Question about GE Zoneline AZ25E12D3B Air Conditioner
I have a GE ptac zoneline 4000 that wont heat on resistance but will on heat pump. It will heat when the unit has been off and the temp is below 40 f. after it has been on for 5 minutes the heat goes off but the heat pump keeps going. Checked all sensors and they all read about the same 6 k. If i put ice on the room air sensor the resistance heat comes on so I changed the sensor but, the same problem continues. This unit was made about 1994. Help Paul
3 Suggested Answers
  • 54 Answers
SOURCE: Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Posted on Jun 08, 2008
SOURCE: Short cycling
The most common cause is the fan relay on the main circuit board. However, if the outside temperature is 30degF and the inside is 60-65degF then the cause could be the insulation is ruined or missing on the backside of the unit's firewall. This can cause the unit's internal thermocouple wire to read below 45degF which is the freeze sentinal temp level. Anything below this temp level will cause the unit to come on for a few minutes to warm up the air and bring it to 46degF or higher to protect internal plumbing from freezing.
The best way to check for this is to manually set the unit to one of the heat modes and the thermostat up just until the heater comes on. Let it run until the unit turns itself off. Then set the mode switch back to Off and see if the unit still cycles on and off as before.
If it does then the main circuit board should be replaced unless you are comfortable de-soldering and re-soldering another fan relay in place.
Posted on Jun 23, 2008
Heating and air unit electrical manual
Aug 20, 2014 | GE Zoneline In Wall Ptac Unit Air...
Sanyo PTAC model STB0823H1 elec. heating element
Try 1st link for Support Request, 2nd link enter zip code
Dec 12, 2013 | GE Zoneline Deluxe Series Cooling &...
Stat issues with GE Zoneline
Your coils on the outside unit may need cleaning.When they get dirty, air cannot flow through them to remove heat from the refrigerant. When this happens pressure increases until it trips a safety and shuts the unit down.
It won't run again until the pressure drops to a safe level. Also check your drain line..Make sure it's dripping.If not it's clogged and that will trip the safety switch not allowing water to back up
Sep 17, 2017 | GE Heating & Cooling
Ihave 50 ge ptac units that only the middle of getting cold
short of gas. Check for leak and arrest it. Then vacum and do gas charging.
Aug 18, 2012 | GE Zoneline In Wall Ptac Unit Air...
GE zoneline heat not working
You need to have some one check the continuity of the thermal fuses at the plug where it plugs into the side of the control box. It's a two pin plastic white plug with black fabric covered wires coming out of the plug, you should have about (0) resistance or maybe 1 ohm. If you have no reading at all you will have to pull the heating coils out. Not a big job but, the unit must be removed from the wall as you have to take off the long top metal plate. Remember you do this only if you have to get to the coils. You can get the the plastic plug with out removing the unit but unplugging the plastic plug this may be a little tough but, you can do it.
Make sure you pull the Power plug out of the unit or out of the wall before testing for continuity.
I hope this helps. I put a picture below. It's the only one I have. On the right of the unit under the control panel there is a metal box you can see the front if it in the picture. Most units have this box on the right side. On the left side of the box are the plugs for heat, fan and Thermal fuses.
There maybe another plug with yellow wires. the plug with the 2 black wires is the one you want. Squeeze the side of the plug to unlock the plug then just pull out and test.
Nov 09, 2008 | GE Zoneline AZ55H07D Air Conditioner
PTAC units burning out compressor overloads
check for the correct amps from the power source!
Sep 05, 2008 | GE Zoneline Deluxe Series Cooling &...
How to best run this thing
Hi Laurelrobin,
When the unit is on "low fan", it is fan only, and is recirculating room air. If the damper is open, it can also bring in outside air. If the space is not occupied for extended periods, it's OK to turn the unit "OFF", as long as you have a newer unit with Heat Sentinel, and the Heat Sentinel is turned on. Heat Sentinel will not let the room temp get above 85F, as long as the unit is OFF. Also, in most cases it's best to keep the damper closed. You can check your owner's manual for more info on the Heat Sentinel and other auxiliary functions. I also have an article on the temperature limiting functions of the GE Zoneline.
Feel free to contact me at greg.mcnary(at) if you need further info.
Greg McNary
Air Distributors Company, Inc.
Louisville, KY
Distributors for GE Zoneline PTAC Units, Zoneiare PTAC Units, and McQuay PTAC Units.
Aug 01, 2008 | GE Zoneline AZ38H12DAD Split System Air...
GE Zoneline AZ25E12D3B Air Conditioner Logo
49 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
