I am not getting a signal on my laptop with the netgear box. the model # is wgr614. I am hard wired into my modem now. I couldn't remember my security password so I pushed the reset button on the back. now I can't get it to work at all.
    Novelist:
  • 148 Answers
When you press the reset button on your router, you essentially erase all of the settings back to factory defaults. You will have to set up your router as if youre connecting it for the first time. You need the default gateway IP address (this is needed to directly access the router itself), and information based on your internet connection type (cable modem or DSL). If you use a DSL modem, you may need your username and password (this should have been provided for you when you got your service; call your provider's customer service if you dont have it). The setup CD that came with your router can (and most times will) help you with setting up your router. Newer setup CDs do most of the work for you. Follow the CDs instructions and refer to the owners manual for more info.
Posted on Mar 04, 2009
Cannot remember my w-f password
If you lose or forget your password, you can usually get it from your modem or your Internet service provider.
  • 1 Look on your modem. This is the box that your Internet service provider gave you when your Internet service was installed. Some Internet Service providers put your wireless password directly on the box along with your user-name. A modem may or may not be separate from a wireless router, which sends out the wireless signals. If you have two boxes and are unsure which is which, look at both.
  • 2 Call your Internet service provider if you cannot find a password on the modem. You can also try online customer service through your service provider's website if you are able to get Internet access apart from your wireless connection.
  • 3 Talk to a customer service representive and ask to retrieve your password. You may be required to change it. Be prepared to provide security information that the service provider has on file, such as your Social Security number, phone number, address or another personal security question.
    Mar 29, 2012 | NetGear WGR614 Wireless Router
    Ialso have suddenlink
    How to Set Up a Netgear WGR614 V5 Wireless Router
    Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
    Things You'll Need:
    Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
    1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
    2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
    3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
    4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
    5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
    6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
    7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
    Jan 09, 2012 | NetGear WGR614 Wireless Router
    Could not make router to work, Netgear modem adding router.
    i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
    Nov 10, 2009 | NetGear WGR614 Wireless Router
    I have moved one of my two computers to my guest house which is about 120 feet away from my cable modem and I have no connection to the internet. I have the computer in the main house connected to a...
    I would go wireless. Try to connect to the net using a laptop (wireless) at the guest house. If the signal strength is decent you should be fine with getting a wireless NIC for the PC in the guest house.
    If the signal strength is bad, either buy a 802.11N router (make sure it's N and not draft N, these should be available now or within a few weeks (nov 09), or buy another access point and connect it via ethernet to the main access point. you only want one modem and one gateway generally speaking.
    Nov 08, 2009 | NetGear WGR614 Wireless Router
    I have a NetGear WGR614 Wireless G Router and the Ethernet light on my modem box as well as a signal light on the router is continuously blinking and making the internet run very slow, do you know how to...
    This is a problem with the firmware of your router, so what you can do here is to update the firmware of it you can get the updated firmware from Netgear web site....
    Jul 12, 2009 | NetGear WGR614 Wireless Router
    Internet connection disappears.
    You may either need to do a firmware update, or reset it back to factory default, you can download the firmware from the netgear site, or you can log onto the router and do a reset of the router.
    Hope this helps,
    Daid
    Mar 15, 2009 | NetGear WGR614 Wireless Router
    Wireless sgnal working but auable to connect to go online
    You need to give the password of your modem in netgear settings .
    Nov 25, 2008 | NetGear WGR614 Wireless Router
    NETGEAR WIRELESS
    More details are needed here, do you have mac address filtering on and is your router using dhcp or fixed address for your computers?
    Jan 17, 2008 | NetGear WGR614 Wireless Router
    Computers & Internet Logo
    56 people viewed this question
    David Payne
    David Payne
