Question about Dryers
The Simpson autosensing 1350 sr dryer overheat. The filters an outlet is clean,
The dryer overheat.
4 Suggested Answers
  • 2468 Answers
SOURCE: My Simpson Maxidry 362 dryer
if its the high-limit thermostat safety device your talking about,take a jumper wire of the appropriate size and bypass it and see if the dryer runs then,if so then just replace the thermostat
Posted on Nov 21, 2010
  • 3074 Answers
SOURCE: The gas dryer works on
your post did not say if you have removed the vent tube and ran the dryer in any of the auto-sense cycles, I would do this first. If it runs normally with the vent disconnected then the vent is restricted. if you have already tried this then the reason it may not be working is that the wires(either blue or green) behind the sensor bars is/are disconnected/broken. There is a diagnostic mode you can enter to test the control's ability to sense the bar contact that is illustrated in the tech sheet which is located within the control panel, when you are in the diagnostic mode touch the two wires of the sensor together and if the light illuminates, it means the wiring to the sensor block and logic of the control is good. If the light doesn't illuminate, then either the control is bad or one of the blue wires is broken or not connected at the control. Hope this helped Tim
Posted on Mar 12, 2011
heatman101
  • 43501 Answers
SOURCE: I have a Simpson autosensing
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101][][
Posted on Aug 12, 2011
Flashing check filter I have and cleaned all filter, but the dryer is still not drying.
Have you cleaned your outlet vent tubing? Cleaning filters is just one part of really cleaning your dryer. You have to clean your dryer vent from the back of your dryer. Disconnect the vent from behind your dryer and use a shop vac to suck out any lint that mite be built up. Blocked lint tubes are #1 cause of dryer fires.
Hope this helps
Jun 29, 2015 | Dryers
I have a Simpson autosensing dryer. I moved it and now doesn't dry. It goes but no heat. When I moved it I tilted it by mistake
heatman101][][
Aug 11, 2011 | Dryers
I need to replace a simpson sirocco lint cover spindle Do you no where i could purchase one. the plastic casing on the spindle has broken and the lint cover will not stay on.
I'm not sure where you can get one as i am in australia but an appliance spare parts outlet should have one or order it in for you,alternatively try simpson or electrolux.
Jun 01, 2010 | Dryers
The dryer is overheating and dont seem to deduct any water. After about 10 to 15 minutes the dryer stops by itselfs. I have cleaned the filter throughly so that is not the problem
Something is blocking the air flow and the overheat safety is stopping the dryer. Check the exhaust duct all the way to the outlet to make sure it is not clogged. If the duct is not clogged and there is no air flowing the blower fan may be disconnected from the motor shaft.
Jan 17, 2010 | Washing Machines
My dryer get to hot is simpson maxidry 505
sounds like it needs to be cleaned out,check outside to seeif the flapper is blowing open or if it is clogged with lint,if you have a leaf blower take vent line off of back of dryer and blow it out,vac inside of dryer and clean out the lint filter duct,if it's gas you should do this every year so you don't have a fire,electric every two years
Nov 08, 2009 | Dryers
Clothes dryer stops
sounds like the drive belt has stretched, or the auto tension is low.
disconnect power and remove back cover, clean inside around motor resitor block wires, and inspect/ replace faulty components. good luck!
Jan 30, 2009 | Dryers
My DBSR453EBww dryer shuts off before the clothes are dry.
Possibly the motor is overheating due to lack of ventilation, or the lint filter requires cleaning, make sure the outlet is clear at the rear of dryer, and that the vent hose (if fitted) is not kinked.
You could also have a problem with the motor itself which is causing it to overheat and the cutout is stopping the motor from working until it cools down enough to start again.
Plz rate my solution.
Thanks.
Jan 03, 2009 | GE DBSR453EBWW Electric Dryer
Simpson dishwasher intermitantly does not wash properly, i think it doesnt always fill correctly
Make sure the filters are clean and that the spray arms do not have food particles blocking the outlet holes. Always a good idea to rinse these off plates before they go into the dishwasher.
Aug 10, 2008 | Dishwashers
Dryers Logo
154 people viewed this question
Top Dryers Experts
