Question about DeLonghi DO400 Toaster Oven with Convection Cooking
How do I remove and replace element in DO400?
The heating element on my Hamilton Beach toaster oven 31134 has a hole in the covering and smells when I use it. Is that safe? Can I replace the heating element?
The element is failing and while it will probably not catch fire, it is better to be safe than sorry and just replace it. Does not look like a replacement element is offered. Sears has this toaster oven for $22.49 + $6.99 shipping.
Dec 10, 2016 | Hamilton Beach Toaster Ovens
My black & decker tro964 is not heating
That may sound like a stupid question, but is it plugged in?
Have you tried to plug in the toaster on a different power outlet?
If there is a ground fault switch where the toaster is plugged in (that's those outlets which have 2 buttons on the front, one labeld "Test" the other usually labeled "Reset") unplug the toaster and push the "Reset" button and try the toaster again. To test, if the power outlet, were the toaster is usually plugged in, is working, try a hair dryer or any other device on that outlet.
Its most likely cheaper to replace the whole toaster than to replace the heating elements, for about 40 $ since that's the price of your toaster on some websites.
Jan 06, 2014 | Black & Decker TRO964 Toaster Oven
How do you set the clock on the delonghi DO400 toaster oven
  1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
  2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
  3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
  4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
  5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
  • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
  • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
Oct 14, 2010 | DeLonghi DO400 Toaster Oven with...
Cant remove warped top grill element
normally this is quite simple 2 screws hold the element on ..If its warped the you could cut it out with a junior hacksaw....Try not to breath in the dust from same...
Mar 31, 2010 | Toaster Ovens
HOW TO REPLACE OVEN ELEMENT
Depending on how it is made, you need to remove the sides or remove the entire metal casing and you will see the ends of the element held in place by a clip or ring that must be removed, and of course you need to remove the electrical wires from each end of the element. Goodluck, Macgivor
Jan 31, 2010 | Toaster Ovens
Bottom elements on DeLonghi AD699 failed.
Solution: buy a new toaster oven. I determined that the manufacturer stopped selling replacement heating elements in 2006, three years after the model year (2003). After market parts makers don't sell the elements for safety and liability reasons. So I got a new one.
Nov 17, 2009 | DeLonghi AD699 Airstream Digital 1500...
BOTTOM ELEMENT DOES NOT WORK
If the top element is working, then it is either the element, the wiring harness , or the control board.
Since both elements are controlled through the same temperature probe, then the temp. probe should be OK.
The heating element must be removed and tested using a multimeter.
The part is tested disconnecting wiring from element contacts, setting a multimeter to read impedance at Rx1, and reading Ohms on element contact.
If the circuit is open (no continuity and infinite Ohms value), then the element has blown and must be replaced.
If the element has continuity, test the wiring harness, then replace wiring harness or control board.
All the test must be done by a trained repairer, strictly observing all health and safety rules.
Regards.
Oct 21, 2009 | DeLonghi EO1238 Toaster Oven with...
Can you change the default settings
hi friend,
  1. Touch Control Setup pad.
  2. Touch number 1 pad.
  3. Touch number 2 pad.
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | DeLonghi DO400 Toaster Oven with...
Delonghi AS690 toaster oven lower element won't turn on.
Cactus Bob Is WRONG. I've had these replaced; and then, when it happened subsequently, bought the part and replaced it myself. You have to take the entire thing apart. but it can be done.
Mar 13, 2009 | DeLonghi AS690 Airstream Stainless Steel...
Black & Decker Toaster Oven Model TR01000-TRO4000
I honestly believe that the burned element in my toaster oven is replaceable
like a burned out oven element or dryed element. I thought someone would
show me how to replace the element. That didn't happen. I am dubious
about the need for experts via a commitment to a specialists' plan.
Peter Olevnik
Dec 15, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
DeLonghi DO400 Toaster Oven with Convection Cooking Logo
Top DeLonghi Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Steve
Craig Butler
Craig Butler
Are you a DeLonghi Toaster Oven Expert? Answer questions, earn points and help others
