Question about HP Hewlett Packard LaserJet P3005n Printer
Servicing hp lj3005n
I have worked with HP LJ printers in the past but not any LJ3005. Recently purchased service kit for it but do not have enough instructions with it to install the various rollers and such. Just looking for a manual or diagram to show what needs to come off to get to the various items, thks!
  • 102 Answers
User please use this link and it will give you demonstration to tear down any of the HP Product,
Link will take little time to open however it should be very helpful for you if it is helpful please let me know
Thanks and Regards
Neeraj Sharma
Posted on Jul 03, 2009
  • Neeraj Sharma Jul 03, 2009
    Thanks and Regards
    Neeraj Sharma
Which one refill kit I need on this page?
HP Easy Refill Kit for (HP) Color Inkjet Cartridges Printer
Jul 10, 2012 | HP Easy Refill Kit for (HP) Color Inkjet...
Jam in tray 2
This is an update to:
HP LaserJet P4015 - Not Picking Up Paper
HP now recognise this as a manufacturing fault and have released a service note for it and will send you a new fuser free of charge. The description of the fault is:
When a print job is sent to the printer, the printer will display processing job on the control panel, and will continually ramp up and down attempting to print the job. After several minutes the printer will return to ready without posting any error messages. Occasionally, after several minutes the print job will print.
The fix for the fault is:
The fuser needs to be replaced and firmware needs to be upgraded to version 04.060.7 or higher.
The customer will need to download the latest firmware from, version 4.060.7 or higher. The firmware can be downloaded from hp at "" . Select Download drivers and software (and firmware) in step 1 and in step 2 type in the printer name, LJ P4014, LJ P4015 or LJ P4515
It's probably best to update the firmware before you phone HP to report the fault, or at least tell them you have. If you do update the firmware, you will notice some extra numbers and letters on the display when the printer initialises. This is normal, it's probably used by HP staff for diagnosis.
The fuser is a customer replaceable part, and does not require a service technician to install. If the customer requests a service technician to install the fuser the customer will be responsible for the labor. The fuser can be sent directly to the customer with instructions to upgrade their firmware.
What this means is that HP will send you a new fuser to fit yourself.
The models covered by this service note are:
HP LaserJet P4014 Printer series, HP LaserJet P4015 Printer series, HP LaserJet P4510 Printer series.
Start: 2010-01-01
Expiration: 2010-12-31
What this means, is that HP will send you a new fuser for this fault until the end of 2010, although they do sometimes extend the active time period for service notes.
Hope it helps..
Thanks for using fixya......
Nov 08, 2010 | HP LaserJet P4014n Printer
Primary charging roller problem for HP LJ 3005dn
How long have you had this printer for. To solve the problem you have to buy new roller for the printer
Jul 26, 2010 | HP LaserJet 1320 Printer
Our hp lj doesn't work anymore. After restart it says "Scan Error 5" or "Scan error8". This morning I managed to send a last fax but after this it stopped working. We had problems with printing those last...
this printer is experiencing what is known as a formatter/scanner assembly failure, hp has a service note issued to service printer up to 2 years after the purchase date.
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp. 1800-334-5144 in order for them to create a case under the service note and have the printer serviced. Both the scanner assembly and formatter board need to be replaced.
Mar 24, 2010 | HP Laserjet M2727nf Multifunction Printer
Tvalue 4 for windows will not print with a new printer
This is a work around as I have the same problem. If I change the default printer to something other then the HP printer, then select Page Setup, I can then select the HP without the program erroring out. You can even set the HP back to default and TValue will continue to work fine until you restart the computer.
Feb 06, 2009 | TimeValue Software TValue 4.0 for PC
50 .2 Fuser Error in HP Laserjet 4100N
you need an maintenance kit 4100
ACC C8057A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8057-67901 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8058A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 220V, LJ 4100 LJ 4100 Series
Selected Item RG5-5069-000 See RG5-5069-090 Not Available 0
Alternate Item(s) RG5-5069-090 Fuser Film ***'y, 220V, LJ 4100 180.50 2
HP LJ 4100 Fuserkit RG5-5069 HP
Dec 11, 2008 | HP LaserJet 4100n Printer
LJ 2420 service error 49.2604
A critical firmware error has occurred. Hp suggest reseating memory modules and upgrading the firmware, but i've found in the past if by turning it off and on a few times doesn't cure it the formatter board needs replacing (quite common on this model)
Sep 01, 2008 | HP LaserJet 2420 Printer
HP Hewlett Packard LaserJet P3005n Printer Logo
205 people viewed this question
Ben Johnson
