Question about Lowrance 000-10767-001 Hds-9M Gen2 Touch Insight Chartplotter
HDS Gens Touch shows positive red to negative & black to positive?
Power connection page 18 shows 12v negative wire (black) to positive & red with fuse to negative. Question is this correct? If so please confirm as we are concerned wiring incorrectly will damage the unit.
    Scholar:
  • 97 Answers
Lowrance may have goofed on the manual printing. RED is Positive, Black is negative. All these systems have reverse polarity protection. If you wire backwards, the screen will flash on and then automatically turn off.
I install these systems and I have always put the fuse hlder on the positive line at the battery. The fuse holders are always red wires and that may also lead to some confusion if they suggest attaching that to the black lead.
Hope this answers your question.
Posted on Mar 28, 2013
2 Suggested Answers
Editor925
  • 285 Answers
SOURCE: How does my Lowrance HDS-5
To connect a LRA 2400 to a Lowrance HDS-5 sounder/chartplotter, you can run an ethernet RJ45 cable from your Radar Processing box to the HDS-5 unit. You will need an adaptor cable for the RJ 45 cable to hook into the HDS-5 head unit. This is part no 000-0127-56.
As for the different transducer pinouts, I am not sure what transducer you have now so I cannot say if there is any kind of converter plug available, however, the HDS-5 units do seem to run best using the transducers that are made for them. Your best option may be to buy the transducer that is made for them, and this will directly connect to the display unit.
Hope that helps!
Posted on Mar 11, 2011
Need to connect a jet sound graphic equalizer JS-234 to a car stereo. The wires had folded stickers and some a gone. The colors of wires are red,black,gray,green.Only have 2 front speakers .
If it's only 4 wires, Red & black are typically power. red +12volts & black is ground. Gray would be one channel say right side and green would be left (example) you would ground the negative speaker lead on both sides. That is probably an old unit and make sure your car is negative ground. Some Ford & Nissan are positive grounded for some circuits which you may need to reverse the power connections. Make sure there is an in line fuse on the power wire just in case.
Feb 14, 2016 | Cars & Trucks
How do i wire up camera after somebody cut off plugs
INDUSTRY STANDARD WIRE CODE COLORS FOR CAMMERAS ARE AS FOLLOWS
RED- POWER SUPPLY POSITIVE
BLACK - POWER SUPPLY NEGATIVE
WHITE- VIDEO CENTER
YELLOW- AUDIO CENTER
THE SHIELDS ON VIDEO AND AUDIO HAVE TO BE JUMPERED TO BLACK - POWER SUPPLY NEGATIVE
NEVER ALLOW POWER SUPPLY POSITIVE TO TOUCH VIDEO OR AUDIO LEADS
Oct 09, 2014 | Lorex Home Security
Need to know where the positive wires that connect to the battery of a '95 Toyota previa connect.
Hi
The black wire will be connected to the body or engine of the van and the red or positive wire is connected to your starter motor.
You can also use a 12 volt battery light to check the negative or positive wires.
You take the 12 volt battery light and place the negative black wire clip to an earth on the vehicle, then when you touch the tip of the 12 volt battery light onto a positive wire the light will light up.
Then you will know which wires are negative or positive sometimes the key has to be on for some wires to work.
Cheers
Oct 10, 2012 | 1995 Toyota Previa
If you can help me i need to know if it is possible to wire a amp into a 2002 landcrusier stock headunit cheers
yes, there is an amp turn-on wire from the head unit (black with a red stripe). You will need to add a power wire and fuse from the fuse box to run the amp. You can use the speaker outputs as inputs to the amp, depending on what you are trying to do. Please let me know if you need more help, and identify the amp model as well as the speakers you will connect.
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Black/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Black/Red
Car Stereo Amplifier Location: Under the center console.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): Yellow
Aug 27, 2011 | Car Audio & Video
How do I wire my 12inch mtx ts 55 subwoofer two outlets red with red and black with black or red and black and red and black
The TS55 is a DVC subwoofer that can be wired for either 4 ohms (voice coils in series) or 1 ohm (voice coils in parallel). The appropriate wiring depends on the amp.
If the amp is stable at 1 ohm, wire both positives and both negatives to the matching amp output terminal (parallel) as shown in Wiring Option #1.
If the amp isn't stable at 1 ohm, connect a jumper between the positive on one voice coil and the negative on the other voice coil. Then connect the remaining positive and negative to the matching amp output terminal (series) as shown in Wiring Option #2.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=1&woofer_imp=3
Jun 17, 2011 | MTX TS551022 Car Speaker
Hello, I need to know the wiring connection destinations by color for all wires coming out of the back of the Pioneer DEH-P9200R car audio receiver. Thanks in advance. John from Baltimore
If this helps you then please help my rating,voting for me would be great too thanks.
Black - Ground
Blue - Power Antenna / Control for an AMP
Orange - Constant 12 Volts
Red - 12 Volts when the ignition is on, 0 Volts when it's off
[Speakers]
[Front]
Gray - Front Right Positive
Gray Black - Front Right Negative
Green - Front Left Positive
Green Black - Front Left Negative
[Rear]
Gray Red - Right Rear Positive
Black Gray - Right Rear Negative
Green red - Left Rear Positive
Black Green - Left Rear Negative
Nov 15, 2010 | Car Audio & Video
I have a pioneer keh-p5450. can please send me a wiring diagram for this unit?
Here is the breakdown of what wire does what:
+Red..............12v ignition
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Oct 05, 2009 | Pioneer Car Audio & Video
To wireup 160c Garmin fishfinder, there are seven clored wires. The book shows red and Yellow to hot. Black and blue to ground. Do the white, green and brown connect? Can the black and yellow be connected...
You only need the red and black wires to supply power to the unit. The red positive wire goes to a positive terminal on your battery or positive side of a bus bar or switch, the black negative wire goes to the negative terminal on the battery or negative common bus bar. Do not try to earth the black wire to an aluminum boat hull... You are asking for trouble! Best to run the black wire straight back to the negative battery terminal or negative bus bar that is wired to the negative battery terminal. The other colored wires on the 160C plug are used for interfacing with NMEA2000 compatible devices, like a compatible GPS.
Jun 14, 2009 | Garmin Color Fishfinder 160c
Installing the Lowrance HDS 5
You do not need the data cable connected unles you are hooking it up to other electronics, ie computer, second GPS sounder ect. You only need to conect the red to the positive on the battery and the black to the negative.
Jun 13, 2009 | Lowrance Hds-5 GPS Receiver
BUTCHERED WIRING.
Dont know what year you have but one of these will work. Ground is usually separate in Dodges:
1990 Dodge Caravan Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Tail Gate
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
1997 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Red/White
Car Radio Illumination Wire: Black/Yellow
Car Stereo Antenna Trigger: N/A
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Blue/Orange
2003 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Gray/Red
Car Radio Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Chassis Or Metal Strap
Car Radio Illumination Wire: Orange/Tan
Car Stereo Amp Trigger Wire: Gray/Green
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Black
Left Rear Speaker Positive Wire (+): Green/Black
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Black
Right Rear Speaker Negative Wire (-): Gray/Pink
Jun 02, 2009 | Car Audio & Video
Lowrance 000-10767-001 Hds-9M Gen2 Touch Insight Chartplotter Logo
120 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
