Question about ASUS A8N-E Motherboard
Asus A8N-E failing? Chip fan dead?
Hey folks...so my computer has been "broken" for a few weeks now and I'm starting to think it's the motherboard. For a couple weeks I would get an error message before I started up my computer saying they're might be a problem with a Chip fan...I didn't really know which fan it was implying and didn't think much of it, because when/if I pressed f1 and exited that troubleshooter, it would just boot up like always/normal. After a while my computer had trouble starting up and would only start up every once in a while after so many tries. Now when I try to turn it on, you hear the typical sound of a mini turbine engine starting up, and when it's about to peak and start up the mobo or the whole system, you hear a "bzz" and it doesn't start it up....all the fans spin, all the LED lights are on....the whole thing gets power...the psu is good (and brand new because I thought that was the problem)..but the little chip fan on the mobo doesn't spin....is my mobo broken?
  • 1 more comment
  • ryan696 Jan 19, 2009
    That was a pretty poor response =/
    Anyone with some knowledge of this problem and some knowledge of the english language please help
  • Anonymous Feb 19, 2009
    Same problem, battery?
  • bradrylexi Mar 07, 2009
    my board has the same problem and so i bought a a8le board to replace a8ne board , just wonder if it will work
    President:
  • 2,692 Answers
The CPU fan need to be replaced and the CPU may now be damaged for overheat.
Posted on Jan 19, 2009
  • Thomas F. Schneider Jan 20, 2009
    Reality is hell, isn't it. I didn't burn it up, you did.
No video after replacing chip fan
Try a different video-card -- a "no-spin" fan and "no-video" implies a dead video-card (or at least a video-card that is not "seated' properly).
Check that the PC-speaker leads are connected to the motherboard, so that you could hear any "beep" codes. There should be one "beep" to indicate 'OK', or multiple "beeps" (bad RAM, no video-card detected).
Apr 09, 2010 | ASUS A8N-SLI Deluxe Motherboard
ASUS A8N-SLI Motherboard - chip fan....how do you get this fan unseated and off the motherboard????
Go to the link provided from Asus;
http://estore.asus.com/shop/item.asp?itemid=231&catid=134
You will need to remove the motherboard to replace the fan & to reconnect a new one.
Instruction listed on the site.
Take your time & good luck.
Mike
Jul 10, 2009 | Computers & Internet
Warning: Your computer CHIP Fan Fail or speed too low.
soem times becasue of heat event system restart. Check your RAM also soem times it could be problem of RAM.
Jun 25, 2009 | ASUS A8N-E Motherboard
I have a burnt out fan chip and was told that I need to replace my mother board - it is an asus a8n-e where can I buy one
There is a problem with the Southbridge chipset. The nForce4 chipset over heats.
Asus has not made a better cooler for the nForce4 Southbridge chipset.
(It does not cool the chipset as it should).
You will have the same trouble with a new A8N-E MB.
Sooner or later if you do not change the chipset cooler with a stronger fan/heatsink assembly like any of the ones listed on the next link, the chipset will burn up.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=498&name=Chipset_Fans
Here is the link to Asus for a replacement chipset fan;
http://estore.asus.com/shop/category.asp?catid=133
Try this link for the board;
http://www.tamayatech.com/parts.php?i=A8NE
Here is the Google search link for the Asus A8N-E board;
http://www.google.com/search?hl=en&q=buy+asus+a8n-e&aq=2&oq=buy+Asus+A8&aqi=g6
Than click the link below for other compatible Socket 939 motherboards with PCI-E x16;
http://www.smarterdeals.com/hardware/goods-sc_id-4890.html
Thank you for trying FixYa
Mike
Jun 23, 2009 | ASUS A8N-E Motherboard
Asus a8n-sli deluxe long beeps
Are you absolutely certain that your chip is compatible with your motherboard?
Oct 01, 2008 | ASUS A8N-SLI Deluxe Motherboard
Cpu fan noisy /chip fan fail
You must buy a new CPU Fan. You can get them HERE or a zillion other places on the Internet. You need a Socket 939 type fan that will handle your cpu speed. If you need help installing it, it may be in the manual. You can read the manual by clicking on the picture of your MB at the top of this post and then scrolling down.
Hope that fixed ya...
Geno
Apr 01, 2008 | ASUS A8N-E Motherboard
Cup fan erro
Firt remove the covering of the cabinet then locate a battery take it out rub it for few seconds.Place it back the way it was.Now if you have another cpu fan port on the mother board then plug your cpufans cable to it.Now restart your computer start pressing F2 ie bios settings.Now check the time and date. restart it again. See if it fixes the problem.
Please rate me> Karatela ;-)
Dec 07, 2007 | ASUS A8N-VM Motherboard
Computer powers off during boot
Hmmm...try resetting CMOS & checking all external peripheral connections: (KB/mouse, monitor, etc.)
Oct 26, 2007 | ASUS A8N-E Motherboard
Audio outputs doesn't working
It sounds like a motherboard sound chip failure, although run a diagnostics on the sound, click Start>run, then type 'dxdiag', hit 'Enter' and run sound driver test. If it has failed, you can purchase a cheap PCI slot souncard and dissable your onboard sound, or a complete new motherboard.
Jan 04, 2007 | ASUS A8N-E Motherboard
ASUS A8N-E Motherboard Logo
404 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
