Question about Broksonic CTSGT8118T 13 in. TV/VCR Combo
Vcr recording speeds
My fuji tape has 3 recording speeds listed - SP, LP and EP. The menu on our 13" TV lists SP, LP and SLP. Is the SLP the same as EP listed on the Fuji tape?
Yes. SP is "Standard Play" and LP is "Long Play", while EP/SLP are short for Extended Play/Super Long Play respectively.
Posted on Jan 19, 2009
When playing back vcr tapes on my magnavox ZV427MG9 A, i have a tracking problem with tapes recorded on slp. i get white streaks on the playback, and manual tracking does not help. tapes recorded on s
The VCR has at least four "heads" two are for 2 hr and two for 6 hour (sp and slp)
It is most likely one of the heads used in the SLP mode is slightly blocked with tape debris--heads need to be manually cleaned in the right way.
Jun 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
I cannot find my manual what is the speed to record on the vcr for 8 hours
Unfortunately, most VCR recorders/tapes don't have an 8 hour option. It is 2 hours on SP (standard), LP for 4 hours or EP (SLP, depending on the unit) for 6 hours. (The slower recording speed usually gives poorer video quality.)
You would need a non-standard VCR cassette to get 8 hour recording. If you do have a tape that would hold 3 hours at SP, then use an EP setting to get 8 hours of recording on your VCR. I don't think I've seen any tapes that do that recording length even when VCRs were popular.
I wish that I had better news.
Jan 28, 2012 | Sansui COM311AD 13 in. Combo
I no longer have the original remote for my Samsung TV/VCR combo and am using a universal remote. Yesterday I started having problems with the speed of the VCR playback. Mostly, it is too slow, distorting...
U have play back problems on playback SP LP SLP modes tuggles problems.Try website like Remotes.com to buy the tv original remote,have these buttons to set the correct VHS tape play back modes tuggles problems.
Dec 11, 2010 | Samsung CXD2512 25 in. Combo
Hi - I can't switch my vcr speed from spl to lp.
On this combo, the vcr can play SLP, LP and SP but can only record SLP(6h) or SP(2h).
Apr 27, 2010 | Quasar VV-1311W 13 in. Combo
VCR LP/EP compatibility
Vdumitre -
No, not usually. If you've recorded a tape at LP and put it another machine that doesn't have LP, it usually won't play properly. Some machines that have only SP/EP will do this, but they are got scarce as more manufacturers dropped the LP speed. Your best bet is to buy an older one from a thrift shop or a garage sale, making sure that it will play LP. Then, copy your older LP tapes to SP or EP (Run the OUT from the LP unit to the IN on the SP/EP unit, and choose "record from line in", "aux", or "rear input").
Thanks,
videoman7
Aug 05, 2009 | Sony Televison & Video
Change VCR settings from SP to LP or EP
Hi;
I have a Panasonic VCR with a different, but I know how to 'fix' your problem on my m/c. The remote for my m/c has a "REC MODE" button; operating that button changes from SP to EP etc. Check it with the "Program" button on your TV screen.
harrisonmx3
Apr 27, 2009 | Panasonic Televison & Video
How to switch the tape speed on Go Video dvd/tape.
  1. Press SETUP,
  2. Toggle with the left/right arrow to the RECORDING OPTIONS (icon has a dot and the letters REC below it in the icon menus at the top of the set up screen.)
  3. While RECORDING options is selected, press the DOWN arrow to select VCR RECORD QUALITY.
  4. Press ENTER to go to the submenu.
  5. Use the ARROW UP/DOWN buttons to select the desired quality.
  6. Press ENTER to confirm selection.
  7. Press SETUP to exit the menu.
This is the same procedure for selecting the quality for the DVR recording speeds.
VHS speeds are:
SLP is 3x the recording time of SP.
DVR recording options are:
HQ=1 hour
SP=2 hours
EP=4 hours
SLP=6 hours
per disc.
Mar 18, 2009 | GoVideo VR3845 DVD Recorder/VCR
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
Codes
Those terms mean the speed that the VCR can record programs.
SP Standart Play >>> 120 minutes.
LP Long Play >>>>>> 240 minutes.
SLP Slow Long Play > 480 minutes.
May 06, 2008 | Funai FDRV90E DVD Recorder/VCR
How to set the tape lenght when recording
on older vcr's there should be a sp/slp or ep button on your remote or vcr. if not when you set a program to record, the option to choose should be there. sp= 2 hrs, ep =6 hrs.
wg
Feb 17, 2008 | Sharp VC-H810U VHS VCR
Broksonic CTSGT8118T 13 in. TV/VCR Combo Logo
317 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
