Riso EZ 331 A shows error code A-16
Cannot open Master to make new master and cannot print the previous Master, Shows paper jam at no. 2 (drum), but nothing is there. Please help.
  • 34 Answers
SOURCE: Riso Rz 220
Remove the master that is on the drum. Then check the master roll remove it cut about 18 inches off then re install master roll. hit the reset, then print bottons.
Posted on Jul 30, 2008
  • 4 Answers
SOURCE: Riso GR3750 T1 error Drum Jam
I had this problem too: just unlock the hook under the drum; disengage the drum then pull out the drum; then check the home position if not in position open the behind cover, pull the belt until you get the puller to the home position. You will get the same problem if you will not put the main drum puller to the home position. chimuntu@yahoo.com
Posted on Jan 24, 2009
  • 5 Answers
SOURCE: Error Code T14 on Riso GR3770
press reset .. is drum in home pos. ?
Posted on Feb 09, 2009
micromatikal
  • 2777 Answers
SOURCE: Riso RP 3700 indicates that the master is still on
It honestly sounds like the unit is going to need some repair work. All the types of troubleshooting possible have been done by the looks of it. It's a hardware problem which is impossible to repair remotely.
You can call Riso at 978-777-7377 to find the nearest service center.
Sorry about that.
Thanks for your patience and understanding,
Tim
Posted on Aug 12, 2009
  • 76 Answers
SOURCE: What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Posted on Oct 08, 2009
Riso cr1610 cannot cut master and it shows me e25 error code, what must i do to clear code
Replace light absorbing sheet (Black strip) on Drum screen sheet & also clean master position sensor , master loading sensor
Jun 19, 2014 | Riso Office Equipment & Supplies
Riso EZ 200E model gives error message A-01 -211
A-01-211 basically means there is master material under the position sensor while in standby. Referring to the manual open the master drawer and clamp rewind the master material back on it roll and close the lid/clamp. This allows the master unit to reset or to say "return home" action. Now open and re-insert the master material in its proper place. This is similar to A-34-218 code.
Nov 07, 2013 | Riso RZ220 Duplicator
Riso ez 200 the code A02 -509 continue to come up
It means that
"Master-loading sensor was OFF when the master was checked at a specified drum angle during the master-loading operation."
Sep 24, 2013 | Riso RZ220 Duplicator
Riso Rp3700 won't print from computer
We suffer the same issue. Have you find the solution?
May 02, 2013 | Office Equipment & Supplies
Riso EZ 570 e "T12-301" error. What is this error
check master disposal box. take it out and check for jams
Nov 01, 2011 | Riso RZ220 Duplicator
I have the d17 error message. I did try to reset it but it still shows the error.
D17
236 - incorect master roll
237 - master roll undetected
238 - master roll communication error
239 - wrong master roll detect
241 - detected a mismatch in master roll information
you must stop the machine and remove the cable from the print drum PCB and check that there is no ink on the connector or the PCB.
If there is no ink try to enter in test mode and activate 0890 test.
If it dose not work call for tech from Riso.
Dec 01, 2010 | Riso RZ220 Duplicator
Displaying A05-305
make sure that you empty the master disposal box...
also check for this sensor. if it is not present you will need to have it replaced
Jun 12, 2009 | Riso RZ220 Duplicator
A05-304 error & Top section of page cutting off
the thing might be down to an old master stuck to the drum this could cause the faint copies and the missing print.. pull the drum out check under the master.this would also cause the paper to jam on exit. the error is for no master eject check the calmp is free where it grips the master and also the path for the master eject to the waste bin
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
I had a Master jam while making a new master. Code A-04-303
Under the drum and master unit is there a round openning .Take a sckrew driver and push it in there to unlock the master and drum.Remove the jam and switch riso off and on.
Jan 16, 2009 | Riso RZ220 Duplicator
jasbo
jasbo
