Question about Nikon N6006 35mm SLR Camera
Will the autofocus works on N6006 if I put on a DX lens?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Yes, the autofocus should work. However you'll likely get vignetting on your photos because a DX lens is designed to cover a smaller area than a frame of 35mm film.
Posted on May 09, 2014
Autofocus on Nikkor 18-55mm lens doesn't work
probably you have problem with the focus motor, i ever have same problem and need to replaced the focus motor.
Jun 08, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Error: FEE on Nikon AF N6006 film camera with Nikon lenses.
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body, the same way as with a lens without an aperture ring.
Feb 05, 2013 | Nikon Used N6006 AF 35mm SLR Autofocus...
What lens can I use the the Nikon N6006 35 mm SLR Camera?
The Nikon N6006 will use just about any Nikon F-mount lens made in the past 55 years. About the only exceptions are some rare (and very expensive) fisheye lenses and the newer DX lenses specifically designed for digital cameras.
Jan 11, 2013 | Nikon N6006 35mm SLR Camera
Nikon N6006 will not autofocus.
If you have more then one autofocus lens, is the problem limited to one lens only? if it turns out that the camera needs professional repair (and it may), keep in mind that an N6006 body is currently available on E-bay for $35 (buy it now price) and an N8008 is only $40 (buy it now).
Sep 18, 2012 | Nikon N6006 35mm SLR Camera
Autofocus stopped working
I fix these all the time for this problem, The focus motor is bad, Tony
May 23, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Apr 16, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
I just bought the Tokina SD 12-24 F4 (IF) DX wide-angle lens for my D70, and it does not autofocus. I'm being told by the company I bought it from that i am past their 2 week return policy. Does this lens...
Only the MkII version of this lens has an autofocus motor built in, the MkI relies on a motor in the body of some Nikon AF SLRs to autofocus. The D70 does not have an inbuilt AF drive motor, so if you have the MkI lens then you can only use it in manual focus mode on your camera.
Aug 03, 2009 | Tokina 12-24mm f/4 Pro DX for Nikon
Lens works fine in manual focus on Nikon D5000 but won't autofocus.
The D5000 needs an AF-S lens to autofocus.
Nikon have not fitted the mechanical focus drive to the D5000.
Jun 22, 2009 | Nikon 10.5mm f/2.8G ED-IF AF DX Lens
Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
May 24, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Apr 19, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Nikon N6006 35mm SLR Camera Logo
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
