Question about ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard
ASUS P4B motherboard problems
I have 2 P4 Asus P4B motherboards and the issues I am having is that it wont read harddrives or allow you to load an operating system on them. When I scub the HD's it works great, but when I go to load the XP disk, it freezes when gets to the point of " installing windows"......I have tried flashing the bios and resetting and upgrading the bios with floppy and it wont even take the floppy. Is there a security thing I am missing?....I have disabled the virus in bios....tried all dif HD's, which I can load anything on to HD's from any other pc.......tried dif roms......dif ram....nothing seems to work for getting it to load an OS. Please help if you can Rick
  • 1 more comment
  • Rick Cronk Jun 28, 2007
    Hi Sandrew....yes ...have tried 3 dif processors......it really wierd...never run into this in the 15yrs been playin with these things
    Thanks anyway
    Rick
  • Rick Cronk Jul 12, 2007
    Hey all....thank you for your tremendus help....I had been dabbling with it and found the problem....so far its been working fine and no glitches.....The problem was that it came with a 40 pin dma cable and takes a 80 pin udma cable.....the OS loads just fine and the pc fires on every shut dwn. I hope this helps others that might have experienced the same issues. Thanks again all
    Rick ( Chicoman2000 )
  • Anonymous May 09, 2008
    the same
Change the batterie
Posted on Jun 19, 2008
Virus scan running in my pc after scan i delete some threat in my my pc and after that i restart it after restart pc display & HDD LED is not is not working but cpu light & Mother board led is working my board is ASUS P4 please what can i do now
Raju
delhi
Posted on May 05, 2008
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
I had issues with this motherboard reading the 320gb drive i bought until i flashed it with the 2003 Beta version of the bios. Then i went into the bios and let it auto detect the drive, it takes a few mins sometimes and i had to go to the drive boot order too to get it to detect, it would say none, and i would go back to the drive section and set it to auto etc. But when it did find it, i took down they cylander, head numbers etc it auto found and put in the values manually. Then I would set it to throughly check at boot up, so it does the ram test a bunch of times also hitting pause right at ram check delays it enough too to read the drive. I have no idea why this is, but thats how i got it working. I just leave the machine on now.
Posted on Jul 11, 2007
    President:
  • 2,961 Answers
I had the same problem a couple of times,have you tried another CPU as this points to the fact that the processor is faulting.
Posted on Jun 27, 2007
SOURCE:
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
ASUS P4B not recognizing the display card
make sure you install the driver of your video card, and if still have the same problem try to use a diff workin video card, if you will be havinG the same issue if miht be the port of your motherboard where your display card is connected and it only means that the motherboard is faulty and you need to replace it
Jul 25, 2010 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
Graphics card problem
Your motherboard uses AGP for graphics card. Here's a link for full specs:
http://www.dealtime.com/xPF-Intel-Asus-P4B-M-Pentium-4-Socket-478-Intel-845-Motherboard-P4B-M
Jun 10, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Asus Motherboad P4B screen
I think the problem is on your motherboard, because in this time windows is not loaded yet. So, check out your motherboad, or take it to service center (if you have no experience in hardware fixing)
May 15, 2009 | ASUS (P4BGV-MX) Motherboard
Can I use Pentium 4, frequency 3.0 GHz with Asus P4B?
Asus support says the fastest CPU you can use in that MB is a P4 2.6 GHz or a Celeron 2.8 GHz.
For the P4 you need BIOS ver. 1011 and for the Celeron you need ver. 1013.004.
Here is a link to the entire list:
P4B CPU Support
Thanks for using Fixya.
Apr 14, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Confused about the motherboards
just go to market for repairer and he wil do this
Dec 07, 2008 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Asus P4B 1.7 mhz P4 motherboard restarts every 10-15 minutes...
Check the CPU temprature from the BIOS. Sometimes if the CPU overheats the system will automatically reboot. High CPU tempratures goes form (60-70). You can also monitor the fan speed and cpu temprature using this utility
http://www.almico.com/speedfan.php
Oct 27, 2008 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
Lost motherboard driver of asus
i want a diver sound for motherboard asus P4B-M
Mar 03, 2008 | ASUS P4B266 Motherboard
ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard Logo
703 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
