Question about Samsung DV219AE Dryer
Thermal fuse location
Trying to find the location of the thermal fuses on my Samsung DV219AE dryer
  • 433 Answers
Ok go to this web page read the instructions for testing, then go to the sears.com page, parts direct and look up thermostats and go to the diagram for locations and test
http://www.ehow.com/how_2377924_test-dryer-thermostat.html
Posted on Jan 05, 2013
2 Suggested Answers
  • 3074 Answers
SOURCE: my samsung dryer m# DV219AE worked fine yesterday
http://www.repairclinic.com/Dryer-Repair-Help
Posted on Feb 27, 2011
My Samsung electric dryer runs but doesn't get hot
Clothes dryers usually have one of three issues when they fail to heat.
Taking a good electrical meter ( with ohms readings), check first the heating element.
If it checks good, then try all of the thermostats and the fuse. (There may be as many as 5 thermostats.)
You will need to unplug the wires off of each of these items that you are testing before you test them.
Whilst you are looking, be sure to test the two hot leads from the circuit breaker box, because one of the two hot lugs is for the machine operation, one is for the heating element.
God bless your efforts.
Jan 19, 2016 | Samsung Dryers
Where is the thermal shut off fuse located and what does it look like. DV331AEW/Xaa
The thermal fuse is located on the blower housing. You should check out this link to www.repairclinic.com
for a lot more info on this and other possible items that could cause no heat. The link is; http://www.repairclinic.com/Shop-For-Parts/a8b160c44d1067187/Model-DV331AEW-Samsung-Dryer-Fuse-Thermal-Fuse-Breaker-Parts
Good Luck!
Rich Lilja
Dec 03, 2014 | Samsung DV331AEW Dryer
Where are the thermal fuses located?
Go to the sears web page, parts direct, look up your model number and then search for thermostats and then go to this page for test procedure
Jan 05, 2013 | Samsung DV219AE Dryer
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
The Dryer does not heat. The load is not too big or too small.
In most cases, a failure to heat is caused by a blown thermal fuse or high limit thermostat. Usually it is the fuse, but the fuse may be blown due to a defective thermostat. To find the location on your specific machine (and purchase the parts) try www.appliancepartspros.com To test the fuse, WITH THE MACHINE UNPLUGGED, put an ohmmeter or continuity tester across the fuse with it's wires unhooked. It should have continuity. If it is open, replace it. If the thermal fuse blows, it is fairly common to find the dryer vent partially blocked as well. Make sure it is clear. Thermal fuses are fairly cheap, but you don't want to have to replace it every other week. Good luck.
Jan 03, 2010 | Samsung Dryers
Samsung dryer blowing thermostats, constantly
you may need to replace both thermal fuses and or the heating element itself but check to make sure you have the proper temp rating for the thermal fuses
Feb 20, 2009 | Samsung DV337 Electric Dryer
Location of the thermal fuse on the kenmore gas dryer 80
Feb 03, 2009 | Dryers
Samsung DV219AE Dryer Logo
541 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
