Question about Refrigerators
High temp alarm keeps going off
I have a Kenmore Freezer model #253.23082101. And the high temp alarm keeps going off every 8 to 12 hours for 4 weeks now. I have replaced battery with 5 different 9volt batteries and it does not have a on off switch for alarm. How do I fix this. Tired of waking up at 2 am to shut alarm off. Food is frozen and ice cream is like a brick. Temp gauge i put in freezer reads 0 degrees any where in freezer.
icansurf
  • 72 Answers
SOURCE: Freezer set at 0 degrees, but runs at 19 degrees. Ice Cream melting...
Low on freon/refrigerant maybe.
Posted on Mar 03, 2007
  • 942 Answers
SOURCE: Will not make ice, freezer temp is high, can not control the temp
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Posted on Apr 01, 2010
  • 333 Answers
SOURCE: high temp in food compartent freezer is ok
Try cleaning the dust out from under the fridge and the back. This worked for me
Posted on Apr 06, 2010
aasc
  • 1606 Answers
SOURCE: ice melting in ice maker
Remove the food from the lower shelves , so the inside rear lower freezer panel can be removed ( only 2 or 4 screws ) .
The # 4 thermistor or # 5 thermistor is bad . # 4 tells the main control board , the temp of the coils , if they need defrosted and when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off / on , due to temp setting .
Posted on May 09, 2010
heatman101
  • 43501 Answers
SOURCE: sidex side 26 cf... 5
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
High temp alarm
Good Afternoon Friend,
I see that you have the High Temp alarm going off on your Frigidaire refrigerator. First, you will want to press the Alarm Off button to turn the alarm off. Next, you will want to press and hold the Factory Default button to put the temperatures at 0 degrees for the freezer and 37 degrees for the refrigerator. Wait 24 hours for the temperatures to stabilize. If you are still having trouble with the alarm going off, reset your appliance by either unplugging it or shutting the power off at your homes circuit breaker for 2-3 minutes. When power is restored, you will need to press the alarm off button. If the High temp alarm is still going off, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Refrigerators
Whirlpool High Temperature Alarm Keeps Blinking
New Refrigerator / Freezer usually takes up to 12 hours to get the food down to temp and the inside air temps to stabilize...
Now, try explaining that to a BSN who is required to take hourly temp readings on a refrigerator and just loaded it half full of warm soft drinks and is opening and closing the door repeatedly retrieving supplies.
You lower the temp to "suit" (shut 'er up) and tomorrow they're calling you back because it's too cold...
Apr 13, 2014 | Whirlpool Refrigerators
What is causing the HIGH-TEMP ALARM to go off?
please set it in normal temperature maybe it is set to high temperature
Jun 17, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
The high temp light is on. What can I do to reset it? Everything seems frozen and fine in the frezzer
HIGH-TEMP ALARM SWITCH (SOME MODELS)
An audible
alarm will sound if the freezer temperature reaches
unsafe levels. The alarm operates on household electricity.If
the power
fails, the alarm will not perform.
An ON/OFF switch
allows the high temperature alarm to be
deactivated if desired. NOTE: You must open the
freezer door to
view the alarm switch. The
freezer is shipped with the switch in
the OFF position.
After the freezer has run longenough to
lower the temperature, you
may set the switch to the ON
position.
To activate the alarm, set the switch
to the ON position.
To deactivate the alarm, set the switch to the OFF position
i got this from the freezer manual from Kenmore hope this was helpful
Mar 28, 2010 | Kenmore Freezer 13.7 cu. ft. Upright...
Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Feb 05, 2010 | Freezers
Do the kenmore refridgerators have a daily defrost cycle? If so, how long does it last and what is the temperature fluctuation? The freezer is empty right now, and the temperature fluctuation seem to go...
All refrigeration products have a defrost set point. Most residential units defrost about every six to eighteen hours. This process should take about 30 minutes to 1 hour. The temp goes up so high inside because there is a heating element in the coils to thaw any residual ice. The temp should not exceed about 45 degrees though. If it does the the compressor is signaled to come back on and start cooling again. This is perfectly alright. The time at higher temp is not enough to spoil the food. Hope this helps. Good luck.
Nov 18, 2009 | Kenmore Refrigerators
FREEZER ALARM WILL NOT SHUT OFF
Use a freezer thermometer and tell me the actual temperature. Or at least store some ice cream and see if it stays brick hard. Unless I have some idea of the actual temp I can't tell if defective freezer or alarm
May 11, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Dec 28, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
