Question about Sablon Robosapien
Robosapien V2 keep shutting down
My robot keep saying it has a bad motivator and then it shuts down.
  • Anonymous May 07, 2009
    Hi. My Robosapien V2 keeps saying "Brain Batteries Low - Powering Down". I've tried several sets of new batteries but he wont work. Any help please?
Robosapien v2 bad motivator
i had the bad motivator problem when he was standing up, then he wouldnt turn on at all. i wasnt about to let my robot be returned, i took off the leg plates and found the problem"
wire covering confetti spilled out of the leg plate, the part where the wire cluster for the right leg goes into the leg from the hip had the charictaristics of being mangled by a dog, minus the slobber. the bad chinese wire batch plus the constand rubbing if the leg plate had cause the wires to be exposed and crossed with each other, i fixed it by sealing each wire in electrical tape and binding the whole cluster in zip ties, and putting the leg back on, he worked perfectly.
i just thought id post this information because the "bad motivator" problem and the crusty wire insulation problems may be linked. as it was for me.Hope This Helps.
Mar 29, 2017 | Toys
Just bought a used WowWee Robosapien Humoid Toy Robot with Remote Control and need help in operating the robot. Are there instructions/manuel available to download?
Hi, first be aware that there are three models of Robosapiens, the V1 (13" tall), V2(23" tall), and RS Media (23" tall with video screen on chest). The WowWee website has the manuals for the Robosapiens and they can also be found at several independent forums). Here's the link to the Robo V1 support page where the manual can be downloaded from: http://www.wowwee.com/en/support/robosapien. You'll see a drop down menu "SUPPORT BY PRODUCT" to get to the other manuals. You can also fins a lot of help at forums, I'd recommend starting at http://www.robocommunity.com/forums.
Good luck,'
John
Jan 30, 2011 | Toys
My son just received a robosapien for Christmas. I put batteries in it and the remote. The eyes only light up. The robot does not move or speak. The robosapien my son received is about 2 feet high,...
Sometimes the robot may get stuck in sleep mode. Press the power button on the robot's back (by his shoulder blade) once, and if nothing happens, wait 2 seconds and press it again. The Robosapien should begin its wakeup procedure.
Jan 06, 2011 | Wowwee Mini Robosapien Humanoid Robot
The WowWee (RSD2) Robosapien V2 Robot remote worked for 5 minutes after I started working with the robot and then quit never to work again. The LEDs do not light up as buttons are pushed. Of course the...
Open the Robot, and check the cables, this Robosapiens V2 has a well known problem with the wire harness that go from main board to the bateries trough the legs. They have a major problem in the wire insulations that crumbles and short the wires. No easy solution exist. Yo need to rewire by your own or accept that will never work again.
Oct 13, 2010 | Wowwee Toys
Hi,is there any chance i can buy the instructions for the robosapien v2? many thanks
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Oct 10, 2010 | Wowwee Mini Robosapien Humanoid Robot
Defective candian robosapien wowwee robot
did you send to official wowwee company in canada? did you email wowwee support canada? its a shame nearly ALL robosapien v2 have problems:( mostly to do with bad quality materials i.e wiring & bad quality screws & bad quality design flaws in general- its strange wowwee robots have only 90 days warranty :O & some have 180 days max warranty. there is a robocommunity forum on net (search for it & ask your questions there)
Apr 21, 2009 | Toys
Sablon Robosapien Logo
359 people viewed this question
Top Sablon Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Sablon Toy Expert? Answer questions, earn points and help others
