Onkyo stereo receiver TX 8255 5-amp 125-volt fuse blown. where can I get replacement part Ref. # F901
Fuse blown. Part # 252166, How do i get replacement fuse?
  • JSokol Jan 05, 2013
    Switched fuse with 5-amp 125 volt fast-acting & 5-amp 250 volt slow-blow, both fuses were blown as soon as power plugged in. Before changing fuses I disconnected Everything from Receiver.
    The slow-blow fuse did work and the receiver was on, immediately after there was tiny puff of white smoke. Power off and unplugged.
  • 21 Answers
SOURCE: Onkyo TX-28 Receiver Output Problem
You may be confusing +/- power supply rail fuses with left and right speaker fuses.
Posted on Sep 03, 2007
  • 42 Answers
SOURCE: I am stationed in Iraq; I have a Onkyo TX-SR606
I would say : NO !
The fact tha the fuse blew wasn't because the voltage was too high, but because a component (after the fuse) became defective because of the high voltage. So there will be something defective....
Posted on Jul 09, 2009
SOURCE: Onkyo TX-SV525 A/V Receiver The fuse by the
The same rating fuse will work as long as the "Ampere" side is the same. The "Voltage" of the fuse determines the input Voltage that will be allowed. As long as you are sure that the input will only be 120V the fuse will work properly but I would recommend using the same Voltage and Amperage of the original fuse since it may fail again. Given that information if it does blow again I would recommend taking it to a specialist. A 3 Phase fuse is only available to 3 Phase inputs (480V). Unless you live in a large compound your house doesn't have that type of capability.
Posted on Sep 17, 2009
  • 1525 Answers
SOURCE: Onkyo TX-DS696. No right channel speaker sound
hello there 2 transistor 1 for the right channel and 1 for the left first thing 2 do is a visual check in good light check for any burn't part or any bulging capacitors if everythink looks ok then check underneath the board for dry joints if then you will need a mulitmeter to start testing components
regards
shasun
Posted on May 15, 2010
Testimonial: "Thanks - i'm gonna hv to take in in for the experts as i couldnt see anything visually."
jdvillanueva
  • 2098 Answers
SOURCE: tx-8511 blows fuse when turned on. I used Radio
If the unit keeps blowing the fuse means you have a shored parts on it.
See my tips by clicking http://www.fixya.com/support/r8053361-fuse_keeps_blowing. This is also applicable to your unit. The only thing added to check is the stepdown Transformer for short, also the output IC.
Hope it may help you.
Thanks for using fixya.
JDVillanueva
Posted on Feb 02, 2011
Onkio amp popped and smoked and won't turn on
check the back and there should be a fuse holder and check the fuse. Likely that your fuse is blown.
Otherwise you might have caused a short in your speaker which will do more damage but check the fuse first.
Oct 28, 2013 | Onkyo Onkio Audio Video Control Receiver...
Fuse type for onkyo a-9555
The main power fuse for most amplifiers is a fast blow, 125 volt fuse for the US and a 250v fuse in countries with 220v. This unit is 125 watt so the main fuse should be 2 amps or so. The correct fuse size is written on the circuit board next to where the internal fuse was located.
Feb 23, 2012 | Onkyo A-9555 2-Channel Amplifier
Tx-8511 blows fuse when turned on. I used Radio shak 5-amp 125 volt replacement fuse. Turn on and it blows
JDVillanueva
Feb 02, 2011 | Onkyo TX-SV414Pro Receiver
How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
May 07, 2010 | Onkyo TX-SR605 Receiver
I am stationed in Iraq; I have a Onkyo TX-SR606 7.1 Channels Receiver that was plugged into a 220VAC outlet; it blew the 10amp 125 Volt fuse on the board; no fuses available here; is it safe to say the...
I would say : NO !
Jul 09, 2009 | Onkyo TX-SR606 Receiver
Onkyo tx-sr606b no power - blown fuse?
it either a bad fuse or your transformer that is blown
Jan 06, 2009 | Onkyo TX-SR606 Receiver
Onkyo tx-ds676 dead no power up
power down the amp totally to reset processor, then try again. If still no go, may have blown internal fuses- replace and try again
.... or failed thermal fuse in mains transformer. this is a workshop repair as it involves mains voltage that can kill :)
Nov 24, 2007 | Onkyo TX-DS676 Receiver
Sep 02, 2007 | Kenwood VR-305
105 people viewed this question
 Grubhead
Grubhead
