Question about Toshiba A000006600 P100 P105 MOTHERBOARD
Applied power using wrong AC adapter. What damages occurred during power up using wrong AC adapter?
Toshiba Satellite P105-S6177 model PSPAAU-01100S Motherboard P/N DABD1VMB06C. What damages occurred applying power using wrong AC adapter? Something popped once. Very little smell, no smoke. While I fix M/B I want to change audio ear phone connector. All in one motherboard available now?
  • Toshiba Master
  • 5,660 Answers
What did you 'smoke'?
The power circuit section of the motherboard. (Hopefully only that)
While I fix M/B? Does this mean you are contemplating, board level component replacement?
Good!
Then you have skills in replacing SMD/SMT components.
(Surface Mount Device/Surface Mount Technology)
[Except for the capacitors which are Leaded. They have leads ]
However, NO.
The audio headphone jack resides on an Audio Board, and this is a separate circuit board. (PCB. Printed Circuit Board)
Therefore even if the motherboard is repaired, or replaced; you still have to replace the Audio Board.
!O_O!
No, it's cheap!
http://www.amazon.com/Toshiba-Satellite-Audio-Board-Da0bd1ab6g5/dp/B008VILH7S
The components you are looking at replacing, average around 18 cents USD to $1.01. Maybe a little higher for some SMD/SMT components, but Not much.
Without going into detailed power circuit technology, for laptops; let me just say that you will be looking for bad;
A) Power MOSFET's
B) MLCC's
C) Diodes that are SMD/SMT
D) Solid Polymer Capacitors
[MLCC = Multi-Layer Ceramic Capacitor. They are SMD/SMT also ]
Let's take a look at the motherboard,
http://www.ebay.com/itm/TOSHIBA-SATELLITE-P100-P105-MOTHERBOARD-LAPTOP-A000012540-DABD1VMB06C-31BD1MB00F-/110990042062?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D4666152334244962514%26pid%3D100011%26prg%3D1005%26rk%3D1%26sd%3D120695866207%26
Scroll to the bottom for the large photos.
The first photo shows a BOTTOM view of the motherboard.
(Heading A000012540 in blue )
This is where the Processor, Ram Memory, and graphics chipset are located.
[The Intel Core Duo T2250 processor, uses a Socket M processor socket,
http://en.wikipedia.org/wiki/Socket_M ]
The second photo down shows a TOP view.
Looking back at the Bottom view; observe the two shiny round objects at the bottom of the motherboard photo, and they have a RED mark on one side.
These are Solid Polymer Capacitors. If you look around the motherboard, you will see larger examples; but they have a BLACK mark on one side.
Rarely do these go out, but IF they do they go with a BANG!
(Like a loud POP!)
They explode like a miniature grenade, and send shrapnel all over.
Too much Voltage can do that, too.
Could be one bit the dust.
Along possibly with Power MOSFET's, and/or MLCC's.
( Except the Power MOSFET's should be rated at 30 Volts. [DC]
[ Will handle UP TO 30 Volts ]
Did you plug an AC adapter [Charger] in, that produced more than 30 Volts? )
The DC Power Jack is a DC Power Harness.
It is the DC Power Jack; attached to a small cable, and the cable ends in a plug connector. The plug connector of the cable, plugs into the motherboard.
The DC Power Jack itself, resides in a Channel formed in the outside wall of the Base Enclosure. (Also can be called the Bottom Cover),
Where it plugs into the motherboard, is the Power Circuit section of the motherboard.
This area, and the matching area on the Bottom of the motherboard, are specifically where you need to check for bad components.
http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/big/toshiba-satellite-p105-18.jpg
Not THE Power MOSFET's that are used, but a large example so you can see what to look for,
http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/FDS6679AZ/?qs=sGAEpiMZZMsrr1kXJis%252bJwONNw%252bcopWaDOKRGBUF24Q%3d
Click on the blue - Larger Image
The 'legs' on the sides are J-leads.
Example of MLCC's that are SMD/SMT.
Not THE ones, just examples. I chose a 4.7uF at 16 Volts (DC), for an example, (SMD/SMT),
http://www.mouser.com/ProductDetail/TDK/C1608X6S1C475K/?qs=sGAEpiMZZMvQvaS66kI3ThUn76Ya%2fK0CNKDzw9lb9Zc%3d
Not in your level of expertise, or something you wish to attempt?
I understand. Replacing the motherboard as a unit, may be more feasible for you.
http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/take-apart-1.htm
Something I would like to bring up;
When Windows is installed on a computer, it assigns hash values to certain major hardware components. Think of them as Serial Numbers, but with no personal information attached.
Hardware components such as;
A) Processor (CPU)
B) Motherboard. This also includes the motherboard chipset, and BIOS program. (BIOS program; To also include the version, and date of the BIOS program)
C) Harddrive
D) Graphics chipset
Change any two of these components, and Windows may throw up a 'Red Flag'.
Thinks this Genuine copy of Windows is being removed from one computer, and installed on another computer.
This = NO
Microsoft User's License states, "One GENUINE copy of Windows per ONE computer"
(Microsoft makes one Master disk. From it all GENUINE copies are made, and sold to the consumer)
You may get an Activation window that comes up. Wants you to activate the genuine copy of Windows you have on your computer.
If so reply back in a Comment, and I'll guide you in performing this simple procedure.
(Advise DO NOT use the internet method. You want to Call Microsoft. MUCH nicer to speak to a REAL person, and also if there is a problem, a HUMAN BEING can help you figure it out)
For additional questions please post in a Comment.
Regards,
joecoolvette
(The more I think about it, the more I lean towards one of the Solid Polymer Capacitors bit the dust.
The capacitors are the weakest link. Solid caps pop LOUD )
Posted on Jan 05, 2013
  • 163 Answers
SOURCE: toshiba laptop motherboard driver
you can download drivers form below website
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/askIris.jsp
Posted on Dec 18, 2008
Benimur
  • 6966 Answers
SOURCE: toshiba dc connector
If the laptop still works, then there would be no need to replace the motherboard. The DC jack is replaceable/repairable. What would be more challenging is the disassembly and eventual exposing of the bottom part of the circuitry where the DC jack is soldered into. Often the DC jack would have at least 2 solder point (not more than 3). This might interest you.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 25, 2008
SOURCE: toshiba replacment motherboard
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp..GO HERE.RICHARDM69
Posted on Dec 29, 2008
nenalex2002
  • 134 Answers
SOURCE: NO POWER AT ALL on Toshiba Satellite A105-S2101. PLEASE HELP!
Try disconnecting the power outlet and removing the battery for about 10 seconds.
Hope this helps
Alex
www.CAS411.com
Posted on Jan 02, 2009
  • 77 Answers
SOURCE: TOSHIBA MB ASSY: 1397B0014520
search ebay for the lowest prices or try google shopping it usually brings up quite a few. But if its the bios just fix it.
Posted on Jan 31, 2009
Why does my laptop have a turning circle attached to it everytime I go on google?
This is usualy a icon for Displaying that the computer is working on your request, and is send/receving information, there is nothing wrong with your computer, don't worry.
Mar 06, 2011 | Toshiba Satellite P105-S6177 Notebook
I need to know what processor ...I can upgrade a P105-S6177 Toshiba with....I need something in the 2.4 range and an upgrade video card to 256mb
You won't be able to upgrade past 2.13ghz but you can upgrade the video card no problem. Cheapest place to get one is ebay. Just ebay for "p105 video card" and a bunch will pop up.
Hope this info helps!
Oh I would search the net and even call Toshiba to verify the fastest cpu you can get. Make sure you get the model number of the CPU that will help you track it down easily. And BEFORE you install new cpu make sure you are running the latest bios firmware version before upgrade ;)
Dec 31, 2010 | Toshiba Satellite P105-S6177 Notebook
Computer starts and power off continually
It should be impact of vius try getting into safe mode and scan ur computer to kill the virus
Nov 01, 2010 | Toshiba Satellite P105-S6177 Notebook
My laptop will not turn on the ac indicator is on and the battery indicator show full charge but laptop won't power up
Can be many reasons if there is no power up and unless the mother board is checked for the source of the power supply , the functiioning of the battery backup , memory or the processor.
If not familiar get it check with a Tosibha service centre to get an idea , and estimate for you to decide further course of action.
Sep 03, 2010 | Toshiba Satellite P105-S6177 Notebook
It won't turn on or charge
may be u used it untill it discharged completely so have pateince connect the power chord nd give it some time to recharge atleast half an hour. nd now try to power on it hopefully it will work
Apr 05, 2010 | Toshiba Satellite P105-S6177 Notebook
Installed Windows 7 and now I have no volume even tho it shows it to be working
Go here
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=2450599
Toshiba has specfic instructions for your model depending on serial #. These instrustions must be followed for win 7 to work properly
Hope this helps
Please leave feedback
Dec 10, 2009 | Toshiba Satellite P105-S6177 Notebook
How to reset BIOS in dead Toshiba Satelite P105-S6177
go to ru and type msconfig.Then u'll see a window , der goto boot.ini and delete one os.and restart the system
Jun 24, 2009 | Toshiba Satellite P105-S6177 Notebook
Toshiba P105 S6104
Hi Ed;
This is issue has resolution as it has been published on Toshiba's Official Support Website. It seems you need to go to an Authorized Toshiba Center. They have a special tool to re-flash your BIOS and it will resolve the issue. I am adding the original text and link for the solution below
Good Luck
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1827224xml&sliceId=&dialogID=24612375&stateId=1%200%2024610494
New BIOS fixes incorrect power-on password prompt Document ID: 98082329 Posted Date: 08/21/07 Last Updated: 08/21/07 Category: ACPI, BIOS, Password Distribution: Public Applicable Models: Satellite P100-ST7111, P100-ST7211, P100-ST9212, P100-ST9612, P100-ST9412, P100-ST1071, P100-ST9732, P100-ST1072, P100-ST9762, P100-ST9772, P100-ST9752, P100-ST9742, P100-ST9712, P100-ST9012, P105-S921, P105-S9312, P105-S6074, P105-S6034, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S9722, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S9339, P105-S9337, P105-S6227, P105-S6217, P105-S6158, P105-S6148, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6134, P105-S6024, P105-S6054, P105-S6014, P105-S6004, P105-S6012, P105-S6002, P105-S931 << hide Use of any software made available for download from this system constitutes your acceptance of the Export Control Terms and the terms in the Toshiba end-user license agreement both of which you can view before downloading any such software.
Issue
The computer models listed above may display a "Password =" prompt when the computer is turned on, even though no power-on password has been set. If this happens, there is no password that will satisfy the password request. If the computer is turned off and back on again, it is very likely that the same password prompt will appear. The computer will be unusable until this problem is fixed.
If the problem has not happened yet, you can prevent it from happening in the future by upgrading the BIOS to the newest version.
The occurrence of this problem on any particular computer is unpredictable -- it may never happen, but it could happen any time that the computer is turned on. If this problem does occur, it will be necessary to send the computer to a Toshiba Authorized Service Provider, who will fix the problem at no charge to you.
Resolution
If this problem has not yet occurred on your computer, then click the following link to download and install BIOS version 4.00. This BIOS displays a power-on password prompt only when a power-on password has actually been set via the BIOS Setup program.
You may also browse for a newer version of the computer's BIOS at pcsupport.toshiba.com.
For more help, see Support Bulletin 98081213 Obtaining downloads and support docs from the Toshiba Support website.
If the problem has already occurred on your computer, then please make arrangements with a Toshiba Authorized Service Provider to have this problem fixed at no charge. To locate a Toshiba Authorized Service Provider (ASP), please visit Toshiba's Global ASP Locator at http://pcrepair.toshiba.com.
Jan 11, 2008 | Toshiba Satellite P105-S6104 Notebook
Toshiba A000006600 P100 P105 MOTHERBOARD Logo
264 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
