when processing an exception triggers a second exception.
09(OD)=Copressor Segment Overrun.
Floating point operand is outside the segment.
10(0Ah/0A)=Invalid Task State Segment Fault
Can be caused by a number of possibilities as Task State Segment contains a number of descriptors.
11(0Bh)=Not Present Fault
The Not Present interrupt allows the operating system to implement virtual memory through the segmentation mechanism. 0B fault occurs when this segment is not available.
12(0Ch)=Stack Fault
Occurs when instruction refers to memory beyond the limit of the stack segment.
13(Odh)=General Protection Fault
Caused by any condition that is not covered by any of the other processor exceptions. The exception indicates that this program has been corrupted in memory generally resulting in the immediate termination of the program.
14(Oeh)=Page Fault
Occurs when a paging protection rule is violated (when the retrieve fails, data retrieved is invalid or the code that issued the fault broke the protection rule for the processor).
16(10h)=Coprocessor error fault
Occurs when an unmasked floating-point exception has signaled a previous instruction.
17(11h)=Alignment Check Fault
Only used on 80486 computers. Caused when code executing at ring privilege 3 attempts to access a word operand that is not divisible by four, or a long real or temp real whose address is not divisible by eight.
Find out the reason of Fatal Error if that is due to Software related then go in safe mode and uninstall the software recently installed or udate them/patch them. or if the same is related to hardware then unplug the recently added hardware,
please vote
Aug 21, 2011 | Computers & Internet
I have a Sony CCD-TRV308 NTSC that flashes the following fault codes: C:31:40, C:31:22 and C:31:23. I have repeatedly removed the tape and the battery in an attempt to clear this. It will run for a few...
The 4-digit error code consisting of an alphabet and numbers, which blinks at 3.2 Hz is dislayed on the screen when any problems occur. This 5-character display indicates the "repaired by:", "block" in which the problem occurred, and "detailed code" of the problem.
The error code C:31:22 and C:31:23 indicates T reel fault and S reel fault respectively. Load the tape again, and perform operations from the beginning.
The error code C:31:40 indicates FG fault when starting drum. Load the tape again, and perform operations from the beginning.
Furthermore, press and hold the power button for 30 seconds then try using the Camcorder.
If the issue persists then service is required.
Sep 17, 2009 | Sony Handycam CCD-TRV308 Camcorder
Jan 22, 2009 | Xerox Office Equipment & Supplies
Cannon D780 All in One Laser Printer System Error 000
System error 000 means a fault occured 4 times in a row. You can reset this fault code and the copier should start working again. I assume you had other fault codes before you received this one, otherwise you would of never got the 000 code. To reset this code, you need to go into service mode. I dont have the instructions at this very moment, but I will get them and post them tomorrow.
Oct 05, 2007 | Canon imageCLASS D780 All-In-One Laser...
60 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
