Question about Motorsports
Nissan 720 brake light wont let ute start
Brake light comes on when when key is in START and wont let it start. When roll started (key is in ON) the brake light stays off driving around and using brakes. Does anyone know why i cant start my ute with the key? its an 84 Nissan 720 if that helps. thanks for your help.
5 Suggested Answers
  • 45 Answers
SOURCE: Front End Noise in 2005 Nissan, Maxima
it would not hurt to check rear tire wear due to misalignment
cupped tires will cause a faulty bearing type noise or humming.
Posted on Aug 27, 2008
  • 740 Answers
SOURCE: 84 Nissan 720 rear brake lock-up
Was the proportion valve and mater cylinder replaced? The problem most likely is a bad proportion valve it doesn't allow the fluid to return to the master and therefore stays in the system and locks-up the brakes.
Posted on Dec 10, 2008
  • 617 Answers
SOURCE: acidentialy turned truck off while in drive while
move shifter around and in neutral, might have broken neutral safty switch
Posted on Feb 05, 2010
ZJLimited
  • 17970 Answers
SOURCE: My ABS light and emergency
I think it means the Antilock Brake System is disengaged. So, a code has been stored in the abs computer. Standard obd tester cannot check these codes, must visit your dealer or some autoshop with ABS reader.
According with the service manual: During starting the RED brake light should briefly come on and then go off. If the RED light stays on, it indicates a problem in the main braking system, such as a low fluid level, or the parking brake is still on.
Hope helps (remember to rate and comment this).
Posted on Sep 14, 2010
Problems with starting my Nissan juke 1.2t Acenta +, I went to the dealership and purchased two batteries for the keys (including the spare), but still it doesn't start.
If the battery has power and the connections are good.
It could be a brake switch or the smart key controller.
Have somebody see if the brake lights come on when you try to start the car. If not replace brake light switch.
Jan 04, 2018 | Nissan Cars & Trucks
My 2008 nissan altima with push button start only makes a clicking sound and dash lights come on,the brake lights come on when i press the brake,and the battery is good in car and key fob
Whether or not the battery will allow the car to start will depend on the cranking amps it is still producing. Too little CCA and the starter motor will not kick over. Unless you specifically test the CCA the battery is producing you cannot say if it is "good" or not.
Try to jump start the Nissan from another vehicle with the engine idling in that vehicle. If the Nissan starts you know the battery in the Nissan is the problem and if the battery you have is 3 years or more old it can be suspect.
Dec 29, 2015 | Nissan Cars & Trucks
I have a nissan sentra .Car will not start, put car I nuetral to push wont move
the transmission linkage must not be putting car in neutral. depress the clutch and see if it will roll. that accomplished will rule out brakes dragging. neutral safety switch not satisfied therefore no start.
Feb 23, 2015 | Nissan Sentra Cars & Trucks
1998 nissan frontier dashboard brake light will not go out unless motor is turned off...
You have a brake light switch attached to your brake pedal,may be loose or bad.Read what it says,if bad light will stay on,easy to replace,just disconnect electrical connector,then unscrew nut,then remove,the end piece clicks on and off,I have a 85 Nissan 720 truck,have replaced mine before years ago. Duralast Stoplight Switch JA413 Read 1 Reviews on Duralast JA413
May 20, 2017 | Cars & Trucks
I replaced my battery in my 2002 nissan maxima now it wont start, wont even turn over, just a click sound. The day before new batter cleaned the ternimals on old battery and jumped it and it started fine....
Wiggle the bsattery terminals while someone else is trying to start car and see if that works. if not have some try to tsrat car as you bang on the starter which is directly to the left of the air box and down. you can use a tire iron or a hammer with a long metal object to bang on.
Jun 29, 2011 | Nissan Maxima Cars & Trucks
I have a nissan sentra 93 and all of the sudden the car wont start. The engine does not crank or anything, my light will turn on, but the warning lights in the dash board usually turn on by turnning the...
try placing car in nuetral and then try starting or push shifter forward while starting! this is a common problem for nissan also make sure your foot is on the brake when starting. for someof them this is a safety feature
Dec 24, 2008 | 1993 Nissan Sentra 4 Door
Motorsports Logo
27 people viewed this question
Top Motorsports Experts
Steve P
Steve P
Jim Rus
Jim Rus
chuck ringwood
chuck ringwood
Are you a Motorsport Expert? Answer questions, earn points and help others
