Question about Runco Lamp for CL-610 Projector
Runco cl-610 projector
Turned on projector and is making a loud vibrating noise, everything is secure, checked the lamp housing, lamp is in secure. Nothing about this in the owners manual. Fan light is not on.
    Problem Solver:
  • 9 Answers
Likely the fan blades are dirty and out of balance. If this projector is in a dusty or smoky place you will need to clean them (or have them cleaned by a tech) often. If you are not good with electronics, I suggest taking it to a dealer. If you can get the covers off properly, you will need use a can of compressed air to carefully blow out the projector and fan blades.
Posted on Jan 10, 2013
I have a Runco CL-810 projector, how do you clean the fan filter?
Filter will be located near the intake fan. You can remove it and clean it. Normally just blow out the dust. If it is oily you can use dish soap be sure it is fully dried before replacement. The fans you can blow out (with machine off) Be sure not to spin them too fast or the bearings will be destroyed.
Dec 16, 2012 | Runco Cl-810 Reflection Dlp Projector Lens
I have no power to my runco cl-710 projector.... no lights will come on regardless of the power cord I use. I have made sure the lamp cover is on securely and correct. any ideas?
The capacitors on the power supply need to be replaced. When you take apart the projector, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video. This is an easy repair.
Jul 18, 2011 | Runco Office Equipment & Supplies
My Runco CL-410 projector runs for about 30-45 seconds, then the lamp turns off. The hour meter says it has 471 hours on it. Any ideas?
Look inside the lamp. If you look into it if you see any white build up at its base, replace it. Need help, let me know.
Jan 09, 2011 | Runco CL-410 Multimedia Projector
Unit not powering up. New lamp installed but
a couple of things did you reset the lamp timer? Sometimes if the panel door lamp is open or not closed you will not be able to power up. Have you tried removing the lamp and reseating it? Perhaps the fuse is blown...you will need to remove the cover and look to see. fuse should be located in the area of where you plug the power cord again you will need to remove the power cord.
Jun 02, 2010 | Runco CL-510LT Multimedia Projector
CL-610 RUNCO PROJECTION SCREEN IS UPSIDE DOWN. Some one touched the remote control and I am at a loss to fix problem.
turn on your projector as usual, and using the remote, press the 'menu' button.
the menu will appear on the scree (albeit upside-down), and your looking for a setting like 'setup' or 'orientation'.
some runco's need a special code to get into some menus, but the orientation selection should be easy.
once you find the menu, there are usually 4 choices; front projection/floor mount, front projection/ceiling mount, rear projection/floor mount, and rear projection/ceiling mount.
the most common is 'front projection/ceiling mount'
Dec 08, 2008 | Televison & Video
Runco Cl 610 keeps shutting down
on the cl-610 it would shut down after about 5 minutes of running..as well as having to replace the customers bulb. so I took a look at the cooling system there are two fans which work fine, but there is a type of vent inside attached to the body of the projector it seems to have some back pressure if my words are right causing the fans to return the heated air back into the projector forcing the fast shutdown and lessening the life of the bulb. so as a test I removed the directional vent and I blew into it and most of the air came back rather that went out so I left it out and the projector has been running flawless for the last two days. might be time for a redesign on that directional vent cover. but check it for yourself first. if this has helpped please let me know.
Nov 27, 2008 | Audio Players & Recorders
Need to adjust from full screen to wide screen on Runco SC3050
You need to use the remote, press the Menu button... on the menu that pops up on the screen, use the remote to scroll down to where it says "aspect ratio", and then select enter.
From that menu, you can select all the different aspect ratios that your Runco can perform.
Here is a link for the owners manual, straight from Runco.
http://runco.com/legacy_prods/legacy_manuals/CL-510_510LT.pdf
Oct 11, 2008 | Runco CL-510LT Multimedia Projector
Projector problem
I have a great deal of experience with that projector in particular.
The burning smell along with the circle on the screen can be one of two thing in the same general area. Both are not good.
The lamp assembly has its own dedicated cooling fans. these fans can sometimes **** in dust and insects. the lamp runs at a very high temperature and can burn those things quickly. I have often found old lamps with particles fused to the glass.
The other situation is that the lamp burned something and it got stuck to the glass somewhere in the light path.
if I remember right the projector monitors the temprature of the bulb and will shutdown if it gets too hot.
Runco is based in california and has a great turn around time on projectors. Unfortunately with Runco you would be hard pressed to find a technician that wouldn't just send it to them for repairs anyways. The major down side with Runco is that customers cannot talk directly to engineers or service men.
Locate a Runco authorized retailer in your area, check runcoes site. and give them a call to see if they cant send it to runco for you. if you cannot find one in your area call Roscor or Blair & Associates in Chicago.
May 02, 2008 | Runco CL-510LT Multimedia Projector
Runco Lamp for CL-610 Projector Logo
173 people viewed this question
Top Runco Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Are you a Runco Office Equipment and Supply Expert? Answer questions, earn points and help others
