Question about Whirlpool Refrigerators
We bought a new whirlpool 22 mssa, plugged it in, turned it on. Freezer works like a charm, fridge part warm as toast. Delivery guy said fridge has been kept upright the whole time. Anyone have any ideas how to fix it? Thanks
  • 139 Answers
SOURCE: Freezer ok fridge warm (15 degrees)
You have a hotpoint mistral f/f i take it in silver..
Check to see if the fan is running at the bottom on the back of the fridge its next to the compressor behind the panel ...
if the compressor is running and the fan is not then your fault is the fan..
IF the fan is running then its the sensors...
These are located in the freezer section, pull out the draws and remove the panel behind it.... six screws.......... you will c threes plugs at the top ledt hand side.. the yellow one is for the fridge the green one for the freezer.... replace both if your freezer is not working...
Also just below the freezer door there is a panel remove the panel and use a vaccumm to clean the fluff that has built up on the coils..
hope this helps if you need anymore help dont hesitate to ask...
by the way the sensors are called evap thermistors...
Posted on Jan 11, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool Freezer doesn't freeze?
insulated or not, garages are generally too cold for new energy efficient frigs to operate. ambient temp needs to be above 60 to work efficiently.
Posted on Mar 08, 2008
  • 4 Answers
SOURCE: Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech.
Posted on Aug 15, 2008
  • 57 Answers
SOURCE: WHIRLPOOL CB18M FRIDGE FREEZER
3 things to check. If you didn't adjust the damer from the freezer to the refrigerator, like closed it off. Is the freezer fan running? The fan blows air from the freezer to the refrigerator section. Some fans shut off when the door is open so you may have to push in the door switch to check this out.
Look for ice on the back wall, of the freezer section, If present then the defrost cycle is not working. The evap. coil is icing up and there is no air blowing into the refrigerator. Set the thermostat back to the normal setting it just causes a longer run time on the freezer section.
Posted on Oct 20, 2008
SOURCE: Whirlpool American Fridge Freezer Clicking noise
my whirlpool amerian side by side it has got warning sign on with a ! at it has stop frezzing
Posted on Apr 19, 2010
Testimonial: "Thanks very much for your help, really appreciate it "
MCBR415SF magic chef fridge or freezer not cooling
Return it to the seller. Obviously the condition was misrepresented.
Jan 17, 2014 | Refrigerators
I have a Whirlpool wbm46mw Fridge, the freezer is working ok but fridge not getting cold, any suggestions,Thanks
Empty fridge and if possible put steam down vent behind the cover in the freezer section. or hot water. it will com out in the fridge so be carefull. this unblocks the aif feed from the freezer to the fridge section. also make sure the fan is working.
Oct 04, 2013 | Engel Freezer 22 Qt. Fridge/Freezer
I have a RFG297ACRS (Canadian Model of AARS). Bought new and delivered yesterday. Waited 2 hours before plugging it in as directed by the delivery guys. Plugged in 24+ hours ago but until now it's still...
must be on demonstation mode, manual says the following: press ENERGY SAVER BUTTON AND FREEZER/HOLD 3 SEC FOR POWER FREEZER BUTTON simultaneously for 3 seconds until an alarm sound is heard.
Jan 05, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Clicking sound and warm temps
Sounds like the compressor is frozen and won;t turn. a slight chance that it starter relay is bad, you will need to get a repairman to check it out.
Jul 26, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a 22 yr old top freezer fridge. I took it to my cabin last year when I bought a new one for the house. However, it does not work-get cold at all. We don't leave the electricity on when we are not at...
ok Sounds like a place i would love to go but .... First, if the trip to the cabin was very bumpy chances are it sprung a leak and lost its gas charge , if this is the case , repairing it may cost more than replacement depending on the location of the leak , if the trip up to the cabin was smooth then consider this, When moving it around to load it up did you maybe move it around suddenly , and if you did this too would cause a leak specially considering  the age of the system, chances are its lost its charge and would require leak testing and repair , here in Australia anywhere up to $ 600.00
May 11, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Feb 22, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Feb 01, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Whirlpool gold gd25df Fridge/freezer warm
Your fan in the freezer is wearing out. When your food in the freezer is blocking the air, the motor is working too hard. After years of using, it needs to be replaced. Get a repair man in to replace with a new parts. My Fridge/Freezer was totally broken and I found this out because the ice was melting. It got fixed and now no problem.
Aug 06, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer too cold, fridge to warm
so what is the problem or question? talk to th company u bought the refrigerator from and deman and refund or replacement
Sep 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
104 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
