Question about Cameras
Ultrak kc-3p camera wiring diagram - Cameras
2 Suggested Answers
SOURCE: How do I install a Ultrak KC-3p camera?
The original Ko-1242CPUA system included a Monitor (KO-1242cpua), cameras (KC-3P) and cables (KO-60).
Posted on Feb 05, 2010
How to check the resistance on the iac in a 2000 acura ti?
Here you go: 2000 3.2TL - DTC Troubleshooting: P1519 (14)
DTC P1519: IAC Valve Circuit Malfunction
  1. Reset the PCM.
  2. Turn the ignition switch ON (II).
    Is DTC P1519 indicated? YES -
    Go to step 3.
    NO -
    Intermittent failure, system is OK at this time. Check for poor connections or loose wires at the IAC valve and the PCM.n
  1. Turn the ignition switch OFF.
  2. Disconnect the IAC valve 3P connector.
  3. Turn the ignition switch ON (II).
  1. Measure voltage between IAC valve 3P connector terminal No. 2 and body ground.
    Is there battery voltage? YES -
    Go to step 7.
    NO -
    Repair open in the wire between the IAC valve and the PGM-FI main relay.n
rjaai003_204.asp?menuid=rdbawh030000&sessionid=20a4339a-9fe0-4aa5-b153-7284daac493a&lang=0&dbkey=s80wa32k72100091519faad01
  1. Check for continuity between body ground and IAC valve 3P connector terminal No. 1.
    Is there continuity? YES -
    Go to step 9.
    NO -
    Repair open in the wire between the IAC valve and G101.n
rjaai003_204.asp?menuid=rdbawh030000&sessionid=20a4339a-9fe0-4aa5-b153-7284daac493a&lang=0&dbkey=s80wa32k72100091519faad02
  1. Disconnect PCM connector B (25P).
  1. Check for continuity between body ground and PCM connector terminal B23.
    Repair short in the wire between the IAC valve and the PCM (B23).n
    NO -
    Go to step 11.
rjaai003_204.asp?menuid=rdbawh030000&sessionid=20a4339a-9fe0-4aa5-b153-7284daac493a&lang=0&dbkey=s0k3a02k77100091519faad01
  1. Connect IAC valve 3P connector terminal No. 3 to body ground with a jumper wire.
rjaai003_204.asp?menuid=rdbawh030000&sessionid=20a4339a-9fe0-4aa5-b153-7284daac493a&lang=0&dbkey=s0k3a02k77100091519faad02
  1. Check for continuity between PCM connector terminal B23 and body ground.
    Go to step 13.
    NO -
    Repair open in the wire between the IAC valve and the PCM (B23).n
rjaai003_204.asp?menuid=rdbawh030000&sessionid=20a4339a-9fe0-4aa5-b153-7284daac493a&lang=0&dbkey=s0k3a02k77100091519faad03
  1. Remove the jumper wire from the IAC valve 3P connector, then reconnect the IAC valve 3P connector.
  1. Measure voltage between body ground and PCM connector terminal B23.
    Substitute a known-good PCM and recheck. If the symptom/indication goes away, replace the original PCM.n
    NO -
    Replace the IAC valve.n
rjaai003_204.asp?menuid=rdbawh030000&sessionid=20a4339a-9fe0-4aa5-b153-7284daac493a&lang=0&dbkey=s0k3a02k77100091519faad04
May 17, 2014 | 1996 Acura TL Series
Looking for RJ12 pinout for a ultrak kc2200nc
The access control on the Door, need to reset password.
HID 4045
Sandy
Feb 25, 2014 | Home Security
I just got a ultrak Kc552bcn ccd camera on the back has a conection for a 24 V AC, my question is that i have a radio shack ac adaptor input:120V AC 60hz, output 18/24 VAC 100ma,can i use this adapter and...
First, you have to find out the current requirement for that 24 VAC input. Just any old adapter won't do. With regard to polarity, most adapters code the positive output with a line of some color.
Oct 31, 2013 | Ultrak Kc552bcn Ccd Cctv Color Security...
Ultrak camera kc4500mn manual
I need the wiring spes.for a ultrak camera there r 2 (-) with a g in the middle
Apr 04, 2013 | Cameras
Hello\r\nI have a kc-2a camera and would like to know what the pinout is? hope you can help thank you K.V
Its RJ11E. If your system doesn't support RJ11E, you can find a adapter at B&H (that's where I got mien) to connect to a BNC DVR. Make sure the camera has the right Power supply. KC-2A use 15V dc... most camera's I have use 12V.
Aug 11, 2011 | Ultrak Kc552bcn Ccd Cctv Color Security...
How do I install a Ultrak KC-3p camera? I just have the camera and need all the attachments. what else do I need besides the camera?
Dec 05, 2009 | Cameras
Ultrak kc550bcn product manual
does anyone have an operating manual for an ultrak cctv color camera model KC550BCN
Jun 20, 2009 | Cameras
Need wiring diagram for ez go golf cart modle x444-3p
This might be useful for you. Check it out.
http://server1.buggiesunlimited.com/phpBB2/viewtopic.php?t=6298
Dec 09, 2008 | Computers & Internet
Cameras Logo
344 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
