Question about Garden
Electric shock pond water pump - Garden
4 Suggested Answers
  • 9 Answers
SOURCE: PUMP RUNS BUT DOES NOT **** UP WATER
I have experienced this same problem and all I needed was to prime the pump. Unless your pump cannot pump up that high.
Posted on Jan 22, 2009
  • 3 Answers
SOURCE: need to seal around pond pump electrical
sndrglltt27,
try draining below elec cord, use 100% silicone to plug hole, it will take 24hours +/- to dry.
Posted on Oct 26, 2009
  • 56 Answers
SOURCE: I have a brand new hozelock easyclear 6000 pond
Sorry to hear of your setback but hopefully we can get you back to worrying about your pond occupants rather than the equipment. First remove the filter cover and filter and give the impeller a gentle turn to feel if the bearing or motor is jammed. If it turns freely try powering the unit to check if the impeller turns, sometimes the impeller needs a little bump to get it moving at first. If nothing still happens return the pump for a replacement.
Posted on Mar 29, 2011
Where can I find a solar evacuation water pump?
try and see if a solar driven pond (fish pond or fountain )pump will do the job.
Nov 13, 2014 | Cars & Trucks
Pump stopped working after 6months running can it be rebuilt
Has it exceeded the manufacturer's warranty? Don't try to compromise the water tight housing where the electro-magnet is located, as this could result in a nasty electric shock (or worse). Try cleaning the impeller and the impeller housing. Perhaps try a replacement impeller.
Sep 04, 2011 | Tetra Pond Pump Dynamag 750
Ive noticed a small electric current running through my pond water , its obviously coming from my pond pump . This cant be normal ? Can anyone help ?
There must be a leak somewhere where water is going in the pumps wirering or its not grounded properly.
Apr 23, 2011 | Garden
Installing an air pump in a 5000 litre tank
The pump must be mounted nearest the 5000 liter tank. The air intake will be the air sorrounding the area, while the discharge low pressure air must be pipe to underwater level such that the air discharge of the air pump bubble up the water (aerate the water) inside the tank. This is common in fish pond/ shrimps pond/ and water treatment plants. Electrical wiring is
standard for the electric motor and controls.
Nov 04, 2009 | Plumbing
Our pond water pump has no pressure so we have no water
1. Pump burned up. 2. Check to see if there is something blocking the intake. 3. Plug it in to a well grounded electrical outlet. Hope you get it working.
Jun 13, 2009 | Garden
Pond pump trips circuit breaker
The circuit breaker trips because there is an electrical short in the pump itself or in the wire feeding the pump. A cause of this could be a bare wire, or a crack in a wire. Remove the pump and put it in a five gallon pail of water and test it. If it still trips the breaker you will know the problem is in the pump or the cord to the pump.
May 02, 2009 | Beckett Corporation Beckett Professional...
GFI for pump keeps tripping...
no you need to put 60amp breaker in house panel box
Jan 15, 2009 | Beckett Water Gardening Beckett Statuary...
Drive systems difference
Magnetic Drive: In a magnetic-drive pump, an electrical charge creates a magnetic field that causes the magnet on the impeller to rotate and pump water. Magnetic drive pumps are completely sealed and do not require lubrication. Because they do not contain oil, magnetic drive pumps are safer for ponds with fish as oil leaks do not occur. This type of pump does not generate high head heights, meaning it is unable to lift pond water vertically, which you might need to supply water to a fountain. Work best in cleaner environments with little or no debris Highly efficient, cost-effective operation Since they have no seals to wear out, they require little maintenance Occasionally clean the impeller and its chamber to ensure efficient operation Direct Drive: Direct-drive pumps have an enclosed motor that is powered by electricity, which turns the impeller shaft. Direct-drive pumps achieve significant head height so they tend to work well for fountains or waterfalls. Some models seal the motor in an oil-filled shell with seals around the cord and impeller shaft. These are risky to use if you have a pond stocked with fish as there is an ever-present danger of water contamination if a leak occurs. Many newer pumps, however, feature alternative lubrication over oil that is safe for fish. Look for oil-free models if you house fish or other aquatic life in your water garden. Typically more expensive to operate Ideal pump type for fountains or other accessories Pushes water rather than pulling it Not easily repaired by the user
Aug 27, 2008 | VIA Aqua Pump 4900
Pond pump types
There are basically two types of pond pumps to choose from - externally mounted and submersible. External pumps were traditionally used in water gardens. They sit outside the pond, with a hose that leads from a strainer in the pond to the pump. From there the water is forced either to a waterfall, stream or fountain. Because external pond pumps are often noisy and require extra plumbing, they are usually not suited for most backyard ponds. Due to easier accessibility and ease of repair, however, external water pumps are often the best choice for larger water gardens and public installations. Submersible water pumps are usually preferred by most do-it-yourselfers. They sit underwater where they are quiet and unseen. These pumps are easy to install, require no priming and stay cool thanks to the surrounding water. Submersible pumps draw water from the bottom of the pond, either through a strainer or biological filter. A hose attached to the outlet then feeds water to whichever water feature you have installed.
Aug 27, 2008 | Little Giant Opwg 71 71 Gpm Out of Pond...
Garden Logo
104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
