Question about ASUS 90-A4C1K1000 Keyboard
Have an Asus laptop and don't know how to turn off the numeric overlay. i know you press the Fn function key but unsure what other button i should press with it
  • Anonymous May 15, 2009
    No it doesn't Fn+F11 lowers the volume on my ASUS. Someone else mentioned the Num Lk key but that doesn't work either.
  • 741 Answers
FN+F11 will turn off the NumLock key on an ASUS..
Don't forget to rate this 4 stars before you log out.
Posted on Jan 19, 2009
Fn+num lk not working
There is no standard meaning to any Fn +Fx key combinations. It depends on the manufacturer and the laptop model.
Usually the Fn key works in combination with the Function (Fn) keys F1-F12, and maybe ESC.
In my Toshiba, there is an overlaid numeric pad that can be activated by pressing Fn +F11. Once the sequence is pressed the F11 key led remains lit, and the overlay active. Pressing the F11 key restores the normal keyboard. Fn+Num Lock does not do anything.
Please check you laptop's manual to familiarize yourself with the uses of the Fn key on YOUR computer.
Dec 19, 2013 | ASUS Eee PC 1000H Laptop
Keyboard of myASUS K50IJ-XA1 15.6-Inch Versatile Entertainment Laptop (Black) is locked How to unlock the same? Kindly help
Well, do you mean only the keyboard is locked? Can you boot the system properly? Is the mouse working? Which Operating System is running on your Laptop?
Here are a couple solutions you can try before you let me know the above queries.
1. Press and hold down the Windows Logo key on the keyboard while pressing the L key on the keyboard once. In other words, Press Windows Key + L once. If this doesn't work, don't forget to include the Fn key while pressing these two keys. Windows+Fn+L. Still nothing?
2. Turn off the Machine, remove the battery and unplug the charger. Leave it for at least 10 seconds, you can press the power On button on the laptop without the battery and the charger installed/plugged in. Now re-install the battery, and turn back On the machine. It should work.
If you need further help, if the problem persists, Let me know with the details.
Good Luck.
Thanks for using FixYa.
Jul 24, 2011 | ASUS K50IJXA1 156Inch Versatile...
I need to know what the keys f1-f12 keys usage.
The uses for the function (f1-f12) keys varies based on which program you have open at the time. Different programs use them for different things.
However, your computer also has some default uses for these keys when combined with pressing the fn (function) key.
fn + f1 locks computer
fn + f2 changes our power use profile
fn + f3 puts the computer to sleep
fn + f4 puts the computer into hibernation mode
fn + f5 changes the display/output mode
fn + f6 decreases the screen brightness
fn + f7 increases the screen brightness
fn + f8 enables/disables wireless connections
fn + f9 enables/disables the touch pad
fn + f10 turns the cursor overlay on/off
fn + f11 turns the numeric overlay on/off
fn + f12 turns scroll lock on/off
May 05, 2011 | Toshiba Satellite Pro L300 Notebook
I have an Asus X58L laptop, For some reason there is a letters lock and I do not know how to unlock it. So if I press letter u it gives me 4, if I press p it gives me - and so on, unless I press Fn button
It sounds like you have the num lock switched on, most laptop keyboards are too small to have a separate numeric keypad so use the letter keys on the right side of the keyboard for this. (you should note numbers as well as the expected letters on the face of these keys).
To turn off the num lock, hold down the Fn key and press Ins. (located top right of the keyboard).
Jun 27, 2010 | ASUS Laptop Keyboard for Asus Eee PC
My dell laptop types numbers instead of letters on some keys without pressing fn key
If you Are writing numbers instead of letters when you press the keyboard of your laptop and you must hold down the Function key (Fn) to write normally.
This is due to the fact that the digital lock is activated. To solve this, simply press the Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
Hope This Helps
Feb 27, 2010 | Dell Vostro 1510 Laptop
Unlock numeric key pad on lap top
your laptop should have a blue FN key (Function) that will work in conjunction with other blue keys on teh keyboard. most laptops this is located in the lower left, next to the ctrl key. Look to the right top on your keyboard for a one labeled numlk. hold down teh left FN key and tap the right num lk key and you just turned off the numbers lock.
There is another option that is a little more intense - if interested let me know that laptop type you have.
Feb 04, 2010 | Microsoft Windows XP Professional
Numeric Keypad
if you search on the keyboard keys there will be one key that says "NUM LOCK" on it pressing which you will be able to turn on or turn off the numeric keypad on the keyboard.
Apr 22, 2009 | Computers & Internet
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Keys are locked on Toshiba Satellite Laptop
hold fn then hit f10 = turns cursor control overlay on/off
hold fn, then hit f11= turns numeric overlay on/off.
hold fn, then hit f12 = turns scroll lock feature on/off
Please remember to rate all users who assist you for free :)
Sep 03, 2008 | Toshiba Satellite A105 Notebook
Asus w2v laptop keyboard problem
wow thats just reversed i wthink its a new design
thank u
May 27, 2008 | ASUS W2V PC Notebook
Computers & Internet Logo
1,305 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
