Question about Coffee Makers & Espresso Machines
Saeco sg 200 empty drip tray - Coffee Makers & Espresso Machines
SOURCE: Saeco Espresso machine - Empty drip tray (all the time)
Clarification: It complains constantly. Even when I empty the drip tray, which is already empty, put it back in (empty) - it still wants me to "empty the drip tray" again. Sometimes - if I'm lucky - I can brew 1 espresso before it wants me to empty the drip tray.
Thank you for your assistance!
Posted on Jul 11, 2008
mirran
  • 515 Answers
SOURCE: Talea Touch - Drip Tray not raising/lowering smoothly
It can be the sensor or the engine that have to be replaced:-(
Best regards
/Mirran
Posted on Sep 08, 2008
  • 24 Answers
SOURCE: Saeco Magic De Luxe type SUP012 r Water leakage into brew unit
The amount of water you are describing is more than I would expect from normal depressuring at the end of the brew cycle. On your machine a leaking steam valve will frequently drain into the drip tray. If you see water driping in the area of the coffee spout, then the valve is likely leaking.
The best way to confirm this or find the source of the leak is to take the top off the machine and operate it so that you can look inside during brewing. Parts diagrams are available at http://www.saecooutlet.com/partsdiagrams.aspx. You can obtain the parts from Saeco or one of their service centers. If you need further assistance you can email john@uncommoncoffee.com.
Good luck
Posted on Jul 01, 2009
  • 60 Answers
SOURCE: Empty Drip Tray message
Try to clip off the tray contacts and clean behind them. If they are dirty and wet on the backside the machine will keep asking you for Empty tray. Use a small screwdriver and clip them off from the inside of the tray
Posted on Aug 20, 2009
SOURCE: Empty drip tray warning stays on
Subscribe to my Premium Plan and I will tell you how I fixed it
Posted on Oct 30, 2009
Saeco energica is half way through descaling cycle but is getting stuck how do I reset
Thoroughly clean the drip tray before putting it back may help. If there is still coffee inside which is wet the sensor may see this as water which is still in the drip tray.
Feb 15, 2015 | Saeco Coffee Makers & Espresso Machines
I was descaling my exprelia coffee machine.i was asked to empty the coffee grounds unit and the drip tray. I did that and the message keeps appearing. I even turned the machine on and off. Help.
  1. Thoroughly clean the small overflow area in the drip tray. Once the drip tray gets full water flows over a small rim into this small separate part thus triggering the sensor that tells that the drip tray should be emptied. Its waals may get a bit fatty/dirty, and so remains wet and keeps triggering the sensor.
May 23, 2014 | Saeco Exprelia Automatic Espresso Machine
Barista supremo thinks it doesn't have coffee beans
http://www.espressotec.com/media/downloads/57/SA1260_Odea_Giro_plus_manual.pdf The red light comes on, doesn't it? The light indicates that the water tank could be empty or the drip tray is full. Tell the coffee machine that it has enough beans, but to please the machine you will fill the water tank and empty the drip tray. Good luck, kolbrun
Sep 10, 2013 | Saeco Odea Giro Plus Coffee Maker
Empty drip tray message
On the bottom of the machine attached to the drip tray is a sensor that "sees" liquid. If there is no liquid thgere, clean the sensor, if there is, empty the tray!
Jan 01, 2013 | Gaggia 1003380 Accademia Espresso Machine
Gaggia accademia displays empty grounds drawer and drip tray. This message will not go away despite emptying the trays?
It could be that the connectors on the drip tray need scrubbing with a wire brush or replacing.
Bean to cup Commercial Coffee Machines have this issue but it's a simple fix
Nov 19, 2012 | Coffee Makers & Espresso Machines
New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
Dec 24, 2009 | Saeco Odea Giro Plus Coffee Maker
Empty drip tray warning stays on despite tray being empty
Oct 30, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
aye that is true if you click the coffe making button directly after you have had it out you will be able to make a cup, as the machine has a 2 second response time.
Ok here is what i think:
As it registers the driptray I dont think its the sensor to it.
More i would think that its the CPU card that is not responding to that its clean.
I am sry but I have to ask this:
When it says emptie the driptray are you actually taking out the container that is located under the brewing unit, and not the "drip tray" were you put the coffe mugs?
Also when i think i have a sensor problem I allways take out everything. Brewing unit, dripwater container, dregbox, and the watercontainer. and have it out for atleast 2 minutes ( clean it under the mean time) and put it back again.
As I dont have the machine infront of me i cant be certain:)
Jul 11, 2008 | Saeco Talea Ring Plus Espresso Maker with...
Coffee Makers & Espresso Machines Logo
57 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
