Question about Apollo 635 Circuit Board
Where is the smart learn button on the apollo 635 circuit board to add remote control devices
Door opens by itself in storm
Here are some things you can check.
Look at the LED light next to the SMART/LEARN button on rear of the motor unit. You may need to remove a light lens cover in order to see it. If the light is flashing rapidly this means you have a stuck button on one of your remote controls. Take the batteries out of each remote control. When you remove the batteries from the bad remote, the light will stop flashing. This remote needs to be replaced.
If one of your neighbors remote controls is inadvertently programmed into your receiver, you door will open when their remote is activated. If this happens you will need to clear out your receiver and reprogram your remote controls. Press and hold the smart/learn button for 6 seconds or until you see the small LED light near the button turn itself off. If the above steps have been followed and the symptoms continue, there may be an electronic short in either the wall control button or the receiver logic board. In this case, remove the wall control wires from terminals 1 and 2 on the motor unit. Should the symptoms persist after the wires are removed, replace the receiver logic board. If the symptoms stop with the wall control wires removed from the motor unit, replace the wall control button, and the wires leading to the wall control button.
Aug 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a lift master model 41a3519 and cannot find the place on the circuit board to set the code to open the garage door remotely. Can you help?
The smart/learn button is on the rear of the motor unit near where all those white wires go. To program a remote you press and hold the button on the remote while you press and immediately release the smart/learn button.
Aug 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door is opening randomly
Mar 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens intermittantly after it has been closed for a while
Here is some information and tips to try.
Jan 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
HAVE SEARS/CHAMBERLAIN "91"MODEL 53615SR AND NEIGHBORS OPENER KEEPS OPENING OUR GARAGE DOOR BUT OUR OPENERS WONT OPEN HIS
Dec 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens and closes randomly without anyone being around
Some things you can check.
Nov 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door open by its self
Nov 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Model 3 41A4315-7D Have 2 remote controls and one keypad. I reset all the codes and I can follow the instructions and program one device, any other device will not program after the first device is...
You might try programming them this way if you haven't already.
Press and hold the button down on your remote and then press and immediately release the smart/learn button. Do this for both remotes.
Press and immediately release the smart/learn button and then walk over and key in your 4 digit code and press enter on your keypad.
What was the problem that made you decide to "reset the codes"? May be a clue to your problem.
Jul 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Apollo 635 Circuit Board Logo
96 people viewed this question
Top Apollo Home Security Experts
Lawrence Oravetz
Are you an Apollo Home Security Expert? Answer questions, earn points and help others
