Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
Why does the belt on my hoover UH70120 keeps falling off?
2 Suggested Answers
renevacdoc
  • 84 Answers
SOURCE: The belt on my hoover will not stay on. It falls
Okay. I would suggest that you have a problem with your roller brush. If the roller becomes clogged with hair/debris, the bearings will sieze, and sometimes even melt the plastic. the roller then has a difficult time turning and will break the belt. If the belt is slipping off, I would suggest that you either have a worn belt, the wrong belt, Or, your "windtunnel" (the half cylindrical insert the roller sets in) is missing. this insert has a "belt guide" that keeps your belt aligned. hope this helps!!!
Posted on Jul 18, 2009
How do I replace cord rewinder on Hoover UH70120?
You should not try this on your own. Take it to an authorized Hoover warranty repair center near you. This is not an easy job and is usually not worth the expense if the machine is out of warranty anyway. If it's within the warranty period, warranty will cover it. My shop is a Hoover warranty center and we have replaced a lot of these.
Dec 17, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
Where is belt for ul70120 found
Hi there! The belt for the Uh70120 can be purchased from Hoover.com directly or from an authorized service center. This unit takes belt number 562932001. Below you will find a link where you may go to purchase the belt, as well as a link to our service center locator.
http://bit.ly/1lzmUv1
Service Center Locator
Hope this helps!
Aug 12, 2014 | Hoover Vacuums
How do i remove the rewinder on a Hoover UH70120
Since you felt the need to ask this question, you are obviously not qualified for this level of repair. Take it to your local vac repair shop. If you have had your machine for less than 1 year it is still under warranty. If it is over 1 year old it is probably not worth fixing. New Hoovers are designed to last only one year and toss them ( as are most all bagless vacs for that matter ).
Jun 25, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
Why won't it suck
Hey there! It's possible that you may still have a clog in your vacuum somewhere. The filters can also cause the vacuum to lose suction. Try these steps to restore suction to your cleaner.
1. Remove the dirt cup canister from the vacuum. Remove the dirt cup lid.
2. Remove the primary foam filter. Rinse the filter under running water until it runs clear. Allow 24 hours to air dry outside of the vacuum.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash) Filters should be replaced once a year.
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Remove the bottom plate and brushroll. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
6. Check that the brushes are still spinning. If not, replace the belt.
Hope this helps!
Jun 20, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
Belt falls off Dirt Devil upright
I have a Hoover canister vacuum it works great.
I think you have the right idea. Good Luck!
May 15, 2017 | Vacuums
Power cord will not come out
There is probably a crossed cord in the rewinder. I am not sure but if you can get into the rewinder you can free up the cord it should go, hope this helps. Chris
Feb 07, 2011 | Hoover UH70120 WindTunnel TSeries Rewind...
Only a month old and it won't turn on anymore
Check Hoover's site to see if your's is under there recall. There's a problem in the cord rewinder. Mine had same issue.
Dec 29, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
How do you replace the belt on this vacuum cleaner?
At this URL:
http://www.ereplacementparts.com/hoover-uh70120-windtunnel-series-rewind-vacuum-parts-c-37315_37337_37514.html
you will find an exploded view of the vacuum you have. There is also a list of the comparable vacuums in the same family. I did not have time to do it, but if you check the comparable vacuums you may find a video on how to replace the belt.
If you find this solution helpful, I would appreciate a Thumbs Up rating from you. Thank you. Paul
Sep 23, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
Hoover UH70120 WindTunnel TSeries problems with the cord. im a tech savy guy and have been trying to fix a cord after it was pulled to far out and now wont auto retract, but just cant find a way to pull...
You will probably have to replace the cord winding mechanism. I have never had any luck trying to repair one. Cord retracters are great when they work but it seems like they always go bad before too long. On many units you can't even replace the cord if you get a bad spot in it, you have to buy a new cord reel which can get expensive.
Jul 21, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
Jul 18, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
203 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
