Question about Samsung DV219AE Dryer
Where are the thermal fuses located? - Samsung DV219AE Dryer
  • 433 Answers
Go to the sears web page, parts direct, look up your model number and then search for thermostats and then go to this page for test procedure
http://www.ehow.com/how_2377924_test-dryer-thermostat.html
Posted on Jan 05, 2013
Where is the thermal fuse located on a frigidarie affinty dryer model # faqg7021wl0
Good Afternoon Friend, this is Z. I am happy to assist you!
The thermal fuse on your Frigidaire dryer (FAQG7021WL0) is typically located on the outlet duct. However, I show that this model also has another thermal fuse located on the flame housing. Hope this helps!
Jun 03, 2014 | Frigidaire Dryers
Daewoo dryer (thermal fuse)
-Most dryer's thermal fuse are locate on the back (Inside).
-Disconnect main power before remove the back panel cover off.
-Usually there are 3 thermals. (2 at heater element, 1 at exhausted
vent)
Good Luck
Mai
Dec 20, 2013 | Dryers
Where is thermal fuse
If your Kenmore dryer has stopped producing heat, chances are the problem lies with the dryer's thermal fuse. A fire-prevention safety device, the thermal fuse is designed to disrupt the flow of electricity to the dryer's heating mechanisms if the dryer temperature reaches a predetermined maximum. Once activated, the thermal fuse must be replaced to restore the heat to your dryer. In Kenmore brand residential dryers, the thermal fuse will be located in one of two places.
Instructions
Front Panel Access
1 Unplug your Kenmore dryer from its power source. Make sure that the appliance is unplugged before proceeding.
2 Use a flathead screwdriver or putty knife to remove the dryer's bottom service panel, sometimes called the toe panel. Slide the screwdriver or putty knife along the top of the toe panel until you've located the toe panel clips. The clips are usually located about four inches in from either side of the service panel. Push down on the toe clips with the screwdriver or putty knife to release. Remove the panel and set it aside.
3 Locate the thermal fuse on your Kenmore dryer. Look for the thermal fuse directly above the dryer's motor; it looks like a white strip with two wires, and is usually mounted off to one side. See Resources for a diagram of thermal components.
Rear Access
4 Disconnect the Kenmore dryer from its power source while locating the thermal fuse.
5 Move the dryer away from the wall so that you can access the back of the appliance.
6 Use a screwdriver to remove the dryer's back panel. Set the panel and loose screws aside until you are ready to replace them.
7 Locate your Kenmore dryer's thermal fuse just above the exhaust port. The thermal fuse looks like a white strip with two connected wires.
Tips & Warnings
Clogged exhaust ports are a common cause of thermal fuse failure. While you've got your Kenmore dryer in pieces, clean out the exhaust ducts to keep it functioning at its best.
Take all proper safety precautions when working with electrical appliances. Make sure that your Kenmore dryer is unplugged before attempting to service it.
Check this link ,if you use Whirlpool Dryers:
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/thermalfuse-dryer-Whirlpool-29inch-electric.html
Thanks
Apr 01, 2012 | Dryers
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Not heating
The Most common problem is a bad thermal fuse.
1 the thermal fuses are located in the cabinet of the dryer under the drum
they can also be located on the front of the blower wheel housing. on the back wall of the dryer or along the heating element can.
2. some kenmore, whirlpool machines have these fuses located in the rear of the machine.especially when the lint filter is located in the top of the dryer.
3. the heating element can also be bad.
4. if you have an ohm meter you can check the continuity of the thermal fuses,as well as the heating element.if there is no continuity on any of the above mentioned parts. Replace the faulty parts.
Also check my tip on thermal fuse locations
Jan 09, 2011 | Whirlpool Dryers
Where is the thermal fuse located?
In the back of the dryer. Look for the coiled heaters and follow the lead wires back to the fuse.
Apr 30, 2009 | Maytag PYE2300AY Electric Dryer
Thermal fuse
the thermal fuse is located on the heater box,the main fuse is located on the blower box,let me know-mike
Oct 07, 2008 | Kenmore 73952 Gas Dryer
Thermal fuse location
the thermal is on the heater box on the right side it has two white wires going to it
you need to remove the high limit stat and bracket and the heating element to get to the safety stat
Jun 13, 2008 | Crosley CDE6000 Electric Dryer
Whirlpool dryer LER5636JQ0 won't turn on
The thermal fuse for your dryer is located behind the rear panel. With the rear panel removed, you can locate the thermal fuse as a small white plastic device located on the blower fan housing on the lower left-hand side (facing from the rear). A resistance reading should indicate close to a short (0 ohms). If the thermal fuse IS defective, the replacement part number is 3392519. You can find all this information at searspartsdirect.com. Just type in your model number and look under the "Bulkhead" heading on the next page. The thermal fuse is listed as item number 7. There's also helpful part locator diagrams to assist in troubleshooting. I hope you find this information helpful. If you need further assistance, please post back and let me know.
Jun 06, 2008 | Whirlpool LER5636P Electric Dryer
Samsung DV219AE Dryer Logo
89 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
