Question about Canon PIXMA MG5320 All-in-One Printer
Edible ink cartridges for MG5320
I am having a problem with the ink in the printer, it's not coming out and I cleaned the carriage but still having a problem
  • 189 Answers
I had the same problem and then found out that when I removed the "tape" from the cartridge, the part that was covering a small hole on the top of the cartridge was still "covered" which prevented air from allowing the ink to flow out.
It is a very easy thing to overlook but it did resolve my issue.
Posted on Apr 04, 2013
Error code cooo
Go To Below official Canon Printer Page For Your problem,
http://forums.usa.canon.com/t5/errors/FilterErrorHandlerPage Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Canon Printer Support
Mar 06, 2014 | Canon PIXMA MG5320 All-in-One Printer
How to remove & clean the Print Head
1.Turn on the printer. Open the cover to expose the printer carriage. Wait for 3 seconds and unplug the printer from the electrical outlet. The print cartridge will stay in place by unplugging the power.
2.Remove the ink cartridge from the carriage by lifting up on the tab holding each cartridge in place. Remove the ink cartridge by pulling it out and up.
3.Use a lint-free cloth to gently wipe the copper contacts on the bottom of the ink cartridges. If the residue is stubborn and won't wipe off, use a cotton swab dipped in bottled water to remove the residue by rubbing gently. Do not wipe the nozzle on the ink cartridge; wipe only the flat contacts. Lay the cleaned ink cartridge on it side on newspaper. Do not stand it upright with the copper contacts touching the newspaper or the ink will drain out.
4.Use the lint-free cloth to wipe the contact points in the print carriage. If the residue won't come off, use a cotton swab wet with bottled water to remove the residue. Wait 5 minutes after you have cleaned the printer contacts before replacing the ink cartridge.
5.Place the ink cartridges back in the printer cartridge. Snap down the top to secure the cartridges. Plug the power cord in the wall outlet. Close the cover. The printer is ready to use after running through the initialization.
***If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Apr 02, 2013 | Office Equipment & Supplies
Info printer :E
Any malfunctions its gives error 'E'... Check paper jam, carriage struck, cartridges faulty and service related issues.checking carriage:Switch on the machine check carriage(the unit carrying print heads)moving left & right.. if its not moving, it might be struck in service station(service station located at right end and its allow carriage to rest on it during shut down as well as its cleans the print head nozzles). power the machine pull carriage out gently, don't force it..Clean encoder strip: Encoder is located back side of the carriage and its guides carriage to move properly, if encoder became dirty you will get error message, clean encoder with smooth cotton cloth.
Feb 03, 2012 | HP PSC 1215 All-In-One InkJet Printer
My HP 940C printer won't move the ink cartridge
Symptom look like carriage jammed in service station,open cover gently try to pull carriage out if its jammed, open top & side covers, release service station capping through manually rotate gears, once its released, push carriage left side, remove service station & verify why its jammed, if found any breakage replace it, or clean it..but little bit technical skill required..see the similar diagram below:
Dec 22, 2011 | HP DeskJet 940c InkJet Printer
A couple days after replacing Maintenence Cartridge printer say's Missing Maintenance Cartridge & will not accept. Try to replace carriage & printer say's missing before door is even...
Hello ,you have change the cleaner also or not,if not then replace the cleaner & clean the entire unit by a blower.Also clean the encoder strip with a smoth cloth,clean the print head flex ckt with clean cloth,altough problem persists then replace the ink tube *** & encoder strip.
Aug 04, 2011 | HP Designjet Z6100 InkJet Printer
I WANT TO MAKE EDIBLE IMAGES FOR CAKE IS MY PRINTER MADE TO DO THAT IF SO WHAT CARTRIDGES WOULD I USE
ask for the edible ink cartridges i use to work with those in 2006. or you can google edible ink cartridge for .....(place your printer and model number after the word for)
Feb 28, 2011 | Canon Pixma MP480 All-In-One InkJet...
My magenta ink won't work. Have just replaced with new ink cartridge.
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Feb 06, 2011 | Epson Stylus NX400 InkJet Printer
Carriage stall.. clear carriage obstruction and press resume...
Jul 27, 2010 | HP cp1700 Color Inkjet Printer
Everytime I turn on the designjet 750c plus, it tells me to turn power off and check cartridge path.
Make sure you have the correct cartridges and that the tape has been removed.
You can try a new set of cartridges and see if that solves your problem.
I hope this helps.
Have a good day and good luck.
Nov 20, 2009 | HP DesignJet 750c plus InkJet Printer
Canon PIXMA MG5320 All-in-One Printer Logo
236 people viewed this question
old marine
old marine
